Fermi-Liquid - amount of electrons available for the interaction
In summary, the conversation discussed the concept of electron energy in relation to the Fermi energy. The speaker proposed using variables measured from the lowest valence electron level to better understand the shell argument. They also questioned the meaning of the fraction ##(\frac{\epsilon_1}{\epsilon_F})^2## and its relationship to electron-electron scattering. The expert summarizer explains that this fraction represents the fraction of total valence electrons that an electron of energy ##\epsilon_1## can interact with, and why this leads to less electron-electron scattering in crystalline conductors.
annaphys
69
I have attached the pages in Kittel's book (pages 417-420) regarding my question. My question is simply based off of the second to last photo, where e_f = 5*10^4 K and e_1 = 1K.
e_2<e_f and |e_2|<e_1. So how can (e_1/e_f)^2 be less than 1? The energy of the free flowing electron is assumed to be greater than e_f.
If you read the bottom of the first page, you will see that they are measuring ##\epsilon_1## and ##\epsilon_2## from ##\epsilon_F##, which they set to zero. Then on the third page they make a shell argument and use the actual value of ##\epsilon_F##.
Either way e_1 > e_f, though.
I can understand your difficulty, but ##\epsilon_1## is still a small quantity.
It would be more clear if he first introduced variables that are measured from the lowest valence electron level, such as ##\epsilon'_1##, ##\epsilon'_2##, and ##\epsilon_F##, which are all large quantities. Then he could introduce the electron energies measured from the Fermi energy: ##\epsilon_1=\epsilon'_1 - \epsilon_F##, and ##\epsilon_2 =\epsilon'_2 -\epsilon_F,##. That way the shell argument would still use the ratio ##\frac{\epsilon_1}{\epsilon_F}##, which you can see also equals ##\frac{\epsilon'_1-\epsilon_F}{\epsilon_F}##.
Ah, got it. So e_1 is just the small difference, and not the complete distance from the origin, right?
Another question, what does this fraction actually tell us? I would assume it would give us the amount of electrons that have enough energy to interact with e_1 to get then e_3 and e_4 outside the fermi sphere, but it is a number much smaller than one. Or is it simply the percentage of electrons that could allow for e_3 and e_4 to be outside of the sphere?
Yes, that is correct, but with a small caveat. This is in reciprocal space and thus the points are vectors, and we know energy is a scalar. For this model, the mapping is $$E=\frac{\hbar^2 k^2}{2m},$$ where ##k## is the radial distance from the origin.
I don't immediately see the difference between your two options. Upon a first reading, they both seem equivalent (except for a conversion from a fraction to a percentage) and basically correct . The final term ##(\frac{\epsilon_1}{\epsilon_F})^2## gives us an idea of the fraction of the total valence electrons that an electron of energy ##\epsilon_1## can interact with. Thus showing us why there isn't much electron-electron scattering in crystalline conductors.
Likes annaphys
Related to Fermi-Liquid - amount of electrons available for the interaction
1. How does the number of electrons affect the properties of a Fermi-Liquid?
The number of electrons available for interaction in a Fermi-Liquid is directly related to its properties. As the number of electrons increases, the Fermi energy also increases, leading to a higher energy state and a larger Fermi surface. This results in a higher conductivity and other electronic properties.
2. What is the relationship between the number of electrons and the Fermi energy in a Fermi-Liquid?
The Fermi energy is directly proportional to the number of electrons in a Fermi-Liquid. This means that as the number of electrons increases, so does the Fermi energy, resulting in a higher energy state and a larger Fermi surface.
3. How do changes in the number of electrons affect the interactions in a Fermi-Liquid?
The number of electrons available for interaction in a Fermi-Liquid is a crucial factor in determining its properties. Changes in the number of electrons can lead to changes in the Fermi energy and Fermi surface, ultimately affecting the electronic interactions and properties of the Fermi-Liquid.
4. Is the number of electrons in a Fermi-Liquid constant or can it change?
The number of electrons in a Fermi-Liquid can change depending on external factors such as temperature, pressure, and magnetic field. These changes can affect the Fermi energy and Fermi surface, ultimately altering the properties of the Fermi-Liquid.
5. How is the number of electrons in a Fermi-Liquid determined experimentally?
The number of electrons in a Fermi-Liquid can be determined experimentally by measuring its electrical conductivity and specific heat. These properties are related to the Fermi energy and can provide information about the number of electrons available for interaction in the Fermi-Liquid.
  • Atomic and Condensed Matter
9K
