Field intensity of a sheet of charge
In summary, a sheet of charge with Ps = 2 NC/m^2 exists at x = 3 in free space, and a line charge with Pl = 20 nC/m is located at x = 1, z = 4. The magnitude of the electric field intensity at the origin is given by Es = -σ/2ε0 i, while the direction of E at P (4,5,6) is found using Gauss' theorem with a right circular cylindrical closed surface of radius R = √(52) and height = 1. The force per meter length on the line charge is λ*Es i, with the appropriate sign used for Es since x < 3 for the
eeengenious
A sheet of charge Ps = 2 NC/m^2 is present at the plane x = 3 in free space, and a line charge Pl = 20 nC/m is located at x = 1, z = 4.
a) Find the magnitude of the electric field intensity at the origin
b) Find the direction of E at P (4,5,6)
c) What is the force per meter length on the line charge?
Field of a sheet of Charge
E = Ps/2(epsilon) * An
At the origin, do I just use the equation above?
For the direction to (4,5,6), how exactly would I draw the vectors?
Appreciate the help, thanks!
Good thing you gave us the fromula for the E field due to the sheet, since the question did not specify if it was conducting or not. It's not.
Take one source of E at a time.
The sheet gives an E field of Es = σ/2ε0 directed in the +x ditection for x > 3 and in the -x direction for x < 3:
Es = σ/2ε0 i, x > 3
Es = -σ/2ε0 i, x < 3. Since the origin is at x<3 you will use this for Es.
Then, the wire, which runs up & down parallel to the y-axis at (1,4):
To find the E field = Ew due to it, I would use Gauss' theorem with a right circular cylindrical closed surface of radius R = √(4^2 + 1^2) = √(17) and height = 1, concentric with the wire. This gives |Ew|*2πR = λ where λ = linear charge density of wire. At the origin this field is directed opposite (4,1) so the vector will be
Ew = |Ew|(-i - 4j)/√17.
So the total field is E = Es + Ew at the origin.
To get the field at ( 4,5,6) do the same thing. Es is now + since x > 3 at this point. Use the same idea with the Gaussian surfgace for Ew. R for this point is now
R = √(4^2 + 6^2) = √52. (y = 5 has no significance; the field is the same for all y.)
The force on the wire per unit length is just λ*Es i. Remember that x<3 for the wire so use the appropriate sign for Es.
the same since x>3
FAQ: Field intensity of a sheet of charge
What is the formula for calculating the field intensity of a sheet of charge?
The formula for calculating the field intensity of a sheet of charge is E = σ/2ε, where E is the electric field intensity, σ is the surface charge density, and ε is the permittivity of the medium.
How is the direction of the electric field determined for a sheet of charge?
The direction of the electric field for a sheet of charge is perpendicular to the sheet, pointing away from the positively charged side and towards the negatively charged side.
Can the field intensity vary along the surface of a sheet of charge?
No, the field intensity is constant along the surface of a sheet of charge as long as the sheet is infinite and has a uniform charge distribution.
How does the field intensity of a sheet of charge change as you move away from the sheet?
The field intensity of a sheet of charge decreases as you move away from the sheet, following an inverse relationship with the distance from the sheet.
What is the difference between a sheet of charge and a point charge in terms of field intensity?
A sheet of charge has a uniform distribution of charge, resulting in a constant field intensity along its surface, while a point charge has a concentrated charge at a single point, resulting in a varying field intensity as you move away from the point.
