Field extensions and degree of odd prime numbers
Wondering)Yes, they are both fields because they contain all the necessary elements and operations for field properties (closure under addition, subtraction, multiplication, and division). Adjoining algebraic elements to a field results in a larger field.
mathmari
MHB
5,049
Hey! :eek:
Let $p$ be an odd prime number. We set $a=Re \left (e^{\frac{2\pi i}{p}}\right )$.
Show that:
1) $$\mathbb{Q}(a)\leq \mathbb{Q}(e^{\frac{2\pi i}{p}}) \text{ and } \left [\mathbb{Q} \left (e^{\frac{2\pi i}{p}} \right ):\mathbb{Q}(a)\right ]=2$$
2) $$[\mathbb{Q}(a):\mathbb{Q}]=\frac{p-1}{2}$$
1) To show that $ \mathbb{Q}(a)\leq \mathbb{Q} \left ( e^{\frac{2\pi i}{p}}\right ) $ we have to show that $a \in \mathbb{Q}(a) \Rightarrow a \in \mathbb{Q} \left (e^{\frac{2\pi i}{p}}\right ) $, right ??
$a = Re \left (e^{\frac{2\pi i}{p}}\right )=\frac{1}{2} \left ( e^{\frac{2\pi i}{p}}+\overline{e^{\frac{2\pi i}{p}}}\right )=\frac{1}{2} \left ( e^{\frac{2\pi i}{p}}+e^{\frac{-2\pi i}{p}}\right )=\frac{1}{2} \left ( e^{\frac{2\pi i}{p}}+\left( e^{\frac{2\pi i}{p}}\right )^{-1} \right ) \in \mathbb{Q} \left (e^{\frac{2\pi i}{p}}\right )$
Is this correct?? (Wondering)To find $ \left [\mathbb{Q}\left (e^{\frac{2\pi i}{p}}\right ):\mathbb{Q}(a)\right ]$ we have to find the degree of $Irr\left (e^{\frac{2 \pi I}{p}},\mathbb{Q}(a)\right )$, right?
But how could we do that?? (Wondering)2) How could we find $Irr(a,\mathbb{Q})$ ?? (Wondering)
It's right, but you don't need to say $a\in \Bbb Q(a) \Rightarrow a\in \Bbb Q\left(e^{\frac{2\pi i}{p}}\right)$. You're simply trying to show that $a\in \Bbb Q\left(e^{\frac{2\pi i}{p}}\right)$.
Yes. Let $z = e^{\frac{2\pi i}{p}}$. Since $a = \frac{z + z^{-1}}{2}$, multiplying both sides by $2z$ yields $2az = z^2 + 1$, or $z^2 - 2az + 1 = 0$. Show that $x^2 - 2ax + 1 \in \Bbb Q(a)[x]$ is $\text{Irr}(z: \Bbb Q(a))$.
There's no need. Since $\Bbb Q \le \Bbb Q(a) \le Q(z)$, we have
\(\displaystyle [\Bbb Q(a) : \Bbb Q] = \frac{[\Bbb Q(z) : \Bbb Q]}{[\Bbb Q(z) : \Bbb Q(a)]}.\)
Since $[\Bbb Q(z) : \Bbb Q] = p - 1$ and $[\Bbb Q(z) : \Bbb Q(a)] = 2$, it follows that $[\Bbb Q(a) : \Bbb Q] = \frac{p-1}{2}$.
Does it stand that $\mathbb{Q}(a) \leq \mathbb{Q}\left(e^{\frac{2\pi i}{p}}\right)$ when we show that $a\in \Bbb Q\left(e^{\frac{2\pi i}{p}}\right)$, because $a\in \Bbb Q\left(e^{\frac{2\pi i}{p}}\right)$ means that $\mathbb{Q}(a) \subseteq \mathbb{Q}\left(e^{\frac{2\pi i}{p}}\right)$ and since $\mathbb{Q}(a)$ and $\mathbb{Q}\left(e^{\frac{2\pi i}{p}}\right)$ are fields, we have that $\mathbb{Q}(a) \leq \mathbb{Q}\left(e^{\frac{2\pi i}{p}}\right)$ ?? (Wondering)
Yes :D
Euge said:
Yes :D
Ok! Do we have to prove that $\mathbb{Q}(a)$ and $\mathbb{Q}\left(e^{\frac{2\pi i}{p}}\right)$ are fields?? (Wondering)
I would hope not, since by definition, $\Bbb Q(a)$ is the smallest field containing $\Bbb Q$ and $a$, and similarly for $\Bbb Q(e^{\frac{2\pi i}{p}})$.
$a$ and $\exp(2\pi i/p)$ are algebraics over $\Bbb Q$ and field while adjoined with algebraic are...?
FAQ: Field extensions and degree of odd prime numbers
What is a field extension?
A field extension is a mathematical concept that involves extending a field (such as the rational numbers or real numbers) by adding in new elements. This results in a larger field that contains the original field as a subset.
How is the degree of a field extension determined?
The degree of a field extension is determined by the number of elements that are added to the original field. For example, if we extend the field of rational numbers by adding the square root of 2, the degree of this extension would be 2, since we are adding one new element.
What is the significance of the degree of a field extension?
The degree of a field extension is important because it tells us about the complexity of the extended field. A higher degree extension means that the extended field is more complex and has more elements than the original field.
Can a field extension have a degree of 1?
Yes, a field extension can have a degree of 1. This means that no new elements are added to the original field, and the extended field is essentially the same as the original field.
How is a field extension represented?
A field extension is typically represented as a tower of fields, with the original field at the bottom and each subsequent field extension on top. For example, a field extension of the rational numbers by the square root of 2 would be represented as Q → Q(√2).
