Ferrofluids, gravity, Pascal and Arquimedes.
In summary, the conversation discusses a proposed device that uses ferrofluid and a magnet to create a continuous motion loop. The device is explained through diagrams and the conversation delves into the physics behind it. It is ultimately concluded that the device will not work as there is no net force on the loop of buoys and the buoys will not receive any energy. The conversation also briefly touches on the use of magnets and solenoids in energy terms.
cala
194
Long time since my last time.
I've found a system that seems to work in a kind of perpetual motion, BUT please, do not take it as SPAM message, and take the time to analyze the system.
Imagine a container made of two cilinders communicated with a tube. We fill this container with ferrofluid with the same density than water (for example). Now the gravity and the pressure will be in equilibrium, so the ferrofluid is equally high in both cilinders.
Now, we put a big magnet in one of the sides, so the ferrofluid level in one side goes higher than on the other side.
Now gravity, pressure and magnetic field forces are in equilibrium for the fluid.
Now, introduce a chain of buoys (every buoy weights 1Kg and has 2 Litres of volume).
Then when in ferrofluid, buoys will float, and in air, they will go down by gravity.
For the buoys, the effects of gravity and floatation will be different on one cilinder or another (force direction).
If we have different ferrofluid levels on the cilinders, the buoys will be affected in a way to rotate the chain in a continuous way!
The ferrofluid is affected by 3 fields (gravity, pressure and magnetic forces), but the buoys are only affected by gravity and floatation... so they see an imbalance, and feels different forces on one cilinder or another.
I post a drawing of the system, and some other drawings explaining how it would work.
What is wrong in the device (if there is something wrong)?
Could you explain why the buoys should not run continuously?
The hard answer is: why don't you build this? If you're right then you won't need to pay for electricity again, if you're wrong then you eventually mightn't be able to afford electricity again, either way the issue is settled to my satisfaction. :devil:
The correct answer is: because you're not putting energy in (to replace the energy inevitably lost from turbulance and friction), it will slow down and stop.
Maybe the answer you're after is: The magnetic attraction counters the gravitational pull on one side, decreasing the effective weight-density of the fluid on the left side (imagine a u-shaped tube with water on one side, oil on the other). Thus, there is a smaller buoyancy force on each ball submersed on the left side than on the one submersed on the right (one on the right displaces a greater effective-weight of ferrofluid), and since the effective-weight of the fluid on each side is in equilibrium..
Thank you Cesiumfrog.
Do you think the magnetic force will affect the density of the ferrofluid so much?
I mean, for example the water is capable of supporting a lot of pressure without a change in density.
Will the attraction of the ferrofluid by magnetic field change its structure in such a way?
The density of "effective-weight" (which I've conveniently defined such that it is trivially so), not the density of mass.
Btw, it is Archimedes.
If there is no change in density, and the fluid is in equilibrium (whatever the forces acting on that fluid), then the buoys will rise by Arquimedes.
Usually, we have only gravity or weight, and this force is counter-acted by pressure, until equilibrium in the fluid.
Now we have gravity, magnetic force, and pressure. Now the fluid gets another equilibrium position, but the density does not change.
If you replace the material of the fluid with material density of the buoys, you'll have a force acting upwards, as usual.
Is there something wrong? The force is not as expected? Why not?
More configurations for the device.
You can use the magnetic field to push or pull the ferrofluid. Also, you can use the ferrofluid as a magnetic "cork" or "clot" that maintains a pressure difference using magnetic forces. The buoys can pass through the ferrofluid.
The buoys get their energy from somewhere, in this case from the permanent magnet used to start the loop. Eventually, this will lose its magnetism as more and more energy is given to the buoys, which of course lose energy contnuously as heat through friction etc, etc...
Simply replace the permanent magent in your setup with a magnetic solenoid and you can see that energy would be lost by the circuit as it moved the loop.
However this is a very intruiging engine design in and of itself.
Working with magnets is not the same than working with solenoids in energy terms, under some circunstances.
Try to replace (for instance) a magnet placed on your fridge door, and do the same thing with a solenoid. You'll waste a lot of electric energy using the solenoid, but the magnet will defy gravity (almost) forever, for free.
I think you've fallen for a red herring. A superconducting solenoid should retain its magnetisation, without wasting electrical energy, for just as long as a good permanent magnet - the internal resistance of a cheap solenoid is not relevant here.
The mistake here is that the buoys will not get energy. The device won't fail to run continuously; it will fail to run, period. This is because there is no net force on the loop of buoys.
One shortcut to see this is to imagine smoothly deforming this loop-of-beads shape into a continuous donut shape. The fluid will not make this torus turn, because doing so will not alter the distribution of the fluid (neither bringing the fluid on the left slightly closer to the magnet nor the fluid on the right slightly closer to the bottom).
Alternatively you can explicity calculate the forces on each individual buoy (after which you'll understand better my earlier posts), and notice they add to give zero.
sorry. If you talked about superconductors, then you're right.
But anyway, I don't understand what do you mean with your last sentence.
FAQ: Ferrofluids, gravity, Pascal and Arquimedes.
1. What is a ferrofluid?
A ferrofluid is a liquid that becomes magnetized in the presence of a magnetic field. It is typically made up of tiny magnetic particles suspended in a carrier fluid, such as oil or water.
2. How does gravity affect ferrofluids?
Gravity has a negligible effect on ferrofluids due to their low density and the fact that they are typically used in small quantities. However, in very strong magnetic fields, the weight of the ferrofluid can cause it to settle or rise, depending on its alignment with the field.
3. What is Pascal's principle and how does it relate to ferrofluids?
Pascal's principle states that pressure applied to a confined fluid is transmitted equally in all directions. In the context of ferrofluids, this means that when a magnetic field is applied, the particles will align and create pressure that is transmitted throughout the fluid, causing it to move or change shape.
4. How does Arquimedes' principle apply to ferrofluids?
Arquimedes' principle states that the buoyant force on an object immersed in a fluid is equal to the weight of the fluid that the object displaces. In the case of ferrofluids, the magnetic particles tend to cluster together, resulting in a decrease in the overall density of the fluid and causing it to float on top of other non-magnetic liquids.
5. What are some common uses of ferrofluids?
Ferrofluids have a wide range of applications, including use in loudspeakers, computer hard drives, and biomedical devices. They are also used in engineering and scientific research for their unique properties in manipulating and controlling fluids. In addition, artists and designers have also utilized ferrofluids in various creative projects.
