Baibhab Bose
- 34
- 3
- Homework Statement
- A heat engine is operated between two bodies that are kept at constant pressure. The constant-
pressure heat capacity Cp of the reservoirs is independent of temperature. Initially the
reservoirs are at temperatures 300 K and 402 K. If, after some time, they come to a common
final temperature Tf , the process remaining adiabatic, what is the value of Tf (in Kelvin) ?
- Relevant Equations
- from 1st law, dQ=dU+PdV. Not sure the ideal gas equation or the P*V^(gamma)=K equation would be applicable here or not since they are for gases.
*Here, no mention of these reservoirs being a gas, so I'm not sure if I can use the PV=nRT or the P*V^(gamma)=K equation.
SO I am left with only the 1st law.
If I can write dQ1( going out from object 1)= Cp (indep of T)*(Tf-T1)
dQ2(coming into the object 2)= Cp*(T2-Tf), where T2>T1; given.
Then is it right to assume that since the process is adiabatic, no heat is lost to the environment an the heat which goes out from object 1 would reach Object 2? Then dQ1=dQ2 would be logical. But from this equality the solution is not correct.
And what is the significance of the pressure being constant?
I can't get any further.
