Field Theory - Algebrais Extensions - D&F - Section 13.2 - Exercise 2, page 529
In summary, the conversation discusses Dummit and Foote Exercise 2, Section 13.2, page 529. The exercise deals with obtaining fields of 4, 8, 9 and 27 elements by adjoining a root of a polynomial to a field F where the polynomial is either g(x) = x^2 + x - 1 or h(x) = x^3 - x + 1 and F = \mathbb{F}_2 or \mathbb{F}_3. The multiplication tables for the fields with 4 and 9 elements are written down and it is shown that the non-zero elements form a cyclic group. However, there is some confusion about the multiplication tables and a request for confirmation of
Math Amateur
MHB
3,998
48
Dummit and Foote Exercise 2, Section 13.2, page 529 reads as follows:
2. Let [TEX] g(x) = x^2 + x -1 [/TEX] and let [TEX] h(x) = x^3 - x + 1 [/TEX]. Obtain fields of 4, 8, 9 and 27 elements by adjoining a root of f(x) to a field F where f(x) = g(x) or h(x) and [TEX] F = \mathbb F_2 [/TEX] or [TEX] \mathbb F_3 [/TEX]. Write down the multiplication tables for for the fields with 4 and 9 elements and show that the non-zero elements form a cyclic group.
In my first attempt at this exercise I took [TEX] f(x) = x^2 + x -1 [/TEX] and [TEX] F = \mathbb F_2 [/TEX]
So we have [TEX] \mathbb F_2 = \{ 0. 1 \}[/TEX] and f(x) as above.
The elements of [TEX] \mathbb F_2 ( \alpha ) [/TEX], then, are as follows: (see attachment)
[TEX]0 + 0. \alpha = 0 [/TEX],
[TEX]1 + 0. \alpha = 1 [/TEX],
[TEX] 0 + 1. \alpha = \alpha [/TEX],
and [TEX] 1 + 1. \alpha = 1 + \alpha [/TEX]The multiplication table can then be composed using the following:
[TEX] {\alpha}^2 + \alpha - 1 = 0 [/TEX]
That is [TEX] {\alpha}^2 = 1 - \alpha [/TEX] ... ... ... ... ... (1)
So the multiplication table, composed using (1) is as follows: (see attachment)
[TEX] 0 \times 0 = 0 \ , \ 0 \times 1 = 0 \ , \ 0 \times \alpha = 0 \ , \ 0 \times {1 + \alpha} = 0 [/TEX]
[TEX] 1 \times 0 = 0 \ , \ 1 \times 1 = 1 \ , \ 1 \times \alpha = \alpha \ , \ 1 \times (1 + \alpha) = (1 + \alpha) [/TEX]
[TEX] \alpha \times 0 = 0 \ , \ \alpha \times 1 = \alpha \ , \ \alpha \times \alpha = (1 - \alpha) \ , \ \alpha \times (1 + \alpha) = 1 [/TEX]
[TEX] (1 + \alpha) \times 0 = 0 \ , \ (1 + \alpha) \times 1 = (1 + \alpha) \ , (\ 1 + \alpha) \times \alpha = 1 \ , \ (1 + \alpha) \times (1 + \alpha) = (2 + \alpha) [/TEX]So far so good (i think?) but when I test whether the 9 non-zero elements in the multiplication table form a cyclic group they do notFor example if you try a cyclic group for the non-zero elements based on [TEX] \alpha [/TEX] we find:
[TEX] {\alpha}^2 = 1 - \alpha [/TEX] (?? should generate another member of the group but does not!)
and
[TEX] {\alpha}^3 = \alpha (1 - \alpha) = \alpha - {\alpha}^2 = \alpha - (1 - \alpha) = 2\alpha - 1 [/TEX] (?? not an element of the group)
Can anyone help?
Peter
[Note; The above has also been posted on MHF]
OK, I think you are a bit confused.
