FEA Hand Calculation Validation
In summary, the speaker has run an FEA analysis on a part and wants to validate the results through hand calculations. They are seeking guidance on the formula for calculating stress and are also working on a related problem with another person on a mechanical engineering website.
Saints-94
63
I have ran an FEA analysis on part screenshot below. I wanted to do some hand calculations to validate the results. What formula should I use to calculate the stress?
Calculate the bending moment in the two beams (by symmetry, you should be able to assume that they are the same, assuming that the loading is otherwise symmetric), then use sigma = Mc/I to get the bending stress.
This is the same problem that Saints-94 subsequently entered On the Mechanical Engineering site as the "Tube Bending Stress" thread that we are now helping him with.
See that thread for the latest updates.
Related to FEA Hand Calculation Validation
1. What is FEA Hand Calculation Validation?
FEA Hand Calculation Validation is a method used to verify the accuracy of Finite Element Analysis (FEA) results by comparing them to hand calculations. It involves performing hand calculations using simplified equations and assumptions, and then comparing the results to the FEA results to ensure they are within an acceptable range of error.
2. Why is FEA Hand Calculation Validation important?
FEA Hand Calculation Validation is important because it helps to validate the accuracy of FEA results and identify any potential errors or discrepancies. This is crucial in ensuring the reliability and credibility of FEA simulations, which are commonly used in engineering and scientific research.
3. How is FEA Hand Calculation Validation performed?
FEA Hand Calculation Validation is performed by first selecting a representative element from the FEA model and simplifying the geometry and loading conditions. Hand calculations are then performed using basic equations and assumptions, and the results are compared to the FEA results. If the results are within an acceptable range of error, the FEA results are considered valid.
4. What are the benefits of FEA Hand Calculation Validation?
The benefits of FEA Hand Calculation Validation include ensuring the accuracy and reliability of FEA results, identifying potential errors or discrepancies in the FEA model, and providing a deeper understanding of the FEA model and its behavior. It can also save time and resources by catching errors early on in the simulation process.
5. What are the limitations of FEA Hand Calculation Validation?
One limitation of FEA Hand Calculation Validation is that it relies on simplifications and assumptions, which may not always accurately represent the real-world conditions. It also requires a thorough understanding of both FEA and hand calculation methods, which can be time-consuming and challenging. Additionally, FEA Hand Calculation Validation may not be suitable for all types of FEA simulations, such as those with complex geometries or non-linear materials.
  • Mechanical Engineering
