Field Extensions - Lovett, Theorem 7.1.10 - Another question
In summary: Lovett's argument is an indirect proof. The statement to proof is: If there is a polynomial ##b(x)## of minimal degree with the property ##b(\alpha)Hi Peter,(QUESTION 1) Lovett brings the minimal polynomial ##p(x)## into the argument ... why is he doing this ... what is his objective in this matter ... ?About the "why" question: (I'll try not to write "Because it works." and guess a motivation instead. Truth is, finding a proof is usually a process of trial and error. You still can see this in Lovett's style, which mostly is a sequence of many small contradiction arguments. Not very pleasant to read.)If we gather all we have about
Math Amateur
MHB
3,998
48
I am reading "Abstract Algebra: Structures and Applications" by Stephen Lovett ...
I am currently focused on Chapter 7: Field Extensions ... ...
I need help with another aspect of the proof of Theorem 7.1.10 ...Theorem 7.1.10, and its proof, reads as follows:
In the proof of the above Theorem, towards the end of the proof, Lovett concerns himself with proving that ##F( \alpha ) \subset F[ \alpha ]## ... ...
To do this he points out that every element in ##F( \alpha )## can be written as a rational expression of ##\alpha##, namely ...
##\gamma = \frac{ a( \alpha )}{ b( \alpha )}##
where ##a( \alpha ), b( \alpha ) \in F[x]## and ##b( \alpha ) \neq 0## ...
Lovett then says ...
" ... ... Suppose also that ##a( \alpha )## and ##b( \alpha )## are chosen such that ##b( \alpha )## has minimal degree and ##\gamma = \frac{ a( \alpha )}{ b( \alpha )}##. ... ... "What does Lovett mean by choosing ##a( \alpha )## and ##b( \alpha )## such that ##b( \alpha )## has minimal degree ... ... ?
It cannot mean choosing special elements for ##b( \alpha )## ... as then ##\gamma## would not be a representative element of ##F( \alpha )## ...
Can someone please clarify this issue ...
Peter
EDIT Does it just mean that when we have ... for example ...##\gamma = \frac{ a( \alpha )}{ b( \alpha )} = \frac{ x^3 - 3x }{ x^4 + 7x }##we just (in this case, for example) we just 'cancel' the ##x## ... and similarly for other examples ...
Yes.
The representation of a number ##\gamma## as a quotient ##\frac{a(\alpha)}{b(\alpha)}## is usually not unique.
However, the set ##\mathcal{Q}_\gamma = \left\{ \left. \frac{a(x)}{b(x)} \,\right\vert \,a,b \in F[x]\, , \,\gamma = \frac{a(\alpha)}{b(\alpha)} \right\} ## can be partially ordered by the degree of ##b(x)##. Furthermore, ##\deg b(x) \geq 0##, and thus there must be a minimal element in any ordered chain in ##\mathcal{Q}_\gamma##. Such an element is chosen.
This doesn't mean this element is unique, as we still can have common factors of nominator and denominator of degree ##0##, i.e. elements of ##F##, or even different polynomials ##b(x)## and ##b'(x)## in the representation of ##\gamma##. But as the argument only relies on the degree of ##b(x)##, we don't care, whether elements of ##F## have been canceled or not, or which ##b(x)## of minimal degree (i.e. which ordered chain in ##\mathbb{Q}_\gamma##\,) we chose. Even ##\alpha## itself can be in ##F##, in which case nothing would have been to prove, so we can rule out this case, too, if we like.
fresh_42 said:
Yes.
Thanks fresh_42 ... most helpful ...
BUT ... just a couple more clarifications pertaining to Lovett's argument that ##b(x)## must be a constant (an argument I am having trouble fully understanding ... )
Further ... ... Lovett writes ... :
" ... ... Hence ##a( \alpha ) / b( \alpha )## can be written as ##a_2( \alpha ) / b_2( \alpha )## where ##\text{ deg } b_2( x ) \lt \text{ deg } b( x)##. This contradicts the choice that ##b( x)## has minimal degree. Consequently, ##r(x) = 0## and hence ##b(x)## divides ##a(x)##. ... .. "
(QUESTION 2) I cannot see how in this argument Lovett concludes that ##b(x)## divides ##a(x)## ... ... ? Can you help ...?Then Lovett writes:
" ... ... Then the expression ##\gamma = a( \alpha ) / b( \alpha )## can only be such that ##b(x)## has minimal degree among such rational expressions if ##b(x)## is a constant. ... ... "
(QUESTION 3) I do not follow this argument that ##b(x)## must be a constant ... can you help ... ?
