Filtered AC V measurement with multimeter
  • Thread starter Gunther_Guss
In summary, measuring the voltage of filtered alternating current (AC) with a multimeter involves using the device to assess the effective or RMS (root mean square) value of the AC voltage after it has passed through a filtering circuit. This process typically requires setting the multimeter to the appropriate AC voltage setting and ensuring that the probes are correctly placed across the output of the filtered circuit. Proper calibration and understanding of the multimeter's specifications are essential for accurate readings, as filtered AC can often contain residual ripple voltage that may affect measurement accuracy.
Gunther_Guss
TL;DR Summary
What result does multimeter show when measuring filtered AC V ? is it Vave or Vrms of the voltage ripple ? And whats the formulas to calculate this ? Thanks.
What does the manual say?
Gunther_Guss said:
TL;DR Summary: What result does multimeter show when measuring filtered AC V ? is it Vave or Vrms of the voltage ripple ? And whats the formulas to calculate this ? Thanks.
DMMs will generally show Vrms on their ACV setting, but as @Borek says it's always best to check the Owner's Manual.
Likes Gunther_Guss
I think it measures Vrms cause when i try to measure it by oscilloscope i get the same result as Vrms, but what i wanted to know is that what result does multimeter show when measuring filtered AC V after rectification cause i want to know whats the Vp/Vmax of its wave, oscilloscope only shows it's ripple voltage, even though first mili second after we input the voltage source it'll show us the whole wave or its Vmax. I want to calculate this by only know what the result from the multimeter, thanks.
You mean, AC component on the buffer cap?
That's quite a rabbit hole, with plenty of harmonics and load-dependent voltages
In general, that's not really for (cheap) DMMs.
Likes DaveE
Multimeters will by convention always attempt to show the RMS value of a signal. However, most cheaper DMM will simply assume that what you are measuring is a pure sine wave and then calculate the RMS value, meaning the shown value is not going to be accurate for non-sinusoidal signals.
More expensive multimeters will attempt to actually measure the RMS value directly, meaning they should show the correct value even if you are measuring say a triangular wave. Most of these multimeters will have some text on them saying e.g., "TrueRMS". However, all instruments have limitations, meaning even a TrueRMS multimeter is not going to be accurate if you are trying to measure something that is outside its specified capability. For example, if the frequency of the signal is too high or, as could be the case, here it contains high-frequency components (which might be the case for e.g., a square wave)
So, just to repeat what was stated above, you need to check the manual.
Generally speaking, for more complex signals you should always use an oscilloscope and/or a spectrum analyser if you need accurate values.
Likes DaveE
If you have an analogue multimeter, hence slow to respond, when you connect it to DC-with-ripple it will read the average value. This is not quite the same as RMS but in this case where the ripple is small, probably not greatly in error. If you connect the multimeter via a capacitor, that will remove the DC component and you can use the multimeter on its AC scale. This will give an RMS ripple value assuming a sinusoidal ripple. You can find the peak value of the DC-with-ripple waveform if wished by shunting a capacitor across the meter when it is on a DC voltage scale.
If using an electronic multimeter, there is always the annoyance of it being either too rapid to reliably average the waveform being measured or alternatively, using a DC range, the electronics might capture the peak rather than the average.
FAQ: Filtered AC V measurement with multimeter
What is a filtered AC V measurement on a multimeter?
A filtered AC V measurement on a multimeter refers to the process of measuring the AC voltage while filtering out any high-frequency noise or interference. This is achieved by using a low-pass filter that allows the desired AC signal to pass through while attenuating the unwanted high-frequency components.
Why is filtering important in AC voltage measurements?
Filtering is important in AC voltage measurements because it ensures the accuracy of the readings by removing high-frequency noise and transient signals that can distort the measurement. This is particularly crucial in environments with a lot of electronic equipment, where electromagnetic interference (EMI) can be prevalent.
How do I activate the filtered AC V measurement mode on my multimeter?
The procedure to activate the filtered AC V measurement mode varies depending on the make and model of the multimeter. Generally, you can find this feature in the advanced settings or functions menu. Refer to the user manual of your specific multimeter for detailed instructions on how to enable this mode.
What types of applications benefit from using filtered AC V measurements?
Filtered AC V measurements are beneficial in applications where precision is critical and where high-frequency noise is a concern. Examples include audio equipment testing, power supply diagnostics, and any sensitive electronic circuitry where accurate voltage readings are essential for performance and troubleshooting.
Can all multimeters perform filtered AC V measurements?
No, not all multimeters have the capability to perform filtered AC V measurements. This feature is typically found in higher-end or specialized multimeters designed for professional and industrial use. When purchasing a multimeter, check the specifications to ensure it includes a filtered AC measurement mode if this is a requirement for your applications.
