Final velocities with the inclusion of air resistance
In summary, the conversation discusses the final speed of two rocks thrown off a cliff, one launched below the horizontal and the other above. It is stated that without air resistance, both rocks would hit the ground at the same speed, but with air resistance, the rock launched below the horizontal would have a greater final speed. The possibility of both rocks reaching terminal velocity and hitting the ground at the same speed is also mentioned. The conversation then explores using a conservation of energy argument to prove which path dissipates more energy and whether it is possible for air resistance to dissipate less energy over the longer path.
sohjau
Two rocks are thrown off a cliff at the same initial speed, v. The first rock is launched at an angle, ϴ, directed below the horizontal. The second rock is launched above the horizontal at the same angle. If air resistance is negligible, the rocks would hit the ground at the same final speed. Including air resistance, which rock would have a greater final speed? Solve using a conservation of energy argument.
If you make the angle 90°, you only have to think about the vertical components. Ignoring air resistance, rock 2 would reach the same speed as it was launched as once it reaches its original altitude. That would result in both the rocks having the same final speed. Including air resistance, rock 2 would not reach as high due to the drag force and would also not reach its initial speed at its original altitude. Therefore, rock 1 would have the greater final speed. Would that be the case for every angle? If the cliff is high enough, won't the rocks reach terminal velocity and hit the ground at the same final speed as well? How does one solve this using a conservation of energy argument?
Just consider which path dissipates more energy.
Terminal velocity is never quite reached, in theory.
Although it is intuitively obvious, a rigorous proof is not that simple. How would you prove which path dissipates more? The horizontal component of speed complicates things. The whole trajectory is different.
I agree, but is there an argument that makes it possible for air resistance to dissipate less energy over the longer path?
Inability to argue that it could happen does not constitute proof it could not.
FAQ: Final velocities with the inclusion of air resistance
What is air resistance?
Air resistance, also known as drag, is the force that opposes the motion of an object through the air. It is caused by the collisions and interactions between the object and the molecules in the air.
How does air resistance affect an object's final velocity?
Air resistance can decrease an object's final velocity by causing it to slow down. This is because the force of air resistance acts in the opposite direction to the motion of the object.
Can air resistance ever increase an object's final velocity?
In some cases, air resistance can actually increase an object's final velocity. This is typically seen with objects that have a streamlined shape, such as airplanes, where the force of air resistance can actually help to propel the object forward.
How is air resistance calculated?
Air resistance is calculated using the drag equation, which takes into account factors such as the object's shape, size, and speed, as well as the density and viscosity of the air. This equation can be quite complex and is typically solved using specialized software or computer simulations.
Can air resistance be ignored in calculations?
In most cases, air resistance cannot be ignored in calculations as it can have a significant impact on an object's final velocity. However, in certain scenarios, such as when an object is moving at low speeds or in a vacuum, air resistance may be negligible and can be ignored.
