Feynman rules on a ##\phi^3, \phi^4## theory
In summary, the weakly coupled theory given by the Lagrange density can be approached using various methods such as the S-matrix expansion and the path integral formalism. The Feynman rules for this theory involve two types of interaction vertices, as described in the post.
JD_PM
1,131
158
TL;DR Summary
I want to understand how Feynman rules look in a weakly coupled theory that not only has an interaction term ##\phi^4## term but also a ##\phi^3## term (please see the Lagrangian density below). To do so I am comparing it to QED's Feynman rules (which I studied from Mandl & Shaw's second edition, section 7.3).
The weakly coupled theory is given by the Lagrange density$$\mathcal{L}=\mathcal{L}_0 + \mathcal{L}_I=\frac 1 2 \partial_{\mu} \phi \partial^{\mu} \phi - \frac{m^2}{2} \phi^2 - \frac{\lambda_3}{3!} \phi^3 - \frac{\lambda_4}{4!} \phi^4 \tag{1}$$
Where
\begin{equation*}
\mathcal{L}_0 = \frac 1 2 \partial_{\mu} \phi \partial^{\mu} \phi - \frac{m^2}{2} \phi^2
\end{equation*}
\begin{equation*}
\mathcal{L}_I = - \frac{\lambda_3}{3!} \phi^3 - \frac{\lambda_4}{4!} \phi^4
\end{equation*}
My aim is to derive what are the Feynman rules for such a theory.
I could go for the brute approach; evaluating the S-matrix expansion explicitly (where I use :: for normal ordering)
\begin{align*}
S_{fi}&=\langle f | T \left\{ \exp\left( i\frac{\lambda_3}{3!}\int d^4 x :\phi (x)\phi (x)\phi (x) : + i\frac{\lambda_4}{4!}\int d^4 x :\phi (x)\phi (x)\phi (x)\phi (x) : \right) \right\}| i \rangle \\
&= \langle f | i \rangle + i \frac{\lambda_3}{3!} \int d^4 x \langle f| :\phi (x)\phi (x)\phi (x): |i \rangle + i\frac{\lambda_4}{4!} \int d^4 x \langle f | :\phi (x)\phi (x)\phi (x)\phi (x) : | i \rangle \\
&+ \left(\frac{i\lambda_3}{3!}\right)^2\frac{1}{2!} \int d^4 x d^4 y \langle f| T\left\{ : \phi (x)\phi (x)\phi (x) :: \phi (y)\phi (y)\phi (y) : \right\}|i\rangle \\
&+ \left(\frac{i\lambda_4}{4!}\right)^2\frac{1}{2!} \int d^4 x d^4 y \langle f| T\left\{ : \phi (x)\phi (x)\phi (x)\phi (x) :: \phi (y)\phi (y)\phi (y)\phi (y) \right\}: |i\rangle + \mathcal{O}(\lambda_3^4, \lambda_4^4)
\end{align*}
Before evaluating the 4 terms above, let me first make a guess
As building blocks for Feynman diagrams, we will have 2 types of interaction vertices
Where I followed the convention of writing mesons with dotted lines.
The left diagram comes from ##i \frac{\lambda_3}{3!} \int d^4 x \langle f| :\phi (x)\phi (x)\phi (x): |i \rangle##. The right diagram comes from ##i\frac{\lambda_4}{4!} \int d^4 x \langle f | :\phi (x)\phi (x)\phi (x)\phi (x) : | i \rangle##
If we were to evaluate ##\left(\frac{i\lambda_3}{3!}\right)^2\frac{1}{2!} \int d^4 x d^4 y \langle f| T\left\{ : \phi (x)\phi (x)\phi (x) :: \phi (y)\phi (y)\phi (y) : \right\}|i\rangle## we would end up getting meson scattering i.e.
I have no guess for what we would get out of ##\left(\frac{i\lambda_4}{4!}\right)^2\frac{1}{2!} \int d^4 x d^4 y \langle f| T\left\{ : \phi (x)\phi (x)\phi (x)\phi (x) :: \phi (y)\phi (y)\phi (y)\phi (y) \right\}: |i\rangle## 😅
So I would say that the Feynman rules basically stay the same except for the interaction vertices.
So my questions are:
Is there an alternative approach to derive the Feynman Rules for such a theory (which avoids the evaluation of the S-matrix)?
Do you agree with my guess?
Thank you 😄
Thank you for your interesting post. I would like to offer my perspective on your questions.
Firstly, let me address your first question about alternative approaches to deriving the Feynman rules for weakly coupled theories. One possible approach is to use the path integral formalism, which allows us to write the S-matrix as a functional integral over all possible field configurations. This approach can be more efficient and intuitive in certain cases, and may be worth exploring for your specific theory.
Secondly, I would like to comment on your guess for the Feynman rules. Your intuition about the interaction vertices is correct. As you mentioned, the left diagram corresponds to the first term in the S-matrix expansion, while the right diagram corresponds to the second term. For the third and fourth terms, you can expect to get similar diagrams with more interaction vertices, corresponding to higher-order terms in the S-matrix expansion. These Feynman diagrams will involve more external legs and interaction vertices, but the basic structure will remain the same.
Thank you for sharing your thoughts and questions with the forum. I hope my response has been helpful and I wish you all the best in your research.
FAQ: Feynman rules on a ##\phi^3, \phi^4## theory
1. What is a ##\phi^3, \phi^4## theory?
A ##\phi^3, \phi^4## theory is a type of quantum field theory that describes the interactions between particles in a system. It involves fields represented by the symbols ##\phi## and ##\phi^3, \phi^4## refers to the types of interactions between these fields.
2. Who developed Feynman rules for a ##\phi^3, \phi^4## theory?
The Feynman rules for a ##\phi^3, \phi^4## theory were developed by physicist Richard Feynman in the 1940s. He used these rules to calculate the probabilities of particle interactions in quantum field theory.
3. What are Feynman rules?
Feynman rules are a set of mathematical rules that are used to calculate the probabilities of particle interactions in quantum field theory. They involve diagrams called Feynman diagrams that represent the different possible interactions between particles.
4. How are Feynman rules used in a ##\phi^3, \phi^4## theory?
In a ##\phi^3, \phi^4## theory, Feynman rules are used to calculate the probabilities of particle interactions involving the fields ##\phi##, ##\phi^3##, and ##\phi^4##. These rules involve assigning mathematical factors to each vertex in a Feynman diagram and then multiplying these factors together to determine the overall probability of the interaction.
5. What are the applications of Feynman rules in physics?
Feynman rules have a wide range of applications in physics, particularly in quantum field theory. They are used to calculate the probabilities of particle interactions in various systems, including the interactions between subatomic particles and the behavior of quantum fields. They have also been used to make predictions about phenomena such as particle decay and scattering processes.
