Feasibility of Open Heat Exchanger
In summary, an open heat exchanger is a device used to transfer heat between two fluids without them mixing. Its feasibility depends on factors such as fluid temperature and flow rate, materials used, and overall system design. Efficiency is measured by comparing actual and maximum heat transfer rates. Advantages include handling corrosive fluids, simple design, and ability to handle large temperature differences. Limitations may include contamination risk, heat loss, and safety precautions.
jamesasteven
Background:
I am a Chem Eng student at the University of Houston. I have worked on this problem quite a while but am stuck.
Question:
A stream of liquid A in an industrial plant, flowing at rate of 2kg/s, needs to be heated from 5 C to 90 C. Another stream or 5kg/s of liquid B, at a temperature of 60 C is available for possible heat exchange. Assuming that unlimited heat exchange is possible with the environment (which is at 20 C), can heating of stream A be accomplished with no external work input?
-If your answer is yes, show a schematic of your proposed process, and compute the flow rate and exit temperature of stream B and the rate of heat exchange (if any) with the environment.
-If your answer is No, provide a full quantitative justification for this claim. the heat capacities at constant pressure of the two liquids are 3Kj/Kg K for A and 2Kj/kg K for B, independent of temperature.
My attempt is attached (pdf). Any advice would be much appreciated.
Have a great day!
  • 09-24-2013.pdf
Dear Chem Eng student,
Thank you for your question and your attempt at solving the problem. I will provide some guidance and suggestions to help you move forward in your solution.
First, let's review the basics of heat exchange. In order for heat exchange to occur, there must be a temperature difference between two streams. In this case, we have a stream of liquid A at 5 C and a stream of liquid B at 60 C. The environment, which is at 20 C, can act as a heat source or sink depending on the direction of heat flow.
Now, let's consider the equations that govern heat exchange. The most important equation is the heat transfer equation, Q = mCpΔT, where Q is the amount of heat transferred, m is the mass of the liquid, Cp is the specific heat capacity, and ΔT is the change in temperature. This equation tells us that the amount of heat transferred is directly proportional to the mass and specific heat capacity of the liquid, as well as the temperature difference between the two streams.
Based on this equation, we can see that in order for heat exchange to occur between the two streams, the temperature difference between them must decrease. In other words, the temperature of stream B must decrease in order to heat up stream A. However, in this case, the temperature of stream B is already higher than the desired temperature of stream A. This means that heat exchange cannot occur without external work input.
To provide a quantitative justification for this claim, we can use the heat transfer equation to calculate the amount of heat needed to heat up stream A from 5 C to 90 C. This comes out to be 2kg/s * 3Kj/Kg K * (90 C - 5 C) = 2.7 MW. This means that in order to heat up stream A without external work input, stream B would need to transfer 2.7 MW of heat to stream A. However, since the temperature of stream B is only 60 C, it does not have enough heat to transfer to stream A and therefore cannot accomplish the task.
In summary, the answer to the question is no, heating of stream A cannot be accomplished with no external work input. In order for heat exchange to occur, there must be a temperature difference between the two streams, and in this case, the temperature difference between stream B and A is not enough to achieve the desired temperature for stream A.
I
Related to Feasibility of Open Heat Exchanger
1. What is the purpose of an open heat exchanger?
An open heat exchanger is a device that is used to transfer heat between two fluids which are not in direct contact with each other. The purpose of an open heat exchanger is to efficiently transfer heat from a hot fluid to a cooler fluid, without the two fluids mixing together.
2. What factors determine the feasibility of an open heat exchanger?
The feasibility of an open heat exchanger depends on several factors, including the temperature and flow rate of the fluids, the materials used for the heat exchanger, and the overall design and operating conditions of the system.
3. How is the efficiency of an open heat exchanger measured?
The efficiency of an open heat exchanger is typically measured by the effectiveness or effectiveness-NTU method. This method compares the actual heat transfer rate to the maximum possible heat transfer rate between the two fluids, and calculates the efficiency as a percentage.
4. What are the advantages of using an open heat exchanger?
Open heat exchangers have several advantages, including their ability to handle corrosive or fouling fluids, their simple design and low maintenance requirements, and their ability to handle large temperature differences between the two fluids being exchanged.
5. What are the potential limitations or challenges of using an open heat exchanger?
Some potential limitations or challenges of using an open heat exchanger include the risk of contamination if the fluids are not carefully selected and monitored, the potential for heat loss due to the open design, and the need for proper insulation and safety precautions to prevent accidents.
  • Mechanical Engineering
