MHB Field Theory _ Dummit and Foote - Theorem 3
The discussion focuses on understanding Theorem 3 from Dummit and Foote's Chapter 13 on Field Theory, particularly the congruence of polynomials in the context of quotient rings. The main query revolves around the interpretation of the notation involving residue classes and how to correctly express the polynomial evaluation at these classes. An example using the polynomial \( p(x) = x^2 + 1 \) illustrates the irreducibility over \( \mathbb{Q} \) and the formation of the quotient ring \( \mathbb{Q}[x]/(x^2 + 1) \), which is shown to be a field. The discussion also emphasizes the importance of correctly applying the projection map and understanding the operations within the quotient ring. Overall, the thread seeks clarification on polynomial evaluations in residue classes and the implications for field extensions.
Math Amateur
MHB
I am reading Dummit and Foote, Chapter 13 - Field Theory.
I am currently studying Theorem 3 [pages 512 - 513]
I need some help with an aspect of the proof of Theorem 3 concerning congruence or residue classes of polynomials.
D&F, Chapter 13, Theorem 3 and its proof read as follows:https://www.physicsforums.com/attachments/2712
View attachment 2713In the above text D&F state the following:
" ... ... If $$ \overline{x} = \pi (x) $$ denotes the image of x in the quotient K, then
$$ p ( \overline{x} ) = \overline{p(x)} $$ ... ... ... (since $$ \pi $$ is a homomorphism) ... ... "
I do not completely understand this statement and further I am having some trouble interpreting the meaning of the notation ...
I hope someone can help .. ...
In order to ensure I understood congruence classes or residue classes in F[x] I went to Hungerford, Abstract Algebra: An Introduction, Chapter 5. In this chapter Hungerford gives the following definitions:View attachment 2714
View attachment 2715So, following Hungerford, if we want to find the residue class of $$ f(x) = x $$, we write:
$$ \overline{x} = [x] = \{ x + k(x)p(x) \ | \ k(x) \in F[x] \} $$
But given this ... how do we form $$ p( \overline{x})$$?
Do we substitute $$p(x)$$ for $$x$$, everywhere $$x$$ appears getting the following:
$$ p ( \overline{x} ) = p[x] = \{ p(x) + k(p(x))p(p(x)) \ | \ k(x) \in F[x] \} $$ ?
I know this seems clumsy ... but it seems to me to have some formal merit ... anyway, although I suspect it is not the way to go ... I am not sure why ...
So maybe the right interpretation is as follows:
$$ p ( \overline{x} ) = p[x] = \{ p(x) + k(x)p(x) \ | \ k(x) \in F[x] \} $$ ?
Can someone clarify this issue for me indicating not only which alternative is correct - but further why that alternative is correct and the other wrong.
I would appreciate some help in this matter.
Peter
The notation is awkward, simply because "polynomial expresssions" are rather clumsy to write down in the first place.
Let's look at a simple example: let $F = \Bbb Q$, and let $p(x) = x^2 + 1$. Clearly, $x^2 + 1$ is irreducible over $\Bbb Q$, for if it were not, Gauss' lemma tells us it would be reducible over $\Bbb Z$, and thus would have an integer root. This integer root would be a factor of 1, hence could only be -1, or 1. Since neither one of these is a root, $x^2 + 1$ is irreducible over $\Bbb Q$.
So we can form the quotient ring: $\Bbb Q[x]/(x^2 + 1)$, which is a field, by dint of the fact that $x^2 + 1$ generates a maximal ideal (being irreducible).
Now elements of $I = (x^2 + 1)$ are rational polynomials of the form: $k(x)(x^2 + 1)$. For example, we have:
$x^3 + x, 2x^2 + 2, x^4 - 1 \in I$.
and a typical element $[f(x)] \in \Bbb Q[x]/I$ is comprised of elements of the form $f(x) + k(x)(x^2 + 1)$, for some $k$.
It behooves us to find a simpler form for $[f(x)]$, which will allow us to limit the complexity of computation in $\Bbb Q[x]/I$. Since $\Bbb Q[x]$ is a Euclidean domain, we may write:
$f(x) = q(x)(x^2 + 1) + r(x)$, where $r(x) \equiv 0$, or $0 \leq \text{deg}(r) < \text{deg}(x^2 + 1) = 2$
We then see that:
$[f(x)] = \{f(x) + k(x)(x^2 + 1)\} = \{q(x)(x^2 + 1) + r(x) + k(x)(x^2 + 1)\} = \{r(x) + (q(x) + k(x))(x^2 + 1)\}$;
that is: $[f(x)] = [r(x)]$.
It follows that we can thus write any $[f(x)]$ as: $[ax + b]$ for unique rational numbers $a,b$.
Now consider the mapping $\Bbb Q \to \Bbb Q/I$ given by*:
$q \mapsto [0x + q] = q + I$. It is not hard to see this is a ring-homomorphism, and since $\Bbb Q$ is a FIELD, it's kernel must be an ideal of $\Bbb Q$. But $\Bbb Q$, as a field, only has TWO ideals: $(0)$ and $(1) = \Bbb Q$.
