Feynman rules for Entangled photons
In summary, the Feynman rules for entangled photons provide a framework for calculating the probabilities and amplitudes of various quantum processes involving entangled states. These rules utilize the principles of quantum mechanics, including superposition and interference, to describe how entangled photons interact and behave in experiments. By applying these rules, physicists can analyze phenomena such as quantum entanglement, Bell's theorem, and the behavior of photons in quantum optics, ultimately aiding in the understanding of fundamental quantum mechanics and the development of quantum technologies.
Quant
44
TL;DR Summary
How is Feynman path integral constructed for a photon of a SPDC entangled pair.
Should we add to the usual amplitude (sum over all extremal paths of this photon) also the amplitude of the other photon of the pair?
The actual Feynman path integral is a weighted sum over all paths in a configuration space. The extremal states are selected by the path integral essentially because of stationary phase so your question is difficult to decipher because of the confused preamble.
Amplitude for what? In order to even do a path integral, you need to define the endpoints.
I guess we are talking about nonrelativistic QM, not about QFT. If you have two particles, each moving in 3 dimensions, you can think of it as one particle in 6 dimensions. Write the path integral by pretending it's one particle in 6 dimensions, and you will get the right result.
Of course from a to b.
Surely. a and b.
So you think the amplitude ofar the other particle must be added?
So you think the amplitude of the other particle should be added?
Suppose photon 1 of the twin pair goes to a beam splitter BS1 and photon 2 can go in the other port of the BS1 but it doesn't (it goes tru a BS2 which outputs are on BS1 and on a point c and is registered after a while in point c. Will photon 1 interfere on the BS1 with the "empty" wavefunction of the photon 2? If we add the amplitude pretending photon 1 is one particle in 6 dimensions it will have to interfere?
Also if photon 2 is registered prior to photon 1 in c and one expects collapse of its part of the wavefunction the possible path to BS for photon 1 does not seem to stop existing and photon1 must interfere on BS1.
In position space? Usually this formulation is used in momentum space.
Let me ask you - have you ever done a calculation this way? Is A (i.e. graduate level) the level you want your answer?
Likes gentzen
Why is Demystifier talking about configuration space then?
Likes gentzen
No, both photons together are "one particle" in 6 dimensions.
Quant said:
Surely. a and b.
What are a and b? You're assuming it's obvious. It's not. Once you answer what a and b actually are, you will know the answer to the question you posed in your OP.
That's not what @Demystifier said. What he said is that you need to first decide what you are computing the path integral for. Are you computing it for just one photon? Or for the system consisting of both of them?
Different answers to that question will result in different path integrals--and different answers to my question, what are a and b?
I don't know Feynman reformulation of QM about entangled pair. For single particle it is 100 % sure that we consider all paths between any two point (usually emitter at a and detector at b) and as the path is surely function of xyz one is in (configuration) space. I don't see anywhere momenta here. They doesn't matter at all. I've not done it explicitly but I've seen how is done.
And Demystifier says just this e.g. to use x1y1z1x2y2z2 E.g. configuration space.
I would be glad if he can answer that?
Is the Feynman integral in configuration space or in momentum space?
I understand this as one particle going two distant paths at the same time together.(e.g photon1 goes also the paths of photon2 which would be otherwise inaccessible for it?
@Demystifier described how this works in configuration space in post #4. See further comments below.
You can do it either way. Doing it in momentum space is much more common because incoming and outgoing momenta and energies are what actual experiments usually measure.
No. The configuration space for two particles, at least in the approximation @Demystifier described, is 6-dimensional: you have 3 position coordinates for particle 1 and three position coordinates for particle 2. So every point in the 6-dimensional configuration space represents particle 1 being at some position ##x_1##, ##y_1##, ##z_1##, and particle 2 being at some position ##x_2##, ##y_2##, ##z_2##.
So if you specify a start and end point for particle 1, and a start and end point for particle 2, you have start and end points for a path integral in the 6-dimensional configuration space. A path in the 6-dimensional configuration space is then equivalent to specifying a path for photon 1 and a path for photon 2.
Entangled photons do not produce traditional interference patterns in the manner you imagine. It’s not possible to explain it without a sufficiently detailed example, but the short story is that such photons do not self interfere and they don’t interfere with each other. However, 2 different entangled photons can interfere if indistinguishable. The Hong-Ou-Mandel effect is an example of that.
There is also no sense in talking about collapse of one vs collapse of the other. There is no scenario in which you can precisely say “one is collapsed, the other is not” and back that up with experimental differences. Time sequence is generally not a factor, and you are free to attempt to interpret it as you like.
That's wrong. Have you ever seen any equation in quantum mechanics for a system with two or more particles?
Likes gentzen, hutchphd and Vanadium 50
Maybe. But in experiment like DSE and MZI one measure the positions by positioned photon detectors. I am interested in only these experiments.
The problem here is strictly in Feynman paths not any other formulations. So I want to know just the amplitude of photon 1 from 'a' (birth of twins) to 'b' (detector). Photon 2 starts also from 'a' but can go to either 'b' or 'c' tru point 'd' (BS 50/50). If it goes to c (is registered there) does the amplitude of photon 1 also include the path where photon 2 goes 'adc'? I hope of an explicit answer.
