Few noob questions and numerical methods help....
In summary, we discussed the different types of equations and numerical methods used to solve them. Degree names and examples of polynomials were provided, along with examples of linear and non-linear equations. We also talked about the use of numerical methods to solve systems of equations, including both linear and non-linear systems. Finally, it was mentioned that there are many different numerical methods for different types of problems, and that further study may be beneficial to fully understand them.
awholenumber
200
i was trying to work with few problems for my computer oriented numerical method ...which i had in college ...
i am not in college anymore ... but i failed that subject ... i am trying to improve this maths field as much as i possibly can , because its a difficult subject for me ...
let met start with a few things i am familiar with ...
When we know the degree we can also give the polynomial a name:
Degree Name Example
0 Constant 7
1 Linear 4x+3
2 Quadratic x2−3x+2
3 Cubic 2x3−5x2
4 Quartic x4+3x−2
then we have simulaneous equations ...which looks like these ...
x+2y-3z=10
2x-3y-4z=1
y-3x+z=-8
i think these two numerical methods can be applied to it if you have to deal with equations like these ...
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/12-LinEqs_Direct.pdf[/PLAIN]
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/13-LinEqs_Indirect.pdf
now could somebody please tell me to what sort of equations do i apply the rest of the three methods mentioned below ?
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/14-NonlinearEquations_1_FixedPoint.pdf
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/14-NonlinearEquations_2_Bisection.pdf
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/14-NonlinearEquations_3_Newton.pdf[/PLAIN]
are those methods for ??
transcendental functions ??
differentiation ?
intergration ??
differential equation ?
Mathematics news on Phys.org
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/14-NonlinearEquations_3_Newton.pdfare those methods for ??
differentiation ?
intergration ??
These methods are for determining solutions of (systems of) nonlinear equations. The equations may involve transcendental functions, but for example also higher order polynomials. (Note that the system of three equations that you wrote down above consists of linear equations only.) Newton's method is a good default choice, but there are caveats. Nonlinear root finders may also occur as part of the numerical solution of other problems, for example involving differential equations.
http://www.ce.utexas.edu/prof/mckinney/ce311k/Overheads/14-NonlinearEquations_3_Newton.pdfso these three methods can be used to solve ...polynomials with degree greater than one , which is not linear ...and when the usual factorisation methods won't work ? for my understandings sake ...
Degree Name Example
0 Constant 7
1 Linear 4x+3
2 Quadratic x2−3x+2
3 Cubic 2x3−5x2
4 Quartic x4+3x−2
also to ...
differentiation
intergration
for some reason .. i thought i could narrow it down to few types of equations and its numerical methods ...
but this subject again .. even though its just the three methods ... is still confusing ...
so this
fixed point iteration
will work for ...
non linear higher order polynomials ...??
differentiation
intergration
differential equation ...
bisection method
works for ...non linear higher order polynomials ...??
differentiation
intergration
Newtons method
works for ...
differentiation
intergration
Degree Name Example
0 Constant 7
1 Linear 4x+3
2 Quadratic x2−3x+2
3 Cubic 2x3−5x2
4 Quartic x4+3x−2
These are all polynomial expressions, for example we write ## x^2 - 3x + 2 = 0 ## and call it a second degree polynomial equation, or a quadratic equation. First degree polynomial equations are also called linear equations.
rosekidcute said:
then we have simulaneous equations ...which looks like these ...x+2y-3z=10
2x-3y-4z=1
y-3x+z=-8
Note that these are all linear equations, and together we call them a system of linear equations, or a linear system.
Yes, as the titles imply these methods are used to find numerical solutions to linear systems.
rosekidcute said:
Again as the titles imply these methods are used to find numerical solutions to non-linear systems. Quadratic systems e.g. ## x = 3t; y = 10t - \frac {9.8}2 t^2; y = 0 ## are non-linear, and so is any system that contains terms other than a variable multiplied by a constant e.g. ## x = \cos t; y = \sin t; t = 2 ##.
differentiation ?
intergration ??
No, they are all for solving systems of equations i.e. working out what values of the variables solve all the constraints. (Numerical) methods for differentiation and integration solve different classes of problems, although if you look at Newton's method in your last link, this can also be used for solving differential equations.
Likes LeoPedranjo
rosekidcute said:
for some reason .. i thought i could narrow it down to few types of equations and its numerical methods ...but this subject again .. even though its just the three methods ... is still confusing ...
There are many numerical methods for many different problems. Even when we restrict ourselves to systems of linear equations, there are various different methods that have different benefits and drawbacks, depending on the structure of the particular problem at hand.
I think you may benefit from a well-structured introductory book with many examples. Would you like that? I have my own favorites on numerical analysis, but maybe in this case it is better when others make some recommendations first. Or did your course already come with prescribed literature?
thanks for the detailed explanation MrAnchovyKrylov , this basically means i have to find atleast one proper simple example ... for
non linear higher order polynomials ...?? fixed point , bisection , Newton
transcendental functions ?? fixed point , bisection , Newton
differentiation ? fixed point , bisection ,Newton
intergration ?? fixed point , bisection , Newton
differential equation ... ?? fixed point , bisection , Newton
to apply these methods to ...
that makes it atleast 15 problems to look into ... :nb)
i myself have gone through many books roughly ... which had algorithms in it in programming languages ...
most of it were a bit hard to follow...
could you suggest me some simple books ??
I enjoy https://www.amazon.com/dp/0471624896/?tag=pfamazon01-20 by Atkinson, but I'm not sure whether the level is appropriate for you. It does not give codes, but presents the basic algorithms clearly enough so you can do your own coding in the language of your choice. Atkinson, together with Han, has also written Elementary Numerical Analysis, but I don't know this book.
There is also the book by Cleve Moler, Numerical Computing with MATLAB, which is available for free. It is much more applied than Atkinson's book and is tied to the MATLAB environment, which is a good but non-free software package suitable for the exploration of numerical methods. Octave is a free alternative, but I don't know how well it goes together with Moler's book.
Many other textbooks exist, so I also encourage you to browse an online bookstore and have a look at the reviews. It depends a lot on your personal style.
thanks for the books suggestion ... i will try to buy the books from some online store ...
let me see if i can apply the
tonon linear higher order polynomials
differentiation
intergration
differential equation ...to begin with ...
Related to Few noob questions and numerical methods help....
1. What are some common numerical methods used in scientific research?
Some commonly used numerical methods in scientific research include finite element analysis, Monte Carlo simulation, and numerical integration. These methods are used to solve complex mathematical problems and analyze data in various fields such as physics, engineering, and economics.
2. How do numerical methods differ from analytical methods?
Numerical methods involve using algorithms and computer programs to solve mathematical problems, while analytical methods involve finding exact solutions using mathematical equations. Numerical methods are often used when analytical solutions are difficult or impossible to obtain.
3. What are some potential sources of error in numerical methods?
Some potential sources of error in numerical methods include round-off error, truncation error, and convergence error. These errors can arise due to limitations in computer precision and approximation errors in the numerical algorithms.
4. How can I determine the accuracy of a numerical method?
The accuracy of a numerical method can be determined by comparing the results obtained from the method to known analytical solutions or experimental data. The smaller the difference between the two, the more accurate the numerical method is.
5. Can numerical methods be used to solve all types of mathematical problems?
No, numerical methods are not suitable for solving all types of mathematical problems. They are most effective for solving problems that involve complex equations or data sets that cannot be solved using analytical methods. However, numerical methods also have limitations and may not always produce accurate results.
  • Differential Equations
  • Beyond the Standard Models