Since this map is evidently not the 0-map, the kernel must be trivial, so it is a monomorphism of rings, and thus an isomorphism of $\Bbb Q$ with its image. In THIS WAY, we can consider $\Bbb Q[x]/I$ an extension of $\Bbb Q$.
Now, clearly, taking $a = 1,b = 0$ yields a unique coset in $\Bbb Q[x]/I$, namely:
$[x] = x + I$.
So what might we mean by $f([x]) = f(x + I)$? If $\pi: \Bbb Q[x] \to \Bbb Q[x]/I$ is the canonical projection map, we just mean:
$f([x]) = f(\pi(x)) \equiv \pi(f(x))$, that is, if:
$f(x) = a_0 + a_1x + \cdots + a_nx^n$ , then:
$f(x + I) = (a_0 + I) + (a_1 + I)(x + I) + \cdots + (a_n + I)(x + I)^n$
$= (a_0 + I) + (a_1x + I) + \cdots + (a_nx^n + I)$
$ = (a_0 + a_1x + \cdots + a_nx^n) + I = f(x) + I$
(REMEMBER how we add and multiply cosets: $(r + I) + (s + I) = (r+s) + I$ and $(r + I)(s + I) = (rs) + I$).
Now what does this mean if $f(x) = p(x) = x^2 + 1$?
$p(x + I) = (x + I)^2 + (1 + I) = (x^2 + I) + (1 + I) = (x^2 + 1) + I = I = 0 + I$.
So in the ring $(\Bbb Q/I)[x+I] \cong \Bbb Q[x]/I$ (be sure you understand this isomorphism! $x + I$ is no longer an "indeterminate" on the left because $I$ annihilates multiples of $x^2 + 1$).
Let's look closer at how $\Bbb Q[x]/I$ behaves. As we saw above, we can write an element as:
$(ax + b) + I$.
Clearly, to add two elements, we get:
$(ax + b) + I + (cx + d) + I = ((a + c)x + (b + d)) + I$.
This suggests we have an abelian group homomorphism: $\Bbb Q \times \Bbb Q \to \Bbb Q[x]/I$ given by:
$(a,b) \mapsto (ax + b) + I$.
I recommend you PROVE this is, in fact, an isomorphism.
Now we can make $\Bbb Q \times \Bbb Q$ into a $\Bbb Q$-module in a natural way: we define, for $q \in \Bbb Q$:
$q\cdot (a,b) = (qa,qb)$.
Show that if we define a $\Bbb Q$-action on $\Bbb Q[x]/I$ by:
$q\cdot((ax + b) + I) = (q + I)((ax + b) + I) = ((qa)x + qb) + I$, this gives a $\Bbb Q$-module isomorphism.
This means that we can regard $\Bbb Q[x]/I$ as a 2-dimensional vector space over $\Bbb Q$, with basis $\{1+I,x + I\}$.
But since we know $\Bbb Q[x]/I$ is a field (so thus a ring), we have even MORE structure: a multiplication. What is this multiplication, in simplest terms? Let's find out:
$((ax + b) + I)((cx + d) + I) = (ax + b)(cx + d) + I = acx^2 + (ad + bc)x + bd + I$.
Now, note that this is of degree 2, so we ought to be able to "reduce" it (mod $I$). Let's do this.
$acx^2 + (ad + bc)x + bd + I = acx^2 + ac + (ad + bc)x + bd - ac + I = (ad + bc)x + bd - ac + ac(x^2 + I) + I$
Now, $ac(x^2 + I) \in I$ (since $I$ is an ideal), so we have:
$((ax + b) + I)((cx + d) + I) = ((ad + bc)x + (bd - ac)) + I$.
Convince yourself that if $i = \sqrt{-1} \in \Bbb C$, that:
$\phi: \Bbb Q[x]/I \to \Bbb Q(i) \subset \Bbb C$, given by:
$\phi((ax + b) + I) = b + ai$ is an isomorphic of our field with the rational complex numbers (the field of quotients of the Gaussian integers).
Clearly: $\phi(x + I) = \phi((1x + 0) + I) = 0 + 1i = i$, and indeed, in $\Bbb C$, we have $i$ is a root of $x^2 + 1$, therefore (since we have an isomorphism), $(x + I)$ is a root of $(x + I)^2 + (1 + I)$ in $\Bbb Q[x]/I$.
This procedure is entirely general, and can be extended to:
Any polynomial in $F[x]$ has a root in an extension of $F$, and thus: for any field $F$, and any polynomial $f(x)$, there exists an extension field $E$ that contains EVERY root of $f$ (just repeat this procedure until all roots are accounted for).
* Note: this is rather an abuse of notation; $I$ is not an ideal of $\Bbb Q$, rather we mean the image of $\Bbb Q$ in $\Bbb Q[x]/I$, considering $\Bbb Q$ as a subring of $\Bbb Q[x]$.
We then see that:
$[x] = x + I$.
$(ax + b) + I$.
Thanks Deveno ... this post is significantly helpful ...
Working through what you have written carefully and reflecting on what you have said ...
Thanks again,
Peter
We then see that:
$[x] = x + I$.
$(ax + b) + I$.
Hi Deveno ... Just a further note to say that I found this post EXTREMELY helpful ... particularly as it involved a concrete and instructive example ...
Thanks again,
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 21 ·
