Fidelity between a pure state and an arbitrary state
In summary, the fidelity between one pure state |\Psi\rangle and one arbitrary state \rho is given by F(|\Psi\rangle , \rho)=\sqrt{\langle\Psi|\rho|\Psi\rangle} .
Emil_M
46
Show that the Fidelity between one pure state [itex]|\Psi\rangle [/itex] and one arbitrary state [itex]\rho [/itex] is given by [itex]F(|\Psi\rangle , \rho)=\sqrt{\langle\Psi|\rho|\Psi\rangle}[/itex] .
The quantum mechanical fidelity is defined as [itex]
\begin{equation*}
F(\rho,\sigma):= Tr{ \sqrt{\rho^{\frac{1}{2}} \sigma \rho^{\frac{1}{2}}}}
\end{equation*}
[/itex]
The operator corresponding to [itex]|\Psi\rangle [/itex] is [itex]\sigma=|\Psi\rangle\langle\Psi| [/itex].
We can make use of the spectral decomposition of [itex]\sigma [/itex] in order to write
[itex]
\begin{equation*}
\sigma=\sum_{j=1}^N s_j |j\rangle\langle j|
\end{equation*}
[/itex]
It follows, that the Fidelity [itex]F(\sigma, \rho) [/itex] is given by
\begin{align*}
F(\sigma, \rho) & =Tr{\sqrt{\left(|\Psi\rangle\langle\Psi|\right)^{\frac{1}{2}}\rho\left(|\Psi\rangle\langle\Psi|\right)^{\frac{1}{2}}}} \\
&= Tr{\sqrt{|\Psi\rangle\langle\Psi|\rho|\Psi\rangle\langle\Psi|}}\\
&= Tr{\sqrt{\langle\Psi|\rho|\Psi\rangle\;|\Psi\rangle\langle\Psi|}}\\
&= Tr{\sqrt{\langle\Psi|\rho|\Psi\rangle\sum_{j=1}^N s_j |j\rangle\langle j|}}\\
&=\sqrt{\langle\Psi|\rho|\Psi\rangle} \; Tr \sum_{j=1}^N \sqrt{s_j} |j\rangle\langle j|\\
&=\sqrt{\langle\Psi|\rho|\Psi\rangle} \; \sum_{k,j=1}^N \sqrt{s_j} \langle k|j\rangle\langle j|k\rangle\\
&=\sqrt{\langle\Psi|\rho|\Psi\rangle} \; \sum_{j=1}^N \sqrt{s_j}
\end{align*}
This is not the expected result, so I have made a mistake somewhere along the way. I would be really thankful if somebody were to spot it!
Thanks in advance
Well, the easiest way to go about doing it is to realize that
[tex]\sqrt{\langle \psi | \rho | \psi\rangle |\psi\rangle \langle \psi| } = \sqrt{\langle \psi | \rho | \psi\rangle} \sqrt{ |\psi\rangle \langle \psi| } = \sqrt{\langle \psi | \rho | \psi\rangle} |\psi\rangle \langle \psi| [/tex]
and so the trace becomes trivial.
Your method is confusing, but there isn't anything wrong with it. When you perform a spectral decomposition of a projector into its diagonal basis, well its just itself isn't it? So, all the coefficients are zero except for one which is unity. So, the summation in your final expression is indeed 1.
Thanks!
I still don't get it. Why is it a given that [itex] |\Psi\rangle \langle\Psi| [/itex] is a projector?
Thanks!
Well, any operator of the form [itex]\hat{P}_{\alpha} = |\alpha \rangle \langle \alpha |[/itex], when acted upon any state ket [itex]|\beta \rangle[/itex], yields the component of [itex]|\beta \rangle[/itex] along the "direction" of [itex]|\alpha \rangle[/itex]. So, the operator [itex]\hat{P}_{\alpha}[/itex] is said to project [itex]|\beta \rangle[/itex] into the "direction" of [itex]|\alpha\rangle[/itex], and that's why it is known as a projector.
Yes, but a projector has to respect the condition [itex] P^2=P [/itex]. And the density matrix corresponding to a general qubit, for example, [itex] |\Psi\rangle = a|0\rangle+b|1\rangle [/itex] is thus not a projector, is it?
[itex]|\Psi\rangle \langle \Psi | \Psi \rangle \langle \Psi | = ?[/itex]
right :)
Thanks for taking the time, don't know why I was so confused.
Related to Fidelity between a pure state and an arbitrary state
1. What is the definition of fidelity between a pure state and an arbitrary state?
Fidelity, in quantum mechanics, is a measure of the similarity between two quantum states. Specifically, fidelity between a pure state and an arbitrary state refers to the degree to which a pure state and an arbitrary state overlap or share the same properties.
2. How is fidelity between a pure state and an arbitrary state calculated?
The fidelity between a pure state and an arbitrary state is calculated by taking the square root of the inner product of the two states. This inner product is also known as the overlap or projection of one state onto the other.
3. What does a high fidelity value indicate about the relationship between a pure state and an arbitrary state?
A high fidelity value between a pure state and an arbitrary state indicates a strong similarity or overlap between the two states. This means that the two states share many of the same properties and are highly correlated.
4. Can fidelity between a pure state and an arbitrary state be greater than 1?
No, fidelity values are always between 0 and 1, inclusive. A value of 1 indicates perfect fidelity, meaning the two states are identical, while a value of 0 indicates no overlap between the two states.
5. What is the significance of fidelity between a pure state and an arbitrary state in quantum information processing?
Fidelity is a crucial concept in quantum information processing as it allows us to quantify the quality of a quantum state or operation. In particular, fidelity between a pure state and an arbitrary state is used to measure the accuracy of quantum operations, such as state preparation and measurement, which are essential in quantum algorithms and quantum computing.
