ptownbro
- 60
When figuring out the product from a reaction using single replacement type of a reaction, we believe we understand what the elements and compounds will be produced but can't figure out how the subscripts are calculated/determined in some examples.
#1 ZnS + O2 ---> ZnO + S
#2 Fe + HCl ---> FeCl3 + H2
#3 Ca + H2O ---> Ca(OH)2 + H2
In #1, how do you get no subscript for the "S" element in the reactant?
In #2, how do you get a subscript of 3 for the "Cl" portion of the compound in the reactant?
In #3, how do you get the "OH" portion of the compound in the reactant with a subscript of 2?
Are these things you just have to memorize or is there a way to figure them out.
When dealing with a cation element or metal reacting with a compound: A + B C = B + A C
When dealing with a anion element or non-metal reacting with a compound: A + B C = B A + C
We based our attempts on solutions from other examples.
For example, in the equation below we used the "cation" form from above to determine the product since Cu has a positive charge. Then, we figured the subscript for Cu(NO3) becomes "2" based on directions in the homework. In short, we determined that Cu has +2 charge and NO3 has a -1 charge. To "balance" them you turn it into 2 molecules to get the charge to -2.
Cu + AgNO3 = Ag + Cu(NO3)2
However, not sure that makes sense since we thought that compound was supposed to be ionic not neutral (or balanced).
Figuring Subscripts in Single Replacement Equations
