Fick's First Law (Diffusion Problem)
In summary, the conversation discusses the use of a MgO sheet to prevent a reaction between Ni and Ta at high temperatures. The task is to calculate the number of Ni ions that diffuse through the MgO per second, given the diffusion coefficient and lattice constant of Ni. Assumptions are made that there are no Ni ions in the MgO and that the Ta reacts instantly with the Ni.
goncalo x. r.
1. A sheet (with a thickness of 0.05 cm) of MgO lies in between layers of Ni and Ta to avoid reaction between these two metals . At 1400 ºC, ions of Ni are created and diffuse through the ceramic MgO to the Ta. Find the number of ions that go through the MgO per second, knowing that the diffusion coefficient of the nickel ions in the MgO is 9*10^(-12) (cm^2)/s, and the lattice constant of Ni at 1400 ºC is 3.6*10^(-8) cm.
Fick's First Law: J=-D*gradient(n) , n being the concentration of the species in cause
The exercise is pretty straight forward. The real issue is to calculate the gradient. With the lattice constant and Ni's type of structure (FCC) it's easy to find Ni's concentration, but I am lacking another concentration to make the gradient. Is the 'ceramic' suppose to imply some lattice constant and/or type of structure?
(All the information given is highlighted)
Thanks in advance,
Gonçalo X. R. N.
The thickness of the MgO sheet is given. Assume that there are no Ni ions in the MgO.
Likes goncalo x. r.
Oh ok, didn't think of that assumption.
Thank you!
If you assume there are no Ni ions in the MgO, you have an unsteady-state situation. I would assume you are looking for the steady-state diffusion rate and that the Ta reacts instantly with the Ni so that the Ni concentration at the Ta side of the MgO is zero.
Likes goncalo x. r.
Thank you!
Related to Fick's First Law (Diffusion Problem)
What is Fick's First Law and what does it describe?
Fick's First Law, also known as the Diffusion Problem, is a mathematical equation that describes the rate of diffusion of a substance. It is commonly used in the field of physics and chemistry to understand how particles move and spread in a specific medium.
What are the variables in Fick's First Law and how are they defined?
The variables in Fick's First Law are diffusion coefficient (D), concentration (C), distance (x), and time (t). D is a measure of how easily a substance can diffuse through a medium, C is the concentration gradient, x is the distance the substance has diffused, and t is the time it has taken to diffuse.
What is the formula for Fick's First Law?
The formula for Fick's First Law is J = -D(dC/dx), where J is the flux or rate of diffusion, D is the diffusion coefficient, and (dC/dx) is the concentration gradient.
What is the difference between Fick's First Law and Fick's Second Law?
Fick's First Law only applies to steady-state diffusion, where the concentration gradient and diffusion coefficient are constant. Fick's Second Law is used for non-steady-state diffusion, where the concentration gradient and diffusion coefficient can change over time.
What are some real-life applications of Fick's First Law?
Fick's First Law has many practical applications, including predicting the rate of diffusion in biological systems such as the exchange of gases in the lungs and the movement of nutrients in cells. It is also used in engineering to understand the diffusion of chemicals in materials and in environmental science to study the movement of pollutants in water and air.
11K
  • Differential Equations
11K
  • General Engineering
