Final velocity problem involving a roller coaster changing height
In summary, the conversation discusses the calculation of the velocity of a roller coaster at point A, given its mass, velocity at point C, and the heights at points A, B, C, and D. The correct answer is the square root of two, which is found by applying the conservation of mechanical energy. The conversation also mentions the equations for potential energy (Ep) and kinetic energy (Ek).
AHUGEMUSHROOM
A roller coaster (475kg) passes point C with a velocity of 10.0 ms-1, calculate the velocity of the roller coaster at point A.
mass = 475 kg
velocity at C = 10 ms-1
height at A = 30m
height at B = 0m
height at C = 25m
height at D = 12m
Ep = mgh
Ek = 1/2mv^2
The trolley is moving from Point C towards point A.
*My method of finding out the answer was incorrect so you might want to ignore the following*
I substituted the data given into Ep = mph (h at point A) and got Ep = 139,650J
Then said Ep = Ek and subbed the data into Ek and got final velocity = 24.5 ms-1
*THE CORRECT ANSWER IS THE SQUARE ROOT OF TWO*
Apply the conservation of mechanical energy. What does it say?
ehild
I'm sorry but we have not come across mechanical energy yet and I am sure it was not used in working out the answer.
So what are Ep and Ek?
ehild
I would approach this problem by using the conservation of energy principle. This principle states that energy cannot be created or destroyed, only transferred from one form to another. In this case, the potential energy (Ep) at point C is converted into kinetic energy (Ek) at point A.
First, we can calculate the potential energy at point C using the formula Ep = mgh, where m is the mass of the roller coaster (475kg), g is the acceleration due to gravity (9.8 ms-2), and h is the height at point C (25m). This gives us Ep = (475kg)(9.8 ms-2)(25m) = 116,875J.
Next, we can use the conservation of energy principle to equate Ep at point C to Ek at point A. This can be written as Ep = Ek. Substituting the values we know, we get 116,875J = 1/2(475kg)v^2, where v is the final velocity at point A.
Solving for v, we get v = √(2(116,875J)/475kg) = 24.5 ms-1. This is the correct answer for the final velocity at point A.
It is important to note that the height at point B is not relevant in this problem since the roller coaster is not moving at this point. We only need to consider the change in height from point C (25m) to point A (30m).
In conclusion, using the conservation of energy principle, we can calculate the final velocity of the roller coaster at point A to be 24.5 ms-1. This approach is more accurate and reliable than using incorrect methods or formulas.
FAQ: Final velocity problem involving a roller coaster changing height
1. What is the formula for calculating final velocity in a roller coaster problem involving a change in height?
The formula for calculating final velocity in this scenario is: Vf = √(Vi^2 + 2gh), where Vf is the final velocity, Vi is the initial velocity, g is the acceleration due to gravity (9.8 m/s^2), and h is the change in height.
2. How does the change in height affect the final velocity in a roller coaster problem?
The change in height directly affects the final velocity in a roller coaster problem. The greater the change in height, the greater the final velocity will be. This is because the roller coaster gains potential energy as it moves higher and then converts it into kinetic energy as it moves down the track.
3. How does the initial velocity impact the final velocity in a roller coaster problem?
The initial velocity also plays a role in determining the final velocity. If the roller coaster starts at a higher initial velocity, it will have a higher final velocity. However, the change in height will have a greater impact on the final velocity than the initial velocity.
4. Can the final velocity ever be negative in a roller coaster problem involving a change in height?
Yes, the final velocity can be negative in this scenario. This would occur if the roller coaster starts with an initial velocity in the downward direction and then moves to a lower height. In this case, the roller coaster would slow down and its final velocity would be negative, indicating that it is moving downwards.
5. How does the mass of the roller coaster affect the final velocity in this problem?
The mass of the roller coaster does not have a direct effect on the final velocity in this problem. The final velocity is determined by the change in height and the initial velocity, as well as gravity. However, a heavier roller coaster may require more energy to move through the track and may experience more friction, which could slightly impact the final velocity.