When you have two entangled photons, there is no such thing as amplitude of photon 1. There is only an amplitude for both photons together.
Likes gentzen, PeterDonis, hutchphd and 2 others
And when the one photon (2) is registered in the detector (c) there would be just one photon (1). Does it has no amplitude? Can Feynman rules not say where we would chance to detect it?
Thanks Dr. Chinese.
Are you saying we can not destroy photon 1 of a entangled pair and leave photon 2 on an infinite journey in all inertial reference frames?
Where it should be an unentangled 'normal' photon which will begin to interfere with itself?
Yes, but in that case you are no longer considering two photons. And by the way, the expression "Feynman rules" means something entirely different, it's related to perturbative Feynman diagrams, not to Feynman path integrals.
Likes gentzen
Quant said:
Thanks Dr. Chinese.
An entangled photon will behave as what you call “normal” and will produce the usual interference pattern if you place a single slit in front of the double slits. That creates a coherent state and stops the entanglement for that photon. But… don’t think that means the other photon will evidence any change. It won’t. If it did, you could perform FTL signaling. Right?
This is why I asked him Saturday if he had ever done such a calculation and if he really wanted a graduate-level answer. Based on his writings, I believe he has not done such a calculation, and that he is ill-served by insisting on a graduate-level answer.
Likes Demystifier
There is not such thing as Feynman rules. What I use is just a working slang. I could say the 'rules for constructing the path integrals' but it's too long don't you think?
There are the Feynman path integral (which I know exactly how to calculate in one particle case) and there are 2 rules for constructing them which you must know (x for successive events and + for independent events)
There are completely different things Feynman diagrams. There also rules how to put a math expression for each diagram. The rules also belong to Feynman.
So after all I pose a really simple question. E.g. must the path integral for photon 1 from a to b include also the path which photon 2 can take 'adb' but the real photon 2 is found in point c. If you think it is B level answer it in B level. I don't care.
  • Sad
Likes weirdoguy
Why should we put a single slit before DS? If the (say idler) photons of entangled pairs do not make DS interference pattern one will disentangle the signal photons and the idler must start to do DS interference. One could send FTL easy then. Consider 10 groups of 1000 idler photons. One can disentangle number 1, 5, 9 of these groups and this is a message.
  • #31
What? Of course there are. And if you don't think there are, why did you put them in the thread title?
  • #32
Yes, there are. They just don't mean what your thread title implies that they mean, as @Demystifier pointed out in post #26.
We don't. That's the point. We think the questions you are asking are A level, but your level of knowledge is not. Your level of knowledge appears to be B level, and there is no useful answer we can give you at B level. The only useful feedback we can give you at B level is to increase your level of knowledge. Study textbooks that deal with path integrals for multiple-particle systems. Then you will be able to frame questions that we can usefully answer.
Thread closed.
Likes Demystifier
FAQ: Feynman rules for Entangled photons
What are Feynman rules in the context of quantum mechanics?
Feynman rules are a set of prescriptions used in quantum field theory to calculate the probability amplitudes of various physical processes. They provide a systematic way to translate the interactions and particles in a quantum system into mathematical expressions, typically represented by Feynman diagrams. These rules help physicists compute scattering amplitudes and other observables by specifying how to account for particles, their interactions, and the contributions of virtual particles.
How do Feynman rules apply to entangled photons?
In the case of entangled photons, Feynman rules can be used to analyze processes involving the creation, manipulation, and detection of entangled states. The rules help in calculating the probability amplitudes for various outcomes in experiments involving entangled photons, such as those used in quantum optics and quantum information science. The entanglement can lead to non-classical correlations between the photons, which can be represented in Feynman diagrams, taking into account their quantum states and interactions.
What are the key features of entangled photon states?
Entangled photon states exhibit correlations in their properties, such as polarization, phase, or momentum, that cannot be explained by classical physics. Key features include the ability to produce measurements that are strongly correlated regardless of the distance between the photons, which is a hallmark of quantum entanglement. These states often arise in processes like spontaneous parametric down-conversion, where a single photon is converted into a pair of entangled photons.
How can Feynman diagrams be used to visualize entangled photon interactions?
Feynman diagrams provide a graphical representation of particle interactions, including those involving entangled photons. In these diagrams, the lines represent the paths of the photons, while vertices indicate points of interaction, such as the creation or annihilation of particles. By using these diagrams, physicists can visualize complex processes, such as the interference effects and correlations arising from entangled photon states, making it easier to understand and compute the associated probabilities.
What experiments utilize Feynman rules for entangled photons?
Experiments that utilize Feynman rules for entangled photons include tests of Bell's theorem, quantum cryptography protocols, and quantum teleportation. In these experiments, the principles of quantum mechanics and entanglement are explored, often using Feynman rules to calculate the expected outcomes and analyze the results. Such experiments have significant implications for our understanding of quantum mechanics and the development of quantum technologies.
