Zeda
- 10
- 1
Hey everybody, I thought I would share an algorithm for factoring that I designed a few years ago while working on a Z80 project. I noted the same thing Fermat must have:
[itex]a^{2}-b^{2}=(a+b)(a-b)[/itex]
After a few moments of looking at it, I realized the translation of that simple expression: If I can find a difference of two squares to equal a given number [itex]c[/itex], then I have factors of c. So for example, 102-52=100-25=75, so 75=(10+5)(10-5)=15*5. Now I also knew that the difference of consecutive squares produced the odd numbers, so 22-12=3, 32-22=5, 42-32=7, ... so I knew that for all odd numbers, there had to be a trivial solution. As well, I was interested in the specific application of factoring RSA keys, so my inputs were always going to be odd and the product of two distinct primes (inputs of 4n,4n+1, and 4n+3 work, but inputs of 4n+2 do not).
So now, here is the problem I was looking at:
Given a natural number [itex]c=pq[/itex] with [itex]p,q\in \mathbb{p}[/itex], then find integer solutions for the equation [itex]a^{2}-b^{2}=c[/itex].
So from here, I rewrote what I had, arriving to:
[itex]b^{2}=a^{2}-c[/itex]
So then we get a restriction that [itex]a^{2}\gt c[/itex] and we need [itex]a^{2}-c[/itex] to be a perfect square. A more naive approach, then, is:
This works, but there is an obvious optimisation we can use with a little math. We note that if we change the order of the code so that a is incremented after b is adjusted, then we need use (a+1)(a+1):
However, this is not the optimisation. The optimisation is that we can see that we are just adding 2a+1 to the original value of b. This replaces a multiplication with an addition and on top of that, it is in the main loop, reducing complexity:
This is a rather standard approach, but those square roots being part of the main loop is ugly to me. I am used to integer add/sub/rotate so square roots or very slow. Now is where I come in with a different approach.
Instead of testing if b is a perfect square at each iteration, we can just test how far away from a perfect square b is. Note that the next perfect square after x2 is x2+2x+1. If we find that b is 2 higher than a perfect square initially, then after the first iteration, it is increased to 2+2a+1=2a+3. if this number is greater than or equal to 2b+1, then we know that it is larger than the next perfect square, so subtract of the 2b+1 and increment b. If this is still larger than 2b+1, repeat. Once this hits 0, we know that b has become a perfect square.
To put this all together:
Now the two square root operations are the most complicated routiens required, and they are just overhead. The loops only perform addition and subtraction, which is what I prefer. However, to remove some of the operations needed:
And if we assume all integer operations:
The following C code took 11 seconds to factor the 64 bit number:
It was done in 32-bit mode on a 1.6GHz AMD processor. Also, I am not fluent enough in C to apply aggressive optimisations like I would in Z80. Maybe somebody could port this to other assembly languages to test benchmarks?
Code:
ceil(√(c))→a
a*a-c→b
while int(√(b))≠√(b)
a+1→a
a*a-c→b
endwhile
return {a-√(b),a+√(b)}
Code:
ceil(√(c))→a
a*a-c→b
(a+1)(a+1)-c→b
a+1→a
endwhile
Code:
ceil(√(c))→a
a*a-c→b
b+1+2a→b
a+1→a
endwhile
Code:
ceil(√(c))→a
a*a-c→b
int(√(b))→e
b-e*e→e ;e is how much larger b is than the largest perfect square less than or equal to b.
while e≠0
e+2a+1→e
a+1→a
while e>=(2b+1)
e-(2b+1)→e
b+1→b
endwhile
endwhile
Code:
ceil(√(c))→a
a*a-c→e
int(√(e))→b
e-b*b→e
(a<<1)+1→a
(b<<1)+1→b
while e≠0
e+a→e
a+2→a
while e>=b
e-b→e
b+2→b
endwhile
endwhile
(a-1)>>1→a
(b-1)>>1→b
return {a-b,a+b}
Code:
1+√c→a
a*a-c→e
√e→b
e-b*b→e
1+a<<1→a
1+b<<1→b
while e≠0
e+a→e
a+2→a
while e>=b
e-b→e
b+2→b
endwhile
endwhile
return {a>>1-b>>1,a>>1+b>>1}
Code:
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <math.h>
int main()
uint64_t x=0xFFFFFFF6E0172B75LL;
uint64_t r=ceil(sqrt(x));
uint64_t err=r*r-x;
uint64_t s=sqrt(err);
err-=s*s;
s+=s+1;
r+=r+1;
while(err>0)
err+=r;
r+=2;
while(err>=s)
err-=s;
s+=2;
printf("%u,",r/2-s/2);
printf("%u",r/2+s/2);
return 0;
