MHB Felix's question at Yahoo Answers regarding Newton's method
The discussion revolves around using Newton's method to find a root of the equation f(x) = 0, given that the line y = 5x - 2 is tangent to the curve y = f(x) at x = 4. At this point, f(4) equals 18, and the derivative f'(4) is 5. Applying Newton's method with the initial approximation x1 = 4, the second approximation x2 is calculated as x2 = 4 - (18/5), resulting in x2 = 2/5. This outcome aligns with the expectation that the second guess is the root of the tangent line. The discussion effectively demonstrates the application of Newton's method in this context.
MarkFL
MHB
Here is the question:
Suppose the line y = 5x − 2 is tangent to the curve y = f(x) when x = 4. If Newton's method is used to loc?
Suppose the line y = 5x − 2 is tangent to the curve y = f(x) when x = 4. If Newton's method is used to locate a root of the equation f(x) = 0 and the initial approximation is x1 = 4, find the second approximation x2.
x2 = ___?______4.8, 4
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Felix
Since the line $y=5x-2$ is tangent to the function $f(x)$ at $x=4$, we know two things:
a) The function and the line have a common point at $x=4$:
$$f(4)=5(4)-2=18$$
b) At $x=4$ the function's derivative is equal to the slope of the line:
$$f'(4)=5$$
Now, Newton's method gives us:
$$x_{n+1}=x_{n}-\frac{f\left(x_n \right)}{f'\left(x_n \right)}$$
If the initial approximation is $$x_1=4$$, then the second approximation is:
$$x_{2}=x_{1}-\frac{f\left(x_1 \right)}{f'\left(x_1 \right)}=4-\frac{18}{5}=\frac{2}{5}$$
As we should expect, the second guess is simply the root of the tangent line:
$$0=5x_2-2\implies x_2=\frac{2}{5}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
