Filtering certain wavelengths from the camera RGB videostream
In summary, Using ordinary CCTV cameras to grab color pictures in RGB format makes it impossible to determine the wavelength of light at a particular pixel. A software solution is not possible as the RGB values do not contain information about specific wavelengths, and hardware solutions such as IR pass filters are necessary. The RGB color model is not able to distinguish between visible and infrared light, making it impossible to filter out only infrared light using RGB values. The RGB signals from a camera represent the signal needed to produce a desired color sensation, but not necessarily a specific wavelength of light. Therefore, it is not possible to convert RGB values into wavelengths using a mathematical formula.
o1234567890
Hello,
We are using ordinary CCTV cameras to grab color pictures. The representation of the picture in our image processing application is in RGB format.
Is it possible to determine wavelength of the light at particular pixel from RGB values ? The purpose is to cut out all the white light and keep only infrared spectrum (above 850nm). We need software solution, because hardware solution (like IR pass filters on lenses) is not acceptable for us.
Thanks for your advices.
bandpass filter
billiards said:
bandpass filter
We can't use hardware filters. Our solution must be done completely in a software.
When the RED light comes to the CCD sensor, the CCD produces value RGB=[255,0,0], the GREEN light is [0,255,0] and so on ...
The problem is that when IR light of frequency approximately 850-900 nm comes to the CCD sensor, the sensor sees the light as a grayscale, that meas RGB value is for instance [5,5,5].
We are looking for a mathematical formula, using which we will be able to convert RGB value into the wavelength.
That means RGB value of [255,0,0] will be converted to 700 nm for instance, and RGB value infrared light will be converted to 850 nm.
I don't think what you are wanting to do is possible with a RGB signal.
The RGB color model is an additive color model in which red, green, and blue light are added together in various ways to reproduce a broad array of colors.
http://en.wikipedia.org/wiki/RGB_color_model"
Not only that, but red is visible red not infrared.
A software solution is not possible. The information isn't there...you don't know anything about the specific wavelengths the illumination is composed of, only the total intensity of illumination in three bands (for a color camera) from the visual range. Any IR signal is contamination that got through the color filters and is indistinguishable from visible light.
It's not an issue of it being hard or computationally expensive, that information just doesn't exist in the output of the camera. Your only options are to use a real hardware IR-pass filter on the camera, or to do something completely different from what you described.
There is some very muddled thinking going on here.
For a start, the basic answer to the question is no.
The following only applies to additive (TV, type) colour reproduction: film is messy and different.
Analysis:
Colour imaging systems use three sensors with analysis curves which are definitely not just 'Red', 'Green' and 'Blue'. All three sensors cover a wide range of wavelengths and match, as closely as practicable, the eye's response with its three colour sensors.
See this Wikki link http://en.wikipedia.org/wiki/CIE_1931_color_space. You percieve a colour (note- not wavelength) because of the relative levels of the signals from the three (very broad band) sensors. These signals are not called RGB but xyz - they are reddish, greenish and bluish, if you like but R, G and B signals only emerge from the process when you want to synthesise a colour. Many different combinations of light of different wavelengths will give you the same subjective 'colour' response. There is no reason to expect to perceive infra red as equal combinations of R,G and B - there is zero response of the blue(ish) sensors to i.r..
Synthesis:
It is possible to synthesise colours which will match the original, subjectively, using suitable combinations of levels of Red, Green and Blue light (Primaries), produced by, say, the phosphors on a TV screen and added together. To get a bright picture, these primaries may well not be 'spot' wavelengths. The RGB signals from the camera (etc) represent the signal which need to be applied to three phosphors (or equivalent) to produce the desired colour sensation.
If you are told that a certain RGB combination was produced from a single wavelength of light then you can work out that wavelength (Look at the CIE chart on the Wikki link) - but other parts of a real picture could have the same RGB combination. So you could not say that you could 'filter' out a particular wavelength - just eliminate a certain colour.
You could identify areas of a picture which were dominated by 'generally far red' signals, where X is much higher than Y and Z, but that's all.
FAQ: Filtering certain wavelengths from the camera RGB videostream
What is the purpose of filtering certain wavelengths from the camera RGB videostream?
The purpose of filtering certain wavelengths from the camera RGB videostream is to selectively capture or exclude specific colors or light frequencies from the image being recorded. This can be used for various purposes such as enhancing certain colors or removing unwanted reflections or glare.
How does filtering wavelengths work in a camera?
In a camera, filtering wavelengths involves using a physical filter or a software algorithm to block or pass certain wavelengths of light. This can be achieved through the use of colored filters or by adjusting the sensitivity of the camera's sensor to different wavelengths.
What are the benefits of filtering certain wavelengths from a camera RGB videostream?
Filtering certain wavelengths from a camera RGB videostream can provide several benefits such as improving image clarity and contrast, reducing noise and interference, and creating dramatic or artistic effects. It can also help in scientific or industrial applications where specific wavelengths need to be isolated for analysis.
Can filtering wavelengths affect the overall image quality?
Yes, filtering wavelengths can affect the overall image quality as it alters the colors and light frequencies captured by the camera. Depending on the type and intensity of the filter used, it can result in color shifts, reduced sharpness, or loss of detail in certain areas of the image.
Is it possible to filter out multiple wavelengths at once?
Yes, it is possible to filter out multiple wavelengths at once by using a combination of filters or by using a software algorithm that can selectively remove multiple wavelengths. This technique is often used in scientific or medical imaging to isolate and enhance specific features or structures in the image.
