Find a function of velocity relative to x
In summary, the problem involves finding the velocity and position functions of an object moving in the x-axis with a given force equation. Using the chain rule, the acceleration is found to be a function of velocity. By reversing the chain rule, the right hand side can be expressed as an exact derivative, leading to the solution for the velocity function. The same process can be used to find the position function.
etchzel
An object is moving in x-axis with given force [itex]Fx = -mω^{2}x[/itex], where ω is a positive constant. when t = 0 the object starts moving from point [itex]x_{0} > 0[/itex].
a. Find the object's velocity function relative to x ([itex]v(x)[/itex])
b. Find the object's position function relative to t ([itex]x(t)[/itex])
Help: [itex]\int\frac{dz}{\sqrt{A^{2} - z^{2}}}[/itex] perform the integration by changing z = A cos u
(I don't know what this help thing for though, I find it irrelevant to the question :confused: )
a. First, using the above-mentioned force equation, I found the acceleration function relative to x, it goes like:
[itex]ma(x) = -mω^{2}x[/itex]
[itex]a(x) = -ω^{2}x[/itex]​
then, since [itex]a(x) = \frac{v(x)}{dt}[/itex], by using chain rule, it goes:
[itex]a(x) = \frac{v(x)}{dx}\frac{dx}{dt}[/itex]
[itex]a(x) dx = v(t) dv(x)[/itex]​
assuming that v(t) = v(x) (even though the function might be different, the result will be the same either way) then:
[itex]a(x) dx = v(x) dv(x)[/itex]
[itex]\int a(x) dx = \int v(x) dv(x)[/itex]
[itex]-\frac{1}{2}ω^{2}x^{2} + C = \frac{v(x)^{2}}{2} + C[/itex]
[itex]v(x) = \sqrt{-1}ωx[/itex]​
there goes my attempt for part a, and I'm not even sure if it was correct, that [itex]\sqrt{-1}[/itex] part is throwing me off :rolleyes:
for part b, my last-moment attempt goes like this:
[itex]v(t) = \int a(x) dt[/itex]
[itex]v(t) = -ω^{2}xt + C[/itex]​
when t = 0, the object is at rest, then v(0) = 0, and when t = 0, [itex]x = x_{0}[/itex]
[itex]0 = -ω^{2}x_{0}(0) + C ==> C = 0[/itex]
[itex]v(t) = -ω^{2}xt[/itex]​
then using integral to find x(t):
[itex]x(t) = \int v(t) dt[/itex]
[itex]x(t) = \frac{-ω^{2}x_{0}t^{2}}{2} + C[/itex]​
when t = 0,
[itex]x_{0} = \frac{-ω^{2}x_{0}(0)^{2}}{2} + C ==> C = 0[/itex]
[itex]x(t) = \frac{-ω^{2}xt^{2}}{2} + x_{0}[/itex]​
pretty sure I was wrong for part b :s
can someone give me a hint on how to solve this problem?
any help is much appreciated, thanks! :smile:
Welcome to PF!
What exactly are you doing? I'm afraid this is nonsense. The acceleration is the time derivative of the velocity. So, it is:$$a(x) = \frac{dv(x)}{dt}$$and so by the chain rule:$$a(x) = \frac{dv}{dx}\frac{dx}{dt} = v\frac{dv}{dx}$$
Now thing to do is to look at the right hand side of that last equation, and notice that it looks like something that *has already been* differentiated with respect to x using the chain rule. So, can you reverse that step, thus turn the right hand side into an exact derivative of something? I.e., right hand side can be expressed as ##\frac{d}{dx}[\textrm{blah}]##, and you have to figure out what "blah" is.
FAQ: Find a function of velocity relative to x
How do you find a function of velocity relative to x?
To find a function of velocity relative to x, you first need to have a position function in terms of x. Then, you can take the derivative of the position function with respect to time to get the velocity function. This velocity function will be in terms of x.
What is a position function?
A position function is a mathematical representation of an object's position in relation to a fixed point, usually denoted by x. It can be written as x = f(t), where t represents time and f(t) is a function that describes the relationship between time and position.
Can a function of velocity be negative?
Yes, a function of velocity can be negative. Negative velocity means that the object is moving in the negative direction, while positive velocity means that the object is moving in the positive direction. The sign of the velocity depends on the direction of the object's motion relative to the chosen reference point.
How is velocity related to displacement?
Velocity is the rate of change of displacement with respect to time. In other words, it measures how fast an object's position is changing over time. If an object has a constant velocity, its displacement will increase or decrease at a constant rate over time.
How does a function of velocity change over time?
The specific shape of a function of velocity over time depends on the object's motion. If an object is moving with a constant velocity, the velocity function will be a straight line. If the object is accelerating or decelerating, the velocity function will be a curve. The slope of the function at any point represents the object's instantaneous velocity at that point in time.
