Fields (Gravitational fields) -- Escape Velocity from the Moon
The discussion revolves around a multiple-choice question regarding the escape velocity from the Moon, specifically whether the answer is 4/81 v(esc). Participants emphasize the importance of showing work before receiving guidance, urging the original poster to explain their reasoning. They suggest calculating the escape velocity of the Moon and checking it against known values to verify correctness. Additionally, there is a recommendation to simplify the problem by using distinct symbols for different variables to avoid confusion. The conversation highlights the need for careful algebraic manipulation and understanding of the concepts involved.
jellybean-spider
The escape velocity for an object at the surface of the Earth is V(esc). The diameter of the moon is 4 times smaller than that of the Earth and the mass of the Moon is 81 times smaller than that of the Earth. What is the escape velocity of the object on the moon.
V(esc) = sqrt (2GM/R)
It's an MCQ, and I chose 4/81 v(esc). Is this correct? There isn't a marking scheme... :cry:
√2G(1/81)M/(1/4)r = √2GM/r
This is with the information that I have got from the question and then I think using proportionality I got 4/81 v(sec)
Why don't you calculate the escape velocity of the Moon from that and check online to see whether you are right?
Check your algebra. If you cancel √(GM/r) from both sides of your equation you are left with:
√(1/81)/(1/4)) = 1
which should sound (loud) alarm bells!
Hint: for practice/understanding, first solve a simple example:
If y=√x, what happens to y if, say, x increases by a factor of 25?
Then try the problem again. Don't forget to check your answer makes sense as suggested by by@PeroK.
It is too confusing using the same symbol for different variables. Add subscripts (##M_e, M_m## for Earth and Moon, etc.) or use different case (M, m, R, r) or different letters.
Likes PeroK and sysprog
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 27 ·
