Feynman Hellman Theorem: dependence of E on [itex]\ell[/itex] Hydrogen
The Feynman-Hellman theorem expresses the relationship between the energy E and the parameter λ in quantum systems, specifically for hydrogen. The discussion highlights the challenge of interpreting the derivative ∂n/∂ℓ, as traditionally, n is considered independent of ℓ due to the multiple possible n values for a given ℓ. However, if the eigenfunctions are restricted, n can be treated as a function of ℓ, leading to a clearer relationship where n = ℓ + c. The calculation of expectation values, such as ⟨1/r²⟩, becomes complex when considering non-integer values of ℓ, complicating the application of the theorem. Ultimately, the discussion emphasizes the need for careful consideration of eigenfunction dependencies in quantum mechanics.
MisterX
The theorem states
\frac{\partial E}{\partial \lambda} = \langle \psi \mid \frac{\partial H}{\partial \lambda} \mid \psi \rangle
Where \mid \psi \rangle is an eigenket of H.
An example (given on Wikipedia) is to find \langle \psi \mid \frac{1}{r^2} \mid \psi \rangle for a Hydrogen eigenstate using this method with \lambda = \ell. It is straightforward to differentiate H with respect to \ell. However the common expression for energy only depends n. In the Wikipedia article there is
\frac{\partial E}{\partial \ell} = \frac{\partial E}{\partial n}\frac{\partial n}{\partial \ell}.
But, how do we make sense of \frac{\partial n}{\partial \ell}. Don't we normally (when \ell is not varied continuously) think of n as being somewhat independent of \ell?
Could you provide a link to the wikipedia article?
Don't we normally (when ℓ is not varied continuously) think of n as being somewhat independent of ℓ?
Yes, in the basic theory of hydrogen atom, we usually do not think of ##n## as of a function of ##l##, because usually we consider all possible combinations of ##n,l##, and for given ##l##, we have many possible ##n = l +1, l+ 2, ...##, so obviusly ##n## is not a function of ##l##.
However, if we restrict the set of the eigenfunctions, we can regard ##n## as a function of ##l##.
In the mentioned application of the Hellmann-Feynman theorem, the argument runs probably as follows.
We have special operator ##\hat{H}_l## which depends on ##l## only. From this it follows that each its eigenfunctions ##\phi_{nl}## is a function of ##l##. The number ##n## with possible values ## l+1, l+2, ...## is introduced as a whole number indexing various different eigenfunctions for the given ##l##.
In the calculation of ##\langle \frac{1}{r^2}\rangle## for ##\phi_{nl}##, we deal with one eigenfunction ##\phi_{nl}## for given numbers ##n,l##. Given these two numbers, we can find exactly one natural number ##c > 0## such that ##n = l + c##. Now, from the set of all eigenfunctions ##\phi_{n'l'}##, let us choose the subset ##\phi_{l'+c,l'}##, in other words, we have ##n' = l'+ c##. Then we have ##\partial n'/\partial l' =1##.
Likes MisterX
Another possibility would be that the degeneracy of eigenvalues with different l but same n is broken once non-integer values of l are considered. It is necessary to consider non-integer l to be able to take the derivatives. I fear a clean calculation of the expectation value of 1/r^2 via the HF theorem is much more complicated than a direct calculation.
In Wikipedia there is also a reference for this problem. Maybe you can check it out.
Edit: Thinking about it, this will probably amount to the same what Jano L. said, i.e. dn/dl=1 as n=l+c also holds for non-integer values of l.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