If the base field is $F_2 = \{0,1\} = \Bbb Z_2$ with multiplication and addition modulo 2, and our irreducible polynomial is of degree 2 (so that $[F_2(\alpha):F] = 2$), then viewed as a vector space, $F_2(\alpha)$ is isomorphic to $F_2 \times F_2$:
$0 = 0 + 0\alpha \leftrightarrow (0,0)$
$1 = 1 + 0\alpha \leftrightarrow (1,0)$
$\alpha = 0 + 1\cdot\alpha \leftrightarrow (0,1)$
$\alpha + 1 = 1 + 1\cdot\alpha \leftrightarrow (1,1)$
This clearly has just 4 elements, and thus just THREE non-zero elements. I claim $\alpha$ generates the non-zero elements:
$\alpha^2 = 1 - \alpha$ (since $\alpha^2 + \alpha - 1 = 0$). But in a field $F$ of characteristic 2, $-u = u$ for ALL $u \in F$, since:
$u+u = 1\cdot u + 1\cdot u = (1 + 1)u = 0u = 0$,
Thus $1 - \alpha = 1 + \alpha = \alpha + 1$.
Finally:
$\alpha^3 = \alpha(\alpha^2) = \alpha(\alpha + 1) = \alpha^2 + \alpha = (\alpha + 1) + \alpha$
$= (\alpha + \alpha) + 1 = 0 + 1 = 1$, which shows that $\alpha$ is of order 3.
Finally:
Thanks for the help, Deveno
Just working on this nowPeter(PS sorry for delay ... Commitments to my day job intervened unfortunately :-). )
I have worked through the post.. It was very helpful.
I am assuming that where you write [FONT=MathJax_Math]F[/FONT][FONT=MathJax_Main]2[/FONT][FONT=MathJax_Main]([/FONT][FONT=MathJax_Math]α[/FONT][FONT=MathJax_Main])[/FONT] is isomorphic to [FONT=MathJax_Math]F[/FONT][FONT=MathJax_Main]2[/FONT][FONT=MathJax_Main]×[/FONT][FONT=MathJax_Math]F[/FONT][FONT=MathJax_Main]2[/FONT] that you are not contesting the fact that \(\displaystyle \mathbb{F}_2 ( \alpha ) = \{ a_0 + a_1 \alpha \ | \ a_0, a_1 \in \mathbb{F}_2 \) - but are just expressing the fact that \(\displaystyle \mathbb{F}_2 ( \alpha ) \cong \mathbb{F}_2 \times \mathbb{F}_2 \) (I do not think you are contesting this - but just checking with you)
I have used the points you have made regarding the fact that \(\displaystyle \mathbb{F}_2 \) has characteristic 2 to upgrade my multiplication table for \(\displaystyle \mathbb{F}_2 ( \alpha ) \) - I have attached the multiplication table as I had it before - labelled previous post - and the new multiplication table - labelled new post.
Can someone please confirm that the new multiplication table is correct.
Peter
Yes, it is correct. Note we have two ways to view this finite field:
1) As a vector space over $F_2$, this makes it easy to add elements.
2) As $\{0\} \cup \langle \alpha \rangle$, this makes it easy to multiply elements.
To pass between the two ways of looking at a finite field requires finding a generator, or primitive element, so we can create a "discrete log table". This is not always an easy task.
Now do the same thing with $F_3$, which will be a lot more interesting (and give you a better idea of how bad things can get when $p$ is large in the field $F_p$).
FAQ: Field Theory - Algebrais Extensions - D&F - Section 13.2 - Exercise 2, page 529
What is field theory?
Field theory is a branch of mathematics that studies the properties and structures of fields, which are mathematical systems that include operations of addition, subtraction, multiplication, and division. It also explores the relationships between different types of fields and their extensions.
What are algebraic extensions?
Algebraic extensions are extensions of a field that involve the addition of new elements to the original field through the use of algebraic operations, such as roots or coefficients of polynomials. These extensions allow for the creation of larger and more complex fields.
What does D&F stand for in "D&F - Section 13.2 - Exercise 2, page 529"?
D&F stands for "Dummit & Foote", which refers to the authors of the textbook "Abstract Algebra" that contains the exercise being referenced.
What is the significance of Exercise 2 on page 529 in Section 13.2?
Exercise 2 on page 529 in Section 13.2 is a specific problem in the textbook "Abstract Algebra" that focuses on the properties of field extensions and their corresponding algebraic operations. It is an important exercise for understanding the concepts and techniques involved in this area of mathematics.
What is the purpose of studying field theory and algebraic extensions?
The study of field theory and algebraic extensions has many practical applications, such as in cryptography, coding theory, and physics. It also has significant theoretical importance in the development of abstract algebra and its connections to other areas of mathematics, such as number theory and geometry.
