Fermi Energy and Conduction Electrons
In summary, we can calculate the number of conduction electrons per atom for a simple cubic metal with an electron density such that the Fermi energy just touches the edge of the first Brillouin zone using the equation N = (2/3)VF, where VF is the Fermi volume. This can be determined by finding the Fermi wavevector using the equation kF = (2mEf/ħ2)1/2 and substituting in the given values. The Fermi volume can then be calculated as 4π/a3, and finally, the total number of conduction electrons per atom is found to be 8π/3a3.
tommowg
The problem:
A simple cubic metal has an electron density such that the Fermi energy just touches the edge of the first Brillouin zone. Calculate the number of conduction electrons per atom for this condition to be fulfilled.
The attempt at a solution:
I know that the electron density for a simple cubic (SC) is n=1/a3
It says that the Fermi Energy just touches the surface of the 1st Brillouin Zone, well the 1st BZ occurs at k=+- π/a
I know that the Fermi Energy is given by: Ef = ħ2/2m * (3π2n)2/3 where n is the electron density again.
Now I can sub in the value of n for a simple cubic into this Fermi Energy equation, however I do not know how I can get the total number of conduction electrons from this information.
Any pointers in the right direction would be greatly appreciated.
Thanks,
Tom
Likes ElectricEel1
Solution:The total number of conduction electrons per atom is given by the equation: N = (2/3)VF, where VF is the Fermi volume. The Fermi volume is the volume of a sphere of radius equal to the Fermi wavevector. Using the above equation for the Fermi energy, we can calculate the Fermi wavevector as follows:kF = (2mEf/ħ2)1/2.Substituting in the values for the electron density, the Fermi energy and the Planck's constant, we have:kF = (2m(ħ2/2m * (3π2/a3)2/3)/ħ2)1/2 = (3π2/a3)1/3The Fermi volume is then just 4π/3 * (3π2/a3)3/3 = 4π/a3.Finally, substituting in the Fermi volume into the equation for the number of conduction electrons per atom, we have:N = (2/3)VF = (2/3)(4π/a3) = 8π/3a3 Hence, the total number of conduction electrons per atom is 8π/3a3.
Related to Fermi Energy and Conduction Electrons
What is Fermi Energy?
Fermi Energy is a concept in quantum mechanics that describes the highest energy state of electrons in a solid material at absolute zero temperature. It represents the energy level at which electrons have a 50% chance of being occupied in a solid material.
How is Fermi Energy related to conduction electrons?
Fermi Energy is closely related to conduction electrons in a solid material. Conduction electrons are the electrons that are able to move freely within a material, and their behavior is determined by the Fermi Energy level. The number of conduction electrons present and their movement is directly related to the Fermi Energy level.
What factors affect the Fermi Energy level?
The Fermi Energy level is affected by several factors, including the number of electrons in the material, the density of the material, and the strength of the interactions between the electrons and the material's atoms. Temperature also plays a role, as the Fermi Energy level can change with temperature.
How does the Fermi Energy level affect a material's conductivity?
The Fermi Energy level is directly related to a material's conductivity. A higher Fermi Energy level means that there are more conduction electrons available, leading to a higher conductivity. Conversely, a lower Fermi Energy level means less conduction electrons and lower conductivity.
What is the Fermi Distribution function and how does it relate to conduction electrons?
The Fermi Distribution function is a mathematical equation that describes the probability of finding an electron at a given energy level in a material. It is used to determine the number of conduction electrons that are present at a given temperature, and is directly related to the Fermi Energy level. The higher the Fermi Energy level, the more electrons will be present in the higher energy levels, as described by the Fermi Distribution function.
