Filter Linear Phase Property for non-integer time delays
In summary: The main reason to want to preserve the input signal is so that the output signal will still look like the original signal, with only a delay in time and modification in amplitude.
Master1022
611
117
What does it mean when the signal is 'reproduced at the output'?
Delay
Hi,
I just have a quick question regarding the linear phase property of filters. It might be easier to provide some context before getting to the question, but feel free to skip to the bottom.
Consider a system input as a discrete sequence obtained by sampling at [itex]t = 0, T, . . . , kT[/itex] from an underlying continuous-time function [itex] cos(\omega t + \phi) [/itex]. Thus the input is:
$$x[k] = cos(\omega kT + \phi)$$
and the output of the system, with a linear phase response, is:
$$y[k]=Acos(\omega kT +\phi + \gamma)$$
where [itex] A [/itex] is the gain of the system. If the phase response [itex] \gamma [/itex] is linear, i.e. [itex] \gamma = −\omega k_0 T [/itex], then
$$ y[k] = A cos(\omega(k − k_0 ) T + \phi) $$
That is, the signal waveform has been preserved at the output, with only a delay in time and modification in amplitude. "Notice that when [itex] k_0 [/itex] is not an integer, then the time delay is not integer multiple of the sampling period [itex]T[/itex] . In this case, the input samples are not exactly reproduced at the output."
Question: Why is this final statement in quotation marks true?
I understand that if [itex] k_0 [/itex] is not an integer, then the time delay is not an integer multiple of the sampling period, but I don't understand how this means that the input samples are not exactly reproduced at the output? I feel like this answer should be very simple, but for some reason, this statement doesn't make any sense to me.
Many thanks in advance for any help.
Master1022 said:
Homework Statement:: What does it mean when the signal is 'reproduced at the output'?
Relevant Equations:: Delay
Hi,
Consider the input samples x[k] = cos(ωkT+Φ), let's assume that your lucky and one of the samples yields x[k] = -1 because ωkT+Φ = π for some value of k.
For the samples to be delayed without change there must be a k that yields y[k] = A cos(ω(k-ko)T+Φ) = -1, so ω(k-ko)T+Φ = π given that ωkT+Φ = π. Which means ko must be an integer. If the delay isn't a multiple of the sample period you may miss and get the nearest sample to -1 at -0.99, for example. It will still look sinusoidal, but not with exactly the same sample values.
Many thanks. Okay, this is starting to make more sense. Why do we want to preserve the input signal though? If we have a linear phase response which can arise from an FIR filter, wouldn't the filter have some sort of objective (e.g. LPF, HPF, etc.) that would alter the signal?
Apologies if this is very obvious and I do appreciate you taking the time to help me out.
Yea, I don't know. I seriously doubt that any practicing engineer will assume that these systems stay in phase like that. If they do, it would be a key part of the system, like feedback in a phase-locked loop or such. Delays in real systems aren't as stable as the mathematical equations that show up in homework problems. Nearly every sampled data system that I've heard of operates below the Nyquist limit and ignores most of the dynamics at the sample rate.
Having said that, jitter at the sampling rate is a huge deal that lots of people care about. There is some impressive engineering in making low jitter samplers. Sampling jitter appears as noise in the baseband. Also, if it's really bad it will add phase shifts to the feedback systems (like variable latency in real time operating systems, for example).
I'm sure there are others with more DSP experience that can comment.
Related to Filter Linear Phase Property for non-integer time delays
1. What is the definition of linear phase property for non-integer time delays?
The linear phase property for non-integer time delays refers to the characteristic of a filter where the output signal has a linear phase response even when there is a non-integer time delay in the input signal. This means that the phase of the output signal is directly proportional to the frequency of the input signal, regardless of any time delay.
2. Why is the linear phase property important in signal processing?
The linear phase property is important in signal processing because it ensures that the output signal is an accurate representation of the input signal, without any distortion caused by phase shifts. This is particularly useful in applications where precise timing and synchronization is critical, such as in audio and video processing.
3. How is the linear phase property achieved in a filter for non-integer time delays?
The linear phase property can be achieved in a filter for non-integer time delays by using a filter design technique known as the Parks-McClellan algorithm. This algorithm allows for the design of a filter with a linear phase response, even when there is a non-integer time delay in the input signal. Other techniques such as frequency sampling and windowing can also be used to achieve the linear phase property.
4. What are the benefits of using a filter with linear phase property for non-integer time delays?
Using a filter with linear phase property for non-integer time delays can provide several benefits, including improved accuracy and precision in signal processing, reduced distortion and artifacts in the output signal, and better control over the phase response of the filter. This can result in better overall performance and quality in applications such as audio and video processing, communication systems, and biomedical signal processing.
5. Are there any limitations or drawbacks to using a filter with linear phase property for non-integer time delays?
While the linear phase property is desirable in many applications, there are some limitations and drawbacks to consider. One limitation is that achieving a linear phase response may require a more complex and computationally intensive filter design process. Additionally, in some cases, the linear phase property may not be achievable for all frequencies, leading to some distortion in the output signal. It is important to carefully consider the trade-offs and requirements of a specific application when deciding whether to use a filter with linear phase property for non-integer time delays.
  • Electrical Engineering
  • Computing and Technology