Peter
Hi Peter,
If we gather all we have about ##\gamma ## and ##\alpha ##, then it is ##\gamma = \frac{a(\alpha)}{b(\alpha)}## and ##p(\alpha)=0##, so it makes sense to relate those three polynomials ( ##a,b,p## ), i.e. see what divisions bring. The goal is to show ##b(x)=b_0 \in F## so that all quotients ## \gamma ## are already in ##F[\alpha]##. This means the degree of ##b(x)## has to be ##1## for this purpose. Division is a good method in algebra to reduce degrees or similar valuations or to use it in an induction argument.
##a_2(\alpha) = a(\alpha)\cdot q(\alpha)## and ##b_2(\alpha)=-r(\alpha)##. We also have (Euclid's algorithm) ##\deg b_2(x) = \deg r(x) < \deg b(x)##. Minimality of ##\deg b(x)## in the representation of ##\gamma ##, however, implies that ##b_2(x)=r(x)=0##. (We have chosen ##b(x)## this way, see my earlier post.)
Now I'm also lost. I assume it's a typo, since ##r(x)=0## implies ##b(x) \mid p(x)##. Now ##p(x)## is irreducible, and therefore a factor ##b(x) ## of it has to be a unit, i.e. an element of ##F\, : \, b(x)=b_0 \in F##.
Me neither, see above. ##a(x)## should be replaced by ##p(x)## here.
Then Lovett writes:
" ... ... Then the expression ##\gamma = a( \alpha ) / b( \alpha )## can only be such that ##b(x)## has minimal degree ##b(x)## has minimal degree among such rational expressions if ##b(x)## is a constant. ... ... "
We have written ##\gamma = \frac{a_2(\alpha)}{b_2(\alpha)}## with the settings for ##a_2(x),b_2(x)## I mentioned above. But ##\deg b(x)## was chosen minimal among all possible representations of ##\gamma## in this way.
I hope my answer on your first question covers the other two.
I've forgotten one point. The argument that ##b(x)## has to be a unit uses the fact, that otherwise ##q(x)=q_0## would be the unit (by irreducibility of ##p(x)##). But then ##0=p(\alpha)=b(\alpha)\cdot q(\alpha) = b(\alpha) \cdot q_0## and ##b(\alpha)=0## which can't be by the choice of ##b(\alpha)## as the denominator of ##\gamma##. Thus ##b(x)## has to be the unit.
Likes Math Amateur
fresh_42 said:
Hi Peter,
Now I'm also lost. I assume it's a typo, since ##r(x)=0## implies ##b(x) \mid p(x)##. Now ##p(x)## is irreducible, and therefore a factor ##b(x) ## of it has to be a unit, i.e. an element of ##F\, : \, b(x)=b_0 \in F##.Me neither, see above. ##a(x)## should be replaced by ##p(x)## here.
Thanks fresh_42 ... just reflecting on your post ...
But one quick clarification ...
You write:
" ... ... The goal is to show ##b(x)=b_0 \in F## so that all quotients ## \gamma ## are already in ##F[\alpha]##. This means the degree of ##b(x)## has to be ##1## for this purpose. ... ... "Can you explain your reasoning that the degree of ##b(x)## has to be ##1## ... ...
If ##b(x)=b_0 \in F## then doesn't the degree of ##b(x)## have to be ##0## ... ... ?Hope you can clarify ... ... must be misunderstanding you somehow ...
Peter
Yep, it's late up here ... Of course ##0##, sorry.
Likes Math Amateur
No problems ... your posts have been extremely helpful!
Thanks again ... from the edge of the world in southern Tasmania ... early afternoon here ...
Peter
Likes fresh_42
Related to Field Extensions - Lovett, Theorem 7.1.10 - Another question
What is a field extension?
A field extension is a mathematical concept that involves extending a field (a set of numbers with operations of addition, subtraction, multiplication, and division) by adding new elements to it.
What is Lovett's Theorem 7.1.10?
Lovett's Theorem 7.1.10 is a theorem in abstract algebra that states that if F is a field and E is a finite-dimensional vector space over F, then every linearly independent subset of E can be extended to a basis of E.
What is the significance of Lovett's Theorem 7.1.10?
Lovett's Theorem 7.1.10 is significant because it provides a way to construct a basis for a finite-dimensional vector space, which is a crucial tool in many areas of mathematics, including linear algebra, differential equations, and physics.
How does Lovett's Theorem 7.1.10 relate to field extensions?
Lovett's Theorem 7.1.10 is related to field extensions because it shows that every finite-dimensional extension of a field can be constructed by adding a finite number of elements to the base field.
Can Lovett's Theorem 7.1.10 be applied to infinite-dimensional vector spaces?
No, Lovett's Theorem 7.1.10 only applies to finite-dimensional vector spaces. For infinite-dimensional vector spaces, a different approach is needed to construct a basis.
  • Linear and Abstract Algebra
