Feynman diagrams and momentum conservation
In summary, Feynman diagrams can be expressed in either position or momentum representation. The 4-momentum is conserved at vertices in both cases, but it is more easily visible in the momentum representation where each line has a definite momentum assigned to it. In the position representation, the concept of momentum does not make sense, but the overall interaction still conserves momentum.
johne1618
371
I understand that Feynman diagrams can be expressed either in the position or momentum representation.
Is the 4-momentum conserved at the vertices in each case or only in the momentum representation?
4-momentum is conserved in any interaction, regardless of how you write it down. However, if the Feynman diagrams are expressed in position space, that's not immediately apparent, because you don't assign definite momenta to each line. In momentum space the lines all have momenta assigned to them, so you can add them up at each vertex and see that they always sum to zero, but in position space you have to take a Fourier transform to see that.
So I guess the answer to your question is that four-momentum conservation at vertices doesn't make sense in the position representation, because talking about momentum at all doesn't make sense in the position representation. But the math will work out either way to show that the overall interaction conserves momentum.
Likes 1 person
Related to Feynman diagrams and momentum conservation
What are Feynman diagrams?
Feynman diagrams are graphical representations of particle interactions in quantum field theory. They were developed by physicist Richard Feynman and are used to calculate the probability amplitudes for different particle interactions.
Why are Feynman diagrams important?
Feynman diagrams are important because they provide a visual representation of complex particle interactions, making it easier to understand and calculate the probabilities of these interactions. They also help in understanding the fundamental principles of quantum mechanics and the conservation laws that govern particle interactions.
How do Feynman diagrams conserve momentum?
Feynman diagrams conserve momentum by representing the momentum of particles as lines in the diagram. The lines can bend and split, but the total momentum of all the particles in the diagram must be conserved. This is in accordance with the law of conservation of momentum, which states that the total momentum of a closed system remains constant.
Can Feynman diagrams be used to calculate the probability of any particle interaction?
Yes, Feynman diagrams can be used to calculate the probability of any particle interaction, as long as the interaction obeys the laws of quantum mechanics and can be represented by a Feynman diagram.
Are there any limitations to using Feynman diagrams?
While Feynman diagrams are a powerful tool in understanding and calculating particle interactions, they have their limitations. They do not account for all possible interactions and cannot be used to calculate the exact values of particle properties. They also become increasingly complex when dealing with more than two particles, making calculations more difficult.
