- 352
- 88
A 10-year-old girl won an injunction that allowed her to receive the same priority as adults on the adult waiting list for available donated lungs.
Family of girl needing lung transplant 'excited' by ruling
One day later, a second child under 12 filed a lawsuit and also won.
Second child files suit for lung transplant, gets on list
I think the news coverage is a little thin.
In the old days, there were three lists: one for adults, one for 12-17 year olds, and one for under 12. The separate lists were because of the need to match the size of the donated lung to the recipient. Children's lungs don't work well for adults and adult lungs don't work well for children under 12.
All three lists were based on first come, first serve. You waited in line regardless of the severity of your disease. Maybe you got a lung in time - maybe you died while waiting.
There was also a chance a person could get a donor lung from a different list than their own. If an under 12 lung was available, but no under 12 recipient, the lung was offered to people on the 12-17 year old list, preferably to someone on the lower end age-wise. If there were an adult lung available, but no recipient, it could also be offered to someone on the 12-17 year old list, preferably someone on the older end. If there were no one over 12 to receive the lung, it could be offered to some on the under 12 list. Being a poor match, presumably only the sickest would go with that option. If there were no one under 18 to receive an under 12 lung, it would be offered to an adult. Once again, being a poor match, only the sickest would go that route.
Lungs from 12-17 year old donors with no recipient avaiable would go be offered to under 12 recipients first, then to adults if there were no one under 18 to receive the lung. With, of course, exceptions due to a 17-year-old probably being a better match for an adult than for a child under 6, etc.
The first come, first serve rule wasn't seen as being very efficient, since the sickest had a much more pressing need than those that could afford to wait for a lung. So they came up with a scoring system (an LAS score) with a person's position in line based on their LAS score rather than how long they had been on the list. That was a controversial move. People with high LAS scores, being the sickest, also had the lowest likelihood of a successful lung transplant, however the argument was that that was at least partially due to the fact that people near death were the most likely to accept bad matches (partial lobe transplants, mismatched size, etc). The belief was that if the sickest were higher on the list and getting good matches, their success rates would match the healthier patients.
The change was only made to one list because it seemed prudent to measure the results before making the change across the board. The procedures for the under 12 list and the 12-17 year old list remained unchanged.
In practice, success rates for patients with high LAS scores are better than they are on the first come, first serve method, but they still have significantly worse success rates for the first year than the patients with lower LAS scores. On the other hand, if they survive the first year, their survival rates do approach the survival rates of healthier patients - or perhaps it might be more accurate to say the healthier patients' survival rates approach the sickest patients' survival rates, since all lung transplant patients have bad (around 50%) five year survival rates. 10 year survival rates are very bad (around 30%). If you're to the point of getting a lung transplant, you're buying time instead of "curing" a person. Does lung allocation score maximize survival benefit from lung transplantation?
This raises all kinds of issues. Is using the LAS score a good enough system to implement across the board? Or should it be implemented with some modifications given that the one year survival rate is worse for patients with an LAS score over 60 and much worse for LAS scores over 80? And if it is implemented across the board, does that mean scrap the idea of trying to match the best size? More importantly to the judge deciding the case, is trying the experiment on just one age group discrimination against the other age groups? In fact, is using age as one of the criteria used in finding the best match discrimination?
I think its sad to see a little kid die because the probability of an appropriate lung being available is low. But if the ultimate goal is to save as many as possible, giving her an inappropriate lung when an appropriate donor is available is a bad idea - especially when she has an LAS of 78, putting her right on the border for the patients least likely to result in a successful transplant even with a well matched lung.
I think the judge made a mistake by interfering and changing a procedure he didn't really understand.
