Field Extensions - Discussion of Dummit and Foote - page 512
In summary, the discussion in Dummit and Foote's Abstract Algebra on field extensions involves constructing an extension field from a given field and polynomial, where the polynomial does not have a root in the given field. This is achieved by considering irreducible polynomials and their splitting fields, which may contain roots not present in the given field. The goal is to create a minimal extension field that contains all necessary roots, using only knowledge of polynomials and rings.
Math Amateur
MHB
3,998
48
I am trying to understand a discussion of field extensions by Dummit and Foote: Abstract Algebra, page 512 ...
The relevant text is as follows:View attachment 4832When I first read the second paragraph, starting "Given any field \(\displaystyle F\) and any polynomial \(\displaystyle p(x) \in F[x]\) ... ... ... ", I thought that D&F were trying to construct a situation where \(\displaystyle p(x)\) did not have a root in \(\displaystyle F\) ... ... and then go on to construct an extension field \(\displaystyle K = F[x]/p(x)\) that did indeed have a root of the polynomial \(\displaystyle p(x)\) ... ...BUT ... ... D&F appear (to me, anyway) to try to ensure that \(\displaystyle p(x)\) does not have a root in \(\displaystyle F\) by stipulating or declaring that \(\displaystyle p(x)\) must be irreducible ... at least I think this is their intention .. ...
BUT ... ... ? ... ... linear polynomials such as \(\displaystyle x - 7\) are irreducible in \(\displaystyle F[x]\) when \(\displaystyle F = \mathbb{Q}\) ... but \(\displaystyle p(x) = x - 7\) does have a root in \(\displaystyle \mathbb{Q}\) ... that is no need for an extension field (except the 'extension' \(\displaystyle \mathbb{Q} = \mathbb{Q}\)) ...
So it seems to me I am not fully understanding D&F's discussion ...
Can someone please clarify D&F's discussion for me by explaining what they are really getting at ...
Peter
Lots of polynomials have roots in the underlying field their polynomial coefficients are in. For example, $x^2 - 3x + 2$ does, as it equals $(x - 2)(x - 1)$ (assuming an underlying field of characteristic $0$, so as to avoid ambiguity).
The point being, if we want to find roots of ALL polynomials, it suffices to consider roots of IRREDUCIBLE polynomials, because we can factor polynomials into their irreducible factors (this is, essentially, the statement that $F[x]$ is a UFD. In a UFD, "irreducible" and "prime" mean the same thing- see here).
A polynomial like $x - 7$ is indeed irreducible (over $\Bbb Q$, let's say). All this leads us to conclude is that the only possible root it has is $7$, and yes, $7 \in \Bbb Q$. If a polynomial factors completely, over a field, into linear factors, we say it SPLITS, and the smallest field containing all of its roots is called its SPLITTING FIELD. For a polynomial like $x - 7$, the splitting field is $\Bbb Q$. This is not particularly interesting.
On the other hand, anyone familiar with the quadratic formula knows it entails square roots. So, even if a quadratic polynomial has rational coefficients, it may not have rational roots-because $\Bbb Q$ does not contain all square roots of rational numbers. For example $\sqrt{2} \not\in \Bbb Q$. This is the kind of situation in which we seek to extend $\Bbb Q$.
But how? Imagine we don't yet know about $\Bbb R$ (for square roots of positive rational numbers) or $\Bbb C$ (for square roots of negative rational numbers). How can we, only having knowledge of polynomials and rings, CREATE an extension of $\Bbb Q$ that contains a square root we need as a root of a quadratic? Ideally, we want a "minimal" construction, so we only do the amount of work we HAVE to.
Thanks for the help, Deveno ...
Will reflect on this more in the morning ... after midnight here in Tasmania ...
Grateful for your help, as usual ...
Peter
FAQ: Field Extensions - Discussion of Dummit and Foote - page 512
What is a field extension?
A field extension is a mathematical concept that extends the operations and properties of a given field, such as the real numbers, to a larger field containing the original field as a subset. This allows for the creation of new elements and operations within the larger field that were not possible in the original field.
How are field extensions related to algebraic structures?
Field extensions are a type of algebraic structure that contain both a field and a larger field that is an extension of the original field. This means that all elements and operations in the original field are also present in the larger field, but the larger field also contains additional elements and operations.
What is the degree of a field extension?
The degree of a field extension is the number of elements in the extension field that are linearly independent over the original field. It is denoted by [F:E], where F is the extension field and E is the original field. The degree of a field extension is always a finite number.
Can all fields be extended?
No, not all fields can be extended. Some fields, such as the rational numbers or the real numbers, are already considered to be "complete" and cannot be extended any further. However, many fields can be extended in various ways, leading to the creation of new fields with different properties.
How are field extensions used in mathematics?
Field extensions have many important applications in mathematics, particularly in algebra and number theory. They are used to study and classify algebraic structures, such as rings and fields, and to prove theorems and solve equations. They also have applications in other areas, such as coding theory, cryptography, and physics.
