MHB Find a Particular Solution y_p for 2nd Order ODE at Yahoo Answers
  • Thread starter Thread starter MarkFL
    Ode
The discussion focuses on finding a particular solution y_p for the second-order inhomogeneous ordinary differential equation (ODE) 2y'' + 6y' + 9y = sin^2(x) using the Method of Undetermined Coefficients. The equation is transformed using a power reduction formula, yielding a right-hand side of 1/2 - 1/2 cos(2x). The differential operator is identified, and the proposed form for the particular solution is y_p(x) = A + Bcos(2x) + Csin(2x). By substituting the derivatives into the ODE and equating coefficients, the values A = 1/18, B = -1/290, and C = -6/145 are determined, leading to the final particular solution. This method effectively illustrates the process of solving a specific type of inhomogeneous ODE.
MarkFL
MHB
Here is the question:
Find a particular solution y_p of the differential equation 2y′′+6y′+9y=sin^2(x)?
2y′′+6y′+9y=sin^2(x).
using the Method of Undetermined Coefficients. Primes denote derivatives with respect to x. Thank you.
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello llllllllllll,
We are given the second order inhomogeneous ODE:
$$2y''+6y'+9y=\sin^2(x)$$
Using a power reduction formula, we may write:
$$2y′′+6y′+9y=\frac{1}{2}-\frac{1}{2}\cos(2x)$$
Observing that the differential operator:
$$A\equiv D\left(D^2+4 \right)$$
annihilates the RHS of the ODE, and that none of the roots of this operator are the characteristic roots of the associated homogenous ODE, we know the particular solution must take the form:
$$y_p(x)=A+B\cos(2x)+C\sin(2x)$$
Computing the derivatives of this solution, we find:
$$y_p'(x)=-2B\sin(2x)+2C\cos(2x)$$
$$y_p''(x)=-4B\cos(2x)-4C\sin(2x)$$
Substituting into the ODE, we obtain:
$$2\left(-4B\cos(2x)-4C\sin(2x) \right)+6\left(-2B\sin(2x)+2C\cos(2x) \right)+9\left(A+B\cos(2x)+C\sin(2x) \right)=\frac{1}{2}-\frac{1}{2}\cos(2x)$$
$$9A+(B+12C)\cos(2x)+(C-12B)\sin(2x)=\frac{1}{2}+\left(-\frac{1}{2} \right)\cos(2x)+0\cdot\sin(2x)$$
Equating coefficients, we obtain the system:
$$9A=\frac{1}{2}\implies A=\frac{1}{18}$$
$$B+12C=-\frac{1}{2}$$
$$C-12B=0\implies C=12B\implies B=-\frac{1}{290},\,C=-\frac{6}{145}$$
Thus, the particular solution is:
$$y_p(x)=\frac{1}{18}-\frac{1}{290}\cos(2x)-\frac{6}{145}\sin(2x)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
