kupid
- 34
I was trying to picture the third derivative of something
Then i came across these ...
What does displacement mean?
The variable x is often used to represent the horizontal position. The variable y is often used to represent the vertical position
Displacement=Delta x=xf-x0xf refers to the value of the final position.
x0 refers to the value of the initial position
Delta x is the symbol used to represent displacement
Distance = Speed x Time
Time = Distance/Speed
Speed= Distance/Time
Average velocity is defined to be the change in position divided by the time of travel
Acceleration is defined to be the rate of change of the velocity
Jerk is defined to be the rate of change of acceleration
What is the term used for the third derivative of position?
It is well known that the first derivative of position (symbol x) with respect to time is velocity (symbol v) and the
second is acceleration (symbol a). It is a little less well known that the third derivative, i.e. the rate of change of
acceleration, is technically known as jerk (symbol j). Jerk is a vector but may also be used loosely as a scalar quantity
because there is not a separate term for the magnitude of jerk analogous to speed for magnitude of velocity.
In the UK jolt has sometimes been used instead of jerk and may be equally acceptable
The more derivative you take the steeper the slope gets ?
Also , when you integrate a " jerk " , You get acceleration ?
Integrate acceleration to get velocity ?
Integrate velocity to get displacement ?So , when a differential equation contains the third derivative of something like that or a " jerk ", we can integrate it to find the original displacement function ?
I was not able to find an example for a third order differential equation containing a "jerk"
This is the only example i got ...
Looks like something interesting to follow .
Separation of variables is a technique commonly used to solve first-order ordinary differential equations. It is so-called because we rearrange the equation to be solved such that all terms involving the dependent variable appear on one side of the equation, and all terms involving the independent variable appear on the other. Integration completes the solution. Not all first-order equations can be rearranged in this way so this technique is not always appropriate. Further, it is not always possible to perform the integration even if the variables are separable. In this Section you will learn how to decide whether the method is appropriate, and how to apply it in such cases
http://www.personal.soton.ac.uk/jav/soton/HELM/workbooks/workbook_19/19_2_first_order_odes.pdf
https://www.khanacademy.org/math/calculus-home
https://www.khanacademy.org/math/differential-equationsPlease help ...
![Eng_Math_Differential_Eq_Terminology_01.png](https://s8.postimg.org/sl7c1am45/Eng_Math_Differential_Eq_Terminology_01.png)
![version_2.png](https://s8.postimg.org/snr7o4prp/version_2.png)
![nap-2-768x194.png](https://s8.postimg.org/blydm1awl/nap-2-768x194.png)
