Fermat's Principle, Snell's Law, and the Prism
In summary, the conversation discusses the issue of blue light following a longer path in a prism than red light, which seems to contradict Snell's Law. There is a debate on the validity of Snell's Law in this scenario and the use of Fermat's Principle to explain the difference in the paths. There is also a mention of using the wave vector of the light wave to derive Snell's Law and the different refractive indices of blue and red light causing them to take different paths in the prism.
Roger Dodger
42
I have a conundrum of sorts that has made me feel like an idiot and I am hoping someone can point out my mistake.
Suppose a light source is placed to the left of a prism and a detector is placed on the opposite side. I have seen plenty of pictures of this sort, and they all appear to show the light passing through the prism obeying Snell's Law. But in doing so, they have the blue light sampling a more substantial portion of the prism than the red light. To me, this makes no sense. Blue light is slower than red light when passing through glass so if anything it would want to sample those paths that reduce its time in the prism.
I fail to see how Snell's Law applies here. Every derivation I have seen of Snell's Law has the detector placed inside the glass. This will give a local path of least action for light refracting from the air into the glass. However, this path would not appear to be related to the path of least action for the entire trip from source to the detector placed to the right of the prism.
Using Feynman's QED description of light, the probability amplitude for reaching the detector would be the product of (1) the probability amplitude for reaching a detector inside the prism and (2) the probability amplitude for light emanating from that detector into the air and reaching the other detector.
I realize we can see the light as it passes through the detector, but that's a completely different problem, since there is no guarantee that the light that reaches the detector sampled the same paths that the light that reaches our eyes sampled.
Or do I have it all wrong?
Science news on Phys.org
Fermat's Principle says that the time the light travels between points P1 and P2 along a path that the time shortest. The blue light travels in the prism along different path than the red light, If you want to make that time shortest, you need to choose a different angle of incidence.
You need to apply Fermat's principle for the entire path from the source and detector, without placing a detector inside the prism. No light emanates from a detector. It is absorbed there.
Snell's Law can be derived from Fermat's principle at an interface between two media, but there is a simpler approach, based on the wave vector k of the light wave. kh serves as momentum of the corresponding photon. When the photon strikes the interface at angle of incidence θ the interface exerts only normal force, so the component k parallel with the interface remains unchanged. This component is ksin(θ) which is the same at both sides of the interface. And k=n/(λ0) where λ0 is the vacuum wavelength and n is the refractive index of the medium. So n1sin(θ1)=n2sin(θ2)
Snell's Law applies at both interfaces the light strikes when enters and leaves the prism. The blue light has refractive index different from the red light, it follows different path inside the prism.
ehild said:
Fermat's Principle says that the time the light travels between points P1 and P2 along a path that the time shortest. The blue light travels in the prism along different path than the red light, If you want to make that time shortest, you need to choose a different angle of incidence.You need to apply Fermat's principle for the entire path from the source and detector, without placing a detector inside the prism. No light emanates from a detector. It is absorbed there.
That much I realize. The problem is that Snell's law is derived by placing the detector inside the glass. As I pointed out, that is not where the detector is actually located. So why does Snell's Law work at the interface between the air and glass?
I realize that blue light travels a different path. The problem is that the path it appears to take is the wrong one. In photos of prisms I have seen, the blue light has a longer path in the prism than the red light. But this makes no sense, as blue light has a higher frequency and should slow down more than red light when in glass.
The detector is placed inside the glass when you apply Fermat's Principle for a single interface. In case of prism, there are two interfaces and both source and detector in the same medium, outside the prism.
I can not follow you. The blue light has a longer path if its enters the prism at the same point with same angle of incidence as the red line. If you want the shortest time between two points for blue light you need to choose a different point where the blue light enters the prism.
Both the red and blue light enter the prism at the same point. Because of their differences in frequency, they end up at different points once they exit the prism. So far, so good. But the problem is that it appears the blue light takes a path where it spends more time in the prism and less time in the air. (Look at just about any photograph of a prism and you'll see what I mean.) From Fermat's Principle, this makes no sense.
When you apply Fermat principle yo compare various paths between two points, for the given monochromatic light.
It is completely irrelevant to compare the path of the blue light with that of the red.
And they have different end points anyway.
Given the entry point of the blue light and the exit point of the same, the path it takes through the prism takes the minimum time. You can put the detector somewhere outside the prism and the path taken by light through the prism between the source and detector will be the one predicted by Snell's law. And will have minimum time for that blue light. If now you want red light to go between the same points, it will have to take a different path. Not the one shown in a dispersion image.What if you had just monochromatic blue light? Would you still think that it should take a different path just because some other beam does something else?
I'm not sure it's that simple. First, let's consider the location where blue light appears on the screen. Let's call this point A. Then consider a point slightly above it, where "above" is defined as the vertical direction toward the apex of the triangular prism. Let's call this point B. According to QED, the probability of blue light reaching Point B should be higher than point A, because the paths that emanate from the source to Point B are generally shorter than from the source to Point A.
Or I am missing something obvious.
Yes, you are missing it again.
The other path is not going between the same two points.
The paths that matter in Fermat's principle or in QED are all BETWEEN THE SAME POINTS A and B (final and initial),
The fact that you can find another final point C which is closer to A than B is irrelevant from this point of view.
You can also find points very close to A for which the time is even shorter. Not even going through the prism. So what?
Nothing to do with path from A to B.
I need to step back and rethink this. Thanks for the input.
Related to Fermat's Principle, Snell's Law, and the Prism
What is Fermat's Principle?
Fermat's Principle is a principle in optics that states that the path taken by a ray of light between two points is the path that can be traversed in the least amount of time. This principle is often used to explain the law of reflection and refraction in optics.
What is Snell's Law?
Snell's Law is a law in optics that describes the relationship between the angle of incidence and the angle of refraction when a light ray passes through a boundary between two different media. It states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the velocities of light in the two media.
How does Snell's Law relate to Fermat's Principle?
Snell's Law is derived from Fermat's Principle. By considering all possible paths that a light ray can take between two points, Fermat's Principle shows that the path that takes the least amount of time is the one that satisfies Snell's Law.
What is a prism?
A prism is a transparent optical element with flat, polished surfaces that can refract and reflect light. It is often used in optics to separate white light into its component colors, or to deviate the path of light. Prisms are commonly made of glass or plastic and come in a variety of shapes and sizes.
How do prisms work?
Prisms work by refracting and reflecting light in a specific way. When light enters a prism, it is bent or refracted as it passes through the first surface. This refraction causes the different wavelengths of light to separate, resulting in the characteristic rainbow effect. The light is then reflected off the other surfaces within the prism, causing it to exit at a different angle than it entered. This allows prisms to manipulate the direction and properties of light.
