MHB Find a Mobius Transformation to Map Real Line to Unit Circle
  • Thread starter Thread starter Amer
    Transformation
Amer
Hey mobius transformation defined as
f(z) = \frac{az+b}{cz+d}
and ad \ne bc
it is a one to one function how i can find a mobius transformation that take the real line into the unit circle
I read it in the net
f(z) = \frac{z - i}{z+i}
and i checked it, it takes the real line into the unit circle, but there is a properties of the mobius transformation as the book said it is a combination of translation, inversion, rotation, dilation.
My question is how to find such map, or if we have the real line what first we have to do inversion,rotation,translation, ? to get the circle.
Thanks
Well, Mobius transformations take lines or circles to lines or circles. All you have to do is check three points.
$$f( \infty)=1, \quad f(0) = -1, \quad f(1)= \frac{1-i}{1+i}= \frac{1-i}{1+i} \cdot \frac{1-i}{1-i}
= \frac{1-2i-1}{1+1} = -i.$$
Therefore, you seem to have done it. This method you can use to do most any of these transformations. Take a line or circle into an appropriate line or circle by making sure your $a,b,c,d$ are chosen correctly. Then, if you must map a region, pick a point in the origin region, and make sure it winds up in the destination region.
still not clear, how did you determine f(\infty) = 1 , f(0) = -1
what I was thinking about I said
\mid f(0) \mid = 1 \\ \frac{\mid b \mid}{\mid d\mid } = 1 \\ \mid b \mid = \mid d\mid
thats one
then I found that \mid a \mid = \mid c \mid by mapping infinity
after that guessing ?
what I was looking for is to master the inversion,translation, dilation, rotation
so I can imagine what i have to use to take a region to another
Technically, the $f( \infty)$ is the limit:
$$ \lim_{x \to \infty}f(z)= \lim_{z \to \infty} \frac{z-i}{z+i}
= \lim_{z \to \infty} \frac{1-i/z}{1+i/z}=1.$$
I determined to check $0, 1, \infty$, because those are easy values to check on the real line.
thats one
I've always just transformed the boundaries of regions, and made sure the inside of the region gets mapped correctly. You can check out inversions, translations, etc., here.
Thanks very :D
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
