GvZ
- 7
I was debating on another forum how hot a heat source in a cartoon would have had to be to cause a temperature increase in the atmosphere. In a cartoon, I found a scene in which a "fireball" (not really fire) heats the air to create a warm front immediately, clashing with an ice beam that creates its own cold front and forming a storm in the process. (It was explicitly stated that the attacks created their own warm and cold fronts.)
Is it possible to calculate the temperature the heat source based on the temperature increase of the air a certain distance away?
I was thinking the inverse square law could be used because I had found sources online (like https://api.viglink.com/api/click?format=go&jsonp=vglnk_146248078578210&key=6afc78eea2339e9c047ab6748b0d37e7&libId=inurapry010009we000DAemnuf9u7&loc=https%3A%2F%2Fwww.physicsforums.com%2Fthreads%2Finverse-square-law-temperature-change-and-heat-source-temp.870235%2F&v=1&out=http%3A%2F%2Fm.nsa.gov%2Facademia%2F_files%2Fcollected_learning%2Fhigh_school%2Fstatistics%2Ftemp_distance_lab.pdf&ref=https%3A%2F%2Fwww.physicsforums.com%2Fforums%2Fgeneral-physics.111%2F&title=Inverse%20Square%20Law%2C%20Temperature%20Change%2C%20and%20Heat%20Source%20Temp%20%7C%20Physics%20Forums%20-%20The%20Fusion%20of%20Science%20and%20Community&txt=This%20classroom%20experiment) saying that the temperature increase an object experiences from thermal radiation is subject to the inverse square law.
I was thinking that, if the air, say 4000 radii away (heat source ~ 4 m, area of effect based on size of storm alone has radius of no less than 17,000 m), experienced a temperature increase of 10 K, the temperature of the heat source would be
(4000^2) * 10 K = 160,000,000 K
or (assuming the air starts off at 25 degrees C = 298 K)
(4000^2) * (298 K + 10 K) = (4000^2) * 308 K ~ 5,000,000,000 K.
Am I completely off here? I focused on heat transfer through radiation because I've read that radiation takes over as the dominant form of heat transfer with high enough temperature differences. Would it take a temperature of 100,000,000+ degrees to heat the atmosphere from so far away? (I know a temperature like this would do far more than simply heat the air in real life.)
