Final velocity of satellite that falls from orbit
In summary: I guess that is enough for now.In summary, the satellite has potential energy at 100,000 meters and kinetic energy after it crashes into the Earth.
jcruise322
36
Hey, how's it going! Just a little confused about how to do the problem below. Any help would be appreciated!
1. Homework Statement
A satellite of mass m=100,000 kg is moving around the Earth in a circular orbit at an altitude of 100,000 feet above the surface.
If the satellite were stopped and released from rest, what would its final velocity be before it hit the earth?
Assume no dampening force.
mv^2/r=G*M1*M1/r^2
mv^2/2=G*M1*M2/r
PE=mgh
KE=.5*m1*v^2
I used equation 2 on the list, plugged all the variables in, and got 11,094 m/s. I have no idea if it is correct however!
Regards,
JT
Try not to just insert things into formulas. This is not what physics is about. Physics is about using reasoning and logic to arrive at a result.
What does the second formula tell you? Why do you think it is applicable to this situation? What physical principles are you using?
Likes jcruise322
Equation 2 relates the speed and the radius for a satellite in a circular orbit, but we're told the satellite is released from rest.
What happens when the satellite falls, is that all its potential energy is converted to kinetic energy.
Likes jcruise322
No it doesn't. It is off by a factor of two. Equation 1 does so (by equating the centripetal force required with the gravitational force).
Likes jcruise322
So...I will try to think about this in the most logical way, I guess. So, Earth and the satellite are part of the system. I am not sure if we can treat gravity's acceleration as equaling 9.81 m/s/s here...can we just use 9.8 as an approximation? Anyway, the satellite has PE at 100,000 meters proportional to the distance between the satellite and the center of mass of the earth. PE=G*M1*M2/r as stated in my physics textbook...this has to all be translated into kinetic energy at the Earth's core, (r=Radius of earth+altitlude of satellite) the formula being equal to .5m*v^2/2. however, using this formula this way assume that there is still PE when the satellite arrives at the earth. So, PE=KEf+mgh (mgh being at the Earth's surface; h=radius of the earth).
Sooooo...after plugging and chugging, I get 11,005.86 m/s as an approximation. That is really frigging fast, holy S***. Anyway, Halp? Orodruin, what do you think? Does this make sense?
Is the satellite orbiting at 100,000 feet (from the problem statement) or 100,000 meters? One altitude is in space, the other is within the upper atmosphere.
100,000 meters NOT feet! Sorry, I made a transcription error! Yup, this baby is in space, Streamking!
*Steamking...xD
This is only an approximation which is valid if the gravitational field is homogeneous and of the same strength as at the Earth's surface. You cannot apply it generally.
But the satellite is not reaching the core, it crashes into the surface first! Also, the potential with this definition is relative to infinity, not with respect to the center of the Earth! As a result of this, you are getting a number which is simply very close to the escape velocity, i.e., the velocity required to escape the Earth's gravitational field.
Likes jcruise322
Exactly! Did you read all of what I said? I said that it didn't.
jcruise322 said:
PE=KEf+mgh
Anyway, if you think that I am wrong, please give me your opinion. I have done all that I can do for now.
Read the last part of Orodruin's post. Your equation 2 is for an object falling from infinity to radius r. There's no point memorising equations if you don't remember the conditions under which they apply and what the variables represent.
Think about the change in PE as it falls 100km.
Of course, 100km is quite small compared with the radius of the Earth, so gravitational acceleration won't change much over that drop. Using mgh would at least give you a fairly tight upper bound on the answer, useful as a check.
Likes jcruise322
Yo, I think I got this figured out. I would use energy conservation.
Ei=Efinal.
The satellite only has potential energy when it is stopped given by-(G*m1*m2)/(r1). r1 equals radius of Earth + altitude.
If we ignore drag, part of this PE is converted into KE, .5*m*v^2, and the other goes into "potential energy" or more precisely, the work required to move a stationary object an infinite distance away from Earth at the Earth's radius r, so PEfinal=-(G*m1*m2)/r2. r2=radius of earth.
Plugging in my numbers and solving for V:
We geeeeet: 1390.1 m/s
Yata! There we go! :) I think this sounds more reasonable...right?
Sorry, my final equation is: -(GM1)/r1=.5*v^2-G(M1)/r2
Ei=Efinal.
Check it yourself using the tip I gave you in post #11.
Likes jcruise322
Using mgh=.5*m*v^2
vf=1400 m/s.
Pretty close to 1390.1 :)
FAQ: Final velocity of satellite that falls from orbit
What causes a satellite to fall from orbit?
A satellite can fall from orbit due to a decrease in its velocity or a change in its trajectory. This can be caused by atmospheric drag, gravitational forces from other celestial bodies, or intentional maneuvers by ground control.
How is the final velocity of a falling satellite calculated?
The final velocity of a satellite falling from orbit can be calculated using the equation vf = √(vi^2 + 2ad), where vf is the final velocity, vi is the initial velocity, a is the acceleration due to gravity, and d is the distance traveled.
Can the final velocity of a falling satellite be controlled?
Yes, the final velocity of a falling satellite can be controlled through various methods such as firing thrusters or deploying a parachute to slow its descent. However, these methods may not always be successful and the final velocity may still be affected by external factors.
What is the impact of a satellite falling from orbit?
The impact of a satellite falling from orbit can vary depending on its size and composition. In some cases, the impact may result in damage to property or harm to living beings. Measures are often taken to ensure that satellites are safely deorbited or disintegrated upon reentering the Earth's atmosphere.
Can a satellite be brought back to orbit after falling from orbit?
In most cases, it is not possible to bring a satellite back into orbit after it has fallen from orbit. Once a satellite has lost its orbital velocity and entered the Earth's atmosphere, it will continue to fall and burn up due to atmospheric friction. However, in rare cases, a satellite may be retrieved and repaired if it falls to Earth without disintegrating.
