Final velocity of a ball down a ramp.
In summary, the conversation discusses the use of two equations to calculate the final velocity of a ball dropped down a ramp with no friction. The equations yield the same answer, but it is questioned whether the acceleration will always be 9.8 regardless of the ramp's shape. It is suggested that the normal force may partially oppose the force of gravity, leading to a different acceleration. Additionally, the fact that the ball may be rolling also affects the final velocity.
HHH
34
If a ball is dropped down a ramp of any shape, will the acceleration always be 9.8 assuming there is no friction.
I know you can use mgh = 1/2mv^2 to solve for velocity, but can you use vf^2 = vi^2 + 2(a)(d)
If you use both equations you get the same answer for final velocity at the bottom of the ramp. However is the acceleration always 9.8 no matter what the shape of the ramp is?
I don't see any attempt to answer the question here. Think about forces.
Does it have to do with the normal force decreasing the force of gravity?
Well, it doesn't decrease it, but it does partially oppose it.
so the acceleration would not be 9.8? if not why can you use both equations?
mgh = 1/2mv^2
(2)x(9.8)x(3) = 1/2 (2) v^2
v = 7.6m/s
vf^2 = vi^2 + 2ad
vf^2 = 0 + 2(9.8)(3)
v = 7.6m/s
mgh = 1/2mv^2
v = 7.6m/s
vf^2 = vi^2 + 2ad
v = 7.6m/s
Ignoring the fact that it's a ball for the moment, just treating it as a zero friction ramp, those (that) equation only tells you the final velocity. It doesn't tell you how long it takes to get there. The final velocity is the same whether dropped straight down or going down a ramp. It only depends on the PE lost. But it takes longer down the ramp, so the acceleration is less.
If it is a rolling ball, that starts off not rotating, then there is another issue. At the end some of the KE will be in rotational energy, so the linear velocity will be less.
Likes AAAA and HHH
Thank you.
FAQ: Final velocity of a ball down a ramp.
1. What is the equation for calculating the final velocity of a ball down a ramp?
The equation for calculating the final velocity of a ball down a ramp is v = √(2gh), where v is the final velocity, g is the acceleration due to gravity (9.8 m/s²), and h is the height of the ramp.
2. How does the angle of the ramp affect the final velocity of the ball?
The angle of the ramp affects the final velocity of the ball by changing the acceleration due to gravity. The steeper the angle, the greater the acceleration due to gravity and therefore the greater the final velocity of the ball.
3. How does the mass of the ball affect the final velocity down a ramp?
The mass of the ball does not affect the final velocity down a ramp. According to the equation v = √(2gh), the mass of the ball is not a factor in determining the final velocity.
4. Can the final velocity of a ball down a ramp be greater than the initial velocity?
Yes, the final velocity of a ball down a ramp can be greater than the initial velocity if the ramp is angled steeply enough. This is because the acceleration due to gravity will increase the velocity of the ball as it travels down the ramp.
5. How does friction affect the final velocity of the ball down a ramp?
Friction can affect the final velocity of the ball down a ramp by slowing it down. If there is significant friction between the ball and the ramp, it will decrease the acceleration of the ball and therefore reduce the final velocity.
