Find a & b for all real values of x
  • MHB
  • Thread starter mathlearn
In summary, the equation $x^2-\frac{9}{16}=\left(x-a\right)\left(x-b\right)$ can be factored into $\left(x+\frac{3}{4}\right)\left(x-\frac{3}{4}\right)$, with the factors being $\left(\pm\frac{3}{4},\mp\frac{3}{4}\right)$. This satisfies the requirement for all real values of x.
mathlearn
331
Find a & b such that $x^2-\frac{9}{16}=\left(x-a\right)\left(x-b\right)$ for all real values of x;
Looks like the LHS is a difference of two squares, how to find a & b ?
Any Ideas? (Thinking)
Mathematics news on Phys.org
You are correct, the LHS is the difference of squares, and can be written as:
\(\displaystyle x^2-\left(\frac{3}{4}\right)^2\)
Now, how would you factor that difference of squares?
The factors of two different squares would be ,
$a^2-b^2= (a+b)(a-b)$,
In this case it should be (x-a) & (x-b)
-a & -b are two different variables, and both of them are negative.
So what should be done? (Thinking)
\(\displaystyle x^2-\left(\frac{3}{4}\right)^2=\left(x+\frac{3}{4}\right)\left(x-\frac{3}{4}\right)\tag{1}\)
Now, observing that:
\(\displaystyle (c+d)=(c-(-d))\)
Can you write the factorization in (1) in the form you need?
(Speechless) My apologies, Can you demonstrate ?
\(\displaystyle x^2-\left(\frac{3}{4}\right)^2=\left(x+\frac{3}{4}\right)\left(x-\frac{3}{4}\right)=\left(x-\left(-\frac{3}{4}\right)\right)\left(x-\frac{3}{4}\right)\)
So, given the commutative property of multiplication, we may state:
\(\displaystyle (a,b)=\left(\pm\frac{3}{4},\mp\frac{3}{4}\right)\)
Many thanks (Smile)
FAQ: Find a & b for all real values of x
What does "find a & b for all real values of x" mean?
This phrase is typically used in math to indicate that you are looking for specific values for the variables a and b that will work for any real number that is plugged in for x. In other words, you are looking for a and b that satisfy the equation for all possible values of x.
How do I find a and b for all real values of x?
This task is typically done by using algebraic manipulation and solving for a and b in terms of x. You may also need to use properties of real numbers, such as the commutative and associative properties, to simplify the equation and isolate a and b.
Why is it important to find a and b for all real values of x?
This type of problem allows you to find a general solution that will work for any real number, rather than just specific values. This can be helpful in various applications, such as in physics or engineering, where you may need to find a solution that is valid for a wide range of inputs.
Are there any restrictions on the values of a and b for this type of problem?
In most cases, there are no restrictions on the values of a and b for this type of problem. However, if the equation involves square roots, logarithms, or other functions with domain restrictions, then there may be limitations on the values of a and b that will work for all real values of x.
Can I use a calculator to find a and b for all real values of x?
Yes, you can use a calculator to help you find the values of a and b. However, it is important to understand the algebraic steps involved in solving the equation, rather than relying solely on the calculator. Also, be sure to check your answers by plugging in various real numbers for x to ensure that your solution is valid for all values of x.
