- #36
lavinia
- 718
If I understand this characteristic class stuff, then it also seems that the tangent bundle of the 2 sphere can not have a 1 dimensional subbundle. For if so the tangent bundle would decompose into a Whitney sum of two line bundles and each would have zero Euler class because the sphere is simply connected. The Whitney sum formula for the Euler class would then imply that the Euler class of the 2 sphere is also zero which can not be because its Euler characteristic is 2.
More generally from the same kind of reasoning, it would seem that the tangent bundle of an even dimensional sphere does not have any proper subbundle.
I think that Arkajad was thinking that the Whitney sum of the Mobius line bundle over the circle is trivial. In this bundle, parallel translation around the circle brings a vector back to its negative. So one can not get a section through parallel translation, I guess. However, if one allows the vector to rotate 180 degrees as one moves around the circle once, you get a section. What does this mean about the bundle?
