Find $a+2b+3c$ Given $(x-1)^3$ is a Factor of $x^{10}+ax^2+bx+c$
  • MHB
  • Thread starter Albert1
In summary, when $(x-1)^3$ is a factor of a polynomial, it means that the polynomial can be divided by $(x-1)^3$ with a remainder of zero. The values of $a$, $b$, and $c$ can be found by substituting $x=1$ into the polynomial. The values of $a$, $b$, and $c$ can be negative and $(x-1)^3$ is not the only factor of the polynomial. To find the roots of the polynomial, we can use polynomial long division to divide by $(x-1)^3$.
Albert1
1,221
if $(x-1)^3 $ is a factor of $x^{10}+ax^2+bx+c$
please find :$a+2b+3c$
Mathematics news on Phys.org
Hello.
I know that the idea is not very brilliant, but:
[tex]\dfrac{x^{10}+ax^2+bx+c}{x-1}=x^9+x^8+x^7+x^6+x^5+x^4+x^3+x^2+(a+1)x+(a+b+1)+\dfrac{a+b+c+1}{x-1}[/tex]
Therefore:
[tex]a+b+c+1=0[/tex]. (1)
[tex]\dfrac{x^9+x^8+x^7+x^6+x^5+x^4+x^3+x^2+(a+1)x+(a+b+1)}{x-1}=x^8+2x^7+3x^6+4x^5+5x^4+6x^3+7x^2+8x+(a+9)+\dfrac{2a+b+10}{x-1}[/tex]
Therefore:
[tex]2a+b+10=0[/tex]. (2)
[tex]\dfrac{x^8+2x^7+3x^6+4x^5+5x^4+6x^3+7x^2+8x+(a+9)}{x-1}=x^7+3x^6+6x^5+10x^4+15x^3+21x^2+28x+36+\dfrac{a+45}{x-1}[/tex]
Therefore:
[tex]a+45=0[/tex]. (3)
For (1), (2) and (3):
[tex]a=-45[/tex]
[tex]b=80[/tex]
[tex]c=-36[/tex]
[tex]a+2b+3c=7[/tex]
Regards.
A slightly different method:
[sp]
Let \(\displaystyle f(x) = x^{10} + ax^2 + bx + c\). If $(x-1)^3$ is a factor of $f(x)$ then $x=1$ is a triple zero of $f(x)$, which means that $f(x)$ and its first two derivatives must all vanish when $x=1$. Therefore $$f(1) = 1 + a + b + c = 0, \qquad(1)$$ $$f'(1) = 10 + 2a + b = 0, \qquad(2)$$ $$f''(1) = 90 + 2a = 0 \qquad(3).$$ These are the same three equations that mente oscura found, leading to the same solution $a+2b+3c = 7.$[/sp]
$(x-1)^3$ is a factor of $P(x) = x^{10}+ax^2 + bx + c$
so $x^3$ is a factor of $P(x+1) = (x+1)^{10}+ a(x+1)^2+b(x+1) + c$
so in the above expression coefficient of $x^2$, x and constant term shall be zero
coefficient of $x^2$ = $\binom{10}{2}+ a = 0= 45 + a = 0 $
coefficient of $x$ = 10 + 2a + b = 0
constant term = 1 + a + b + c = 0
these are same equations as above 2 that is mente oscuras's and opalg's and so the ans are same as well
Based on the given information, we can use the factor theorem to determine the value of $a+2b+3c$. Since $(x-1)^3$ is a factor of $x^{10}+ax^2+bx+c$, we know that when $x=1$, the polynomial $x^{10}+ax^2+bx+c$ will equal zero. This means that $a+2b+3c$ must also equal zero.
To find the value of $a+2b+3c$, we can plug in $x=1$ into the polynomial $x^{10}+ax^2+bx+c$ and set it equal to zero. This gives us the equation $1^{10}+a(1)^2+b(1)+c=0$ or simply $a+b+c=0$.
Next, we can use the factor theorem again to determine the value of $a+2b+3c$. Since $(x-1)^3$ is a factor of $x^{10}+ax^2+bx+c$, we can rewrite the polynomial as $(x-1)^3Q(x)$, where $Q(x)$ is a polynomial of degree 7. This means that $x^{10}+ax^2+bx+c=(x-1)^3Q(x)$.
Expanding this equation, we get $x^{10}+ax^2+bx+c=x^3Q(x)-3x^2Q(x)+3xQ(x)-Q(x)$. Since we know that $x^{10}+ax^2+bx+c$ is equal to zero when $x=1$, we can plug in $x=1$ to this equation and set it equal to zero. This gives us the equation $1^3Q(1)-3(1)^2Q(1)+3(1)Q(1)-Q(1)=0$ or simply $Q(1)=0$.
Since $Q(x)$ is a polynomial of degree 7, we can rewrite it as $Q(x)=q_7x^7+q_6x^6+...+q_1x+q_0$. Plugging in $x=1$ to this equation, we get $Q(1)=q_7(1)^7+q_6(1)^6+...+q_1(
FAQ: Find $a+2b+3c$ Given $(x-1)^3$ is a Factor of $x^{10}+ax^2+bx+c$
What does it mean for $(x-1)^3$ to be a factor of $x^{10}+ax^2+bx+c$?
When we say that $(x-1)^3$ is a factor of a polynomial, it means that when we divide the polynomial by $(x-1)^3$, the remainder is equal to zero. In other words, $(x-1)^3$ is one of the factors that can be multiplied together to get the original polynomial.
How do I find the values of $a$, $b$, and $c$ from the given information?
Since $(x-1)^3$ is a factor of $x^{10}+ax^2+bx+c$, we can use the remainder theorem to find the values of $a$, $b$, and $c$. This theorem states that when a polynomial $f(x)$ is divided by $(x-a)$, the remainder is equal to $f(a)$. In this case, we can substitute $x=1$ into the polynomial $x^{10}+ax^2+bx+c$ to get the values of $a$, $b$, and $c$.
Can the values of $a$, $b$, and $c$ be negative?
Yes, the values of $a$, $b$, and $c$ can be negative. This is because the polynomial $x^{10}+ax^2+bx+c$ can have any real numbers as its coefficients, including negative numbers.
Is $(x-1)^3$ the only factor of $x^{10}+ax^2+bx+c$?
No, $(x-1)^3$ is not the only factor of $x^{10}+ax^2+bx+c$. There can be other factors as well, but we know for sure that $(x-1)^3$ is one of the factors because it is given in the problem.
How can I use this information to find the roots of $x^{10}+ax^2+bx+c$?
Knowing that $(x-1)^3$ is a factor of $x^{10}+ax^2+bx+c$, we can use polynomial long division to divide $x^{10}+ax^2+bx+c$ by $(x-1)^3$. This will give us a quotient polynomial, which we can then use to find the roots of $x^{10}+ax^2+bx+c$. The roots will be the values of $x$ when the quotient polynomial is equal to zero.
