Fictituous forces and apparent weight
In summary, fictitious forces are apparent forces that appear to act on objects in non-inertial reference frames and are not real forces, but rather the result of an object's acceleration relative to a non-inertial reference frame. The main difference between fictitious forces and real forces is that fictitious forces do not arise from physical interactions between objects, but rather from the choice of reference frame. They do not actually affect an object's motion, but rather appear to do so due to the frame's acceleration. Apparent weight is the weight that an object appears to have in a non-inertial reference frame, and is related to fictitious forces. In scientific calculations and experiments, it is important to carefully consider the reference frame and any
mugzieee
77
The passengers in a roller coaster car feel 50% heavier than their true weight as the car goes through a dip with a 30.0 radius of curvature.
how would i find the speed of the car at the bottom?
How do you think you'd go about finding it?
Nobody's going to do your homework for you, but a diagram with some marked forces is usually a good place to start.
FAQ: Fictituous forces and apparent weight
What are fictitious forces?
Fictitious forces, also known as pseudo forces or inertial forces, are apparent forces that appear to act on objects in non-inertial reference frames. These forces are not real forces, but rather the result of an object's acceleration relative to a non-inertial reference frame.
What is the difference between fictitious forces and real forces?
The main difference between fictitious forces and real forces is that fictitious forces do not arise from physical interactions between objects, but rather from the choice of reference frame. Real forces, on the other hand, are the result of interactions between objects, such as gravitational, electromagnetic, or contact forces.
How do fictitious forces affect an object's motion?
Fictitious forces do not actually affect an object's motion, as they are not real forces. However, they do appear to act on an object in a non-inertial reference frame due to the frame's acceleration. In an inertial reference frame, an object will not experience fictitious forces.
What is apparent weight and how is it related to fictitious forces?
Apparent weight is the weight that an object appears to have when it is in a non-inertial reference frame. This is due to the fictitious forces that arise from the frame's acceleration. For example, on a spinning amusement park ride, a person may feel heavier due to the centrifugal force acting on them, even though their actual weight has not changed.
How do we account for fictitious forces in scientific calculations and experiments?
In order to accurately account for fictitious forces, it is important to choose the appropriate reference frame for the situation. In some cases, it may be necessary to switch to an inertial reference frame in order to eliminate fictitious forces from the calculations. In experiments, it is important to carefully consider the reference frame and any potential fictitious forces that may affect the results.
9K
18K
11K
