MHB Field Theory - Element u transcendental of F
Math Amateur
MHB
Field Theory - Element u transcendental over F
In Section 10.2 Algebraic Extensions in Papantonopoulou: Algebra - Pure and Applied, Proposition 10.2.2 on page 309 (see attachment) reads as follows:
10.2.2 Proposition
Let E be a field, F \subseteq E a subfield of E, and \alpha \in E an element of E.
In E let
F[ \alpha ] = \{ f( \alpha ) \ | \ f(x) \in F[x] \}
F ( \alpha ) = \{ f ( \alpha ) / g ( \alpha ) \ | \ f(x), g(x) \in F[x] \ , \ g( \alpha ) \ne 0 \}
Then
(1) F[ \alpha ] is a subring of E containing F and \alpha
(2) F[ \alpha ] is the smallest such subring of E
(3) F( \alpha ) is a subfield of E containing F and \alpha
(4) F( \alpha ) is the smallest such subfield of E
Papantonopoulou proves (1) and (2) (see attachment) and then writes:
" ... ... (3) and (4) are immediate from (1) and (2) since F[ \alpha ] \subseteq E and E is a field, F[ \alpha ] is an integral domain, and F( \alpha ) is simply the field of quotients of F[ \alpha ]. "
[Note: I do not actually follow this statement - can someone help clarify this "immediate" proof]================================================================================================
However ...
... in Nicholson: Introduction to Abstract Algebra, Section 6.2 Algebraic Extensions, page 279 (see attachment) we read:
" ... ... If u is transcendental over , it is routine to verify that
F(u) = \{ f(u){g(u)}^{-1} \ | \ f(x), g(x) in F[x] \ ; \ g(x) \ne 0
Hence F(u) \cong F(x) where F(x) is the field of quotients of the integral domain F[x]. ... ... "
***My problem with the above is that Papantonopoulou and Nicholson both give the same expression for F( \alpha ) but Nicholson implies that the relation F(u) = \{ f(u){g(u)}^{-1} \ | \ f(x), g(x) in F[x] \ ; \ g(x) \ne 0 \} is only the case if u is transcendental?
Can someone please clarify this issue for me.
Peter
Re: Field Theory - Element u transcendental over F
10.2.2 Proposition
In E let
Then
Try doing the proofs of (3) and (4) without relying on (1) and (2). (3) is infact trivial. The proof of (4) is also easy but requires a bit more work. To prove (4), let $K$ be a subfield of $E$ which contains $F$ and $\alpha$. Since a field is closed under addition and multiplication, $K$ contains $f(\alpha)$ for all $f(x)\in F[x]$. Also, any field is closed under inverses, so $K$ contains $(g(\alpha))^{-1}$ for all $g(x)\in F[x]$ whenever $g(\alpha)\neq 0$. Lastly, any field is closed under multiplication, thus $f(\alpha)(g(\alpha))^{-1}\in K$ for all $f(x),g(x)\in F[x]$ whenever $g(\alpha)\neq 0$. Thus $K$ contains $F(\alpha)$.
I think this would explain the word 'immediate' above. However, I would suggest that you shouldn't take it too seriously. Proving the four statements independently is good enough.
Peter said:
However ...
Peter
Papantonopoulu and Nicholson have not given the same definition for $F(u)$.
Papanto gives $F(\alpha)=\{f(\alpha)(g(\alpha))^{-1}:f(x),g(x)\in F[x],{g(\alpha)}\neq 0\}$ while Nicholson says that if $\alpha$ is transcendental over $F$ then $F(\alpha)=\{f(\alpha)(g(\alpha))^{-1}:f(x),g(x)\in F[x], {g(x)}\neq 0\}$
(Note that in Papanto's expression of $F(\alpha)$ we have $g(\alpha)\neq 0$ and not $g(x)\neq 0$).
Papanto's def is general; it applies regardless of whether $\alpha$ is algebraic or transcendental over $F$.
Now to see this,
Papanto says that $F(u)=\{f(u)(g(u))^{-1}:f(x),g(x)\in F[x], g(u)\neq 0\}$ regardless of whether $u$ is transcendental over $F$ or not.
When $u$ is transcendental over $F$ then the above definition conincides with that of Nicholson as then $g(u)=0\iff g(x)=0$.
Now assume $u$ is algebraic over $F$. We will show that if $g(u)\neq 0$ then $(g(u))^{-1}\in F$.
Let $m(x)$ be the minimal polynomial of $u$ over $F$. now since $g(u)$ is not zero, $m(x)$ and $g(x)$ must be relatively prime over $F[x]$. Thus there exists $a(x),b(x)$ in $F[x]$ such that $a(x)m(x)+b(x)g(x)=1$. "Substitute" $u$ in place of $x$ in the LHS of the last equation (use the evaluation map to be rigorous) to get $b(u)g(u)=1$. Thus $(g(u))^{-1}=b(u)$ and hence we have shown that $(g(u))^{-1}\in F$.
I think this would explain the word 'immediate' above. However, I would suggest that you shouldn't take it too seriously. Proving the four statements independently is good enough.Papantonopoulu and Nicholson have not given the same definition for $F(u)$.
Now to see this,
Thanks for the help Caffeinemachine.
Just one issue.
You write:
"When u is transcendental over F then the above definition coincides with $$ g(u)=0 \iff g(x)=0$$"
But ... when u is transcendental over F then there is no polynomial in F such that g(u) = 0?
Can you help further?
Peter
Peter said:
Thanks for the help Caffeinemachine.Just one issue. You write:"When u is transcendental over F then the above definition coincides with $$ g(u)=0 \iff g(x)=0$$"But ... when u is transcendental over F then there is no polynomial in F such that g(u) = 0?
No. When $u$ is transcendental over $F$ then there is exactly one polynomial $g(x)$ in $F[x]$ for which $g(u)=0$. The zero polynomial!
Try proving this: Let $g(x)\in\mathbb Q(x)$ be such that $g(\pi)=0$. Show that $g(x)=0$. The converse is obvious.
Tell me if you have any further doubts.
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
