Fermi Energy Calculations About Non Parabolic Dispersions
In summary: Non-quadratic dispersion is not a big deal as long as the system is isotropic. You don't need to integrate anything!All you need is a volume of the occupied state. For 3D case, the Fermi surface is a sphere whose volume is equal to ## V_F = \frac 4 3 \pi k^3_F##. If you have one electron per primitive unit cell, the Fermi sphere volume is 1/2 the volume of the first Brillouin zone. That gives you the Fermi momentum using elementary math. Then the Fermi energy can be easily obtained by inserting the Fermi momentum value into the dispersion formula. For the 2-D case
MartinCort
Greetings!
It is easy to understand that for a free electron, we can easily define the energy state density, and by doing the integration of the State density* Fermi-Dirac distribution we will be able to figure out the chemical potential at zero kelvin, which is the Fermi-Energy. Hence, we can define the Fermi Momentum correspondingly.
However, I feel rather struggling to define the fermi-momentum and Fermi energy for a non-parabolic dispersion.
Say, For example, A 2D system, I have a dispersion
E = A*k^2 +B*k^3
So k(E) will be in general complicated due to its cubic relations.
So If we still want to evaluate the Fermi Energy, Do still solve the integration
int _0 ^E_f state density*Fermi-Dirac Distribution dE = Number of Particles
to evaluate E_f?
And I think this integration will be very complicated.
Also, Under this circumstance, how do we define the Ferim-Momentum? Do we still solve
E_f = A k_F^2 + B k_F^3 to find k_F?
Thanks!
All you need is a volume of the occupied state. For 3D case, the Fermi surface is a sphere whose volume is equal to ## V_F = \frac 4 3 \pi k^3_F##. If you have one electron per primitive unit cell, the Fermi sphere volume is 1/2 the volume of the first Brillouin zone. That gives you the Fermi momentum using elementary math. Then the Fermi energy can be easily obtained by inserting the Fermi momentum value into the dispersion formula. For the 2-D case, the Fermi surface is a cylinder. Project that onto a plane and use planar geometry formulae.
Likes MartinCort
Thanks for your reply!
I think I somehow understand the idea of this. Would you like to recommend some literature on these materials?
I don't know anything specific about non-quadratic dispersion. But this should be intuitive. You fill up the band with all available electrons and as long as the dispersion is isotropic, the shape of the Fermi surface is spherical. From Born-van Karman boundary conditions, you will get that number of allowed states in each band is equal to 2 x number of Bravais cells in the crystal (2 because of spin degeneracy). This point is easy to see in the case of a cubic lattice.
If the bands are not symmetric, then the situation gets a bit more complicated. In simpler case, they could be ellipsoidal. These could happen in semi-metals when the bands are much less than 1/2 full. In general, the shape can be quite complex. See for example Ashcroft and Mermin for some examples. I did Fermi surface calculations for intercalated graphite and had to do numerical calculations.
Related to Fermi Energy Calculations About Non Parabolic Dispersions
1. What is Fermi energy and how is it calculated?
Fermi energy is the energy level at which the probability of finding an electron in a solid material is exactly 50%. It is calculated using the Fermi-Dirac distribution function, which takes into account the number of available energy states and the temperature of the material.
2. What is the significance of non-parabolic dispersions in Fermi energy calculations?
In some materials, the relationship between energy and momentum of an electron is not a perfect parabola. This is known as a non-parabolic dispersion. The presence of non-parabolic dispersions can significantly affect the calculation of Fermi energy, as it introduces additional complexities in determining the available energy states.
3. How do non-parabolic dispersions affect the density of states in a material?
Non-parabolic dispersions can lead to a non-uniform density of states in a material. This means that the number of available energy states at a particular energy level may not be the same throughout the material. This can impact the overall behavior and properties of the material, including its electrical conductivity.
4. How can the effective mass approximation be used in Fermi energy calculations for materials with non-parabolic dispersions?
The effective mass approximation is a simplification technique that allows for the calculation of Fermi energy in materials with non-parabolic dispersions. It involves approximating the non-parabolic dispersion as a parabolic one, using an effective mass value. This allows for a simpler calculation of the number of available energy states and the Fermi energy.
5. What are some experimental techniques used to measure Fermi energy in non-parabolic materials?
There are several experimental techniques used to measure Fermi energy in non-parabolic materials, including Angle-Resolved Photoemission Spectroscopy (ARPES), Scanning Tunneling Microscopy (STM), and Hall Effect measurements. These techniques involve directly measuring the energy and momentum of electrons in the material to determine the Fermi energy level.
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
