Fe and paramagnetic/diamagnetic
  • Thread starter JustinLevy
In summary, iron is unique in its ability to easily form molecules with unpaired electrons due to its high number of possible oxidation states and spin-orbit coupling.
JustinLevy
895
I don't understand why people expect iron compounds to have unpaired electrons, just because an iron atom does. Atomic silicon does as well. So do many other atomic species. But it seem fairly rare to get a molecule to have unpaired electrons in the ground state ... so what makes Fe special in that respect.
So I have three questions:
1) Does anyone know of an example of a neutral simple (as in just one Fe atom) molecule containing Fe which is diamagnetic? I'd like to play with it in a quantum chemistry program to see some stuff, so the simplier the better.
2) Does anyone know of an example of a charged simple complex containing Fe which is diamagnetic?
3) Can anyone give me some guiding insight for why some atoms seems special with regards to "causing" unpaired electrons in molecules?
Thanks.
1) A simple neutral molecule containing iron that is diamagnetic is FeO. 2) A simple charged complex containing iron that is diamagnetic is the ferric ion (Fe3+).3) For certain elements, including iron, it is easier for the electrons to remain unpaired in molecules than it is for other elements. This is due to the fact that iron has a greater number of possible oxidation states, and so it can more easily form molecules with multiple unpaired electrons. This property is known as spin-orbit coupling, and it allows certain elements, such as iron, to have higher spin multiplicities than other elements.
Related to Fe and paramagnetic/diamagnetic
1. What is the difference between ferromagnetism and paramagnetism?
Ferromagnetism is the property of certain materials, such as iron, where they can retain a permanent magnetic dipole moment even in the absence of an external magnetic field. Paramagnetism, on the other hand, is the property of materials where the magnetic dipoles are only aligned in the presence of an external magnetic field and lose their alignment when the field is removed.
2. Is iron a paramagnetic or diamagnetic material?
Iron is a paramagnetic material, meaning that it is weakly attracted to an external magnetic field and will become temporarily magnetized in its presence. It is not diamagnetic, which would mean that it is repelled by an external magnetic field.
3. How does the electronic structure of iron contribute to its magnetic properties?
Iron has an atomic number of 26, giving it 26 electrons. In its ground state, iron has 2 electrons in its innermost energy level, 8 in the second energy level, and 14 in the third energy level. The remaining 2 electrons in the third energy level are unpaired and can contribute to the overall magnetic moment of the atom.
4. What is the Curie temperature of iron?
The Curie temperature is the temperature at which a ferromagnetic material loses its permanent magnetization and becomes paramagnetic. For iron, this temperature is 1043 K (770°C or 1418°F).
5. How can the magnetic properties of iron be used in everyday life?
The magnetic properties of iron are used in various everyday objects, such as refrigerator magnets, compasses, and electric motors. Iron is also a crucial component in the production of steel, which is used in construction, transportation, and many other industries.
18K
