btb4198
- 572
- 10
Does anyone know of a Kernel I can use to find a ring in a image ?
The term kernel is used by NVidia to describe functions that run on GPUs that they manufacture, as opposed to functions that run on the computer's CPU. Is this the type of kernel that you're asking about?btb4198 said:Does anyone know of a Kernel I can use to find a ring in a image ?
Do you know of any kernel to identify circular features ?jedishrfu said:i think the OP wants to scan an image using a kernel to identify circular features in the image via convolution.
https://towardsdatascience.com/types-of-convolution-kernels-simplified-f040cb307c37
I think that kernel would match the letter "X", not a circle.btb4198 said:This is it :
_kernel = new double[5, 5] { { 16, 0, 0, 0,16 },
{ 0, 8, 0, 8, 0 },
{ 0, 0, 1, 0, 0 },
{ 0, 8, 0, 8, 0 },
{ 16, 0, 0, 0, 16 }};
Convolution is the process of adding each element of the image to its local neighbors, weighted by the kernel.
The purpose of "Find a Ring with a Kernel" in image processing is to detect and locate circular objects or patterns in an image. This can be useful in various applications such as object recognition, medical imaging, and quality control.
The algorithm works by using a circular kernel, which is a small matrix with a circular shape, to scan the image and identify areas that match the kernel's shape. The center of the kernel is then used as the center of the detected ring, and its radius is calculated based on the size of the kernel and the surrounding pixels.
Yes, the algorithm can be applied to different types of images, including grayscale, RGB, and binary images. However, the effectiveness of the algorithm may vary depending on the quality and complexity of the image.
One limitation is that the algorithm may struggle to detect rings that are too small or too large compared to the size of the kernel. Additionally, it may not be as accurate when there are overlapping or distorted rings in the image.
Yes, there are other methods such as Hough Transform and Circular Hough Transform that can also be used for detecting rings in images. These methods may be more robust and accurate in certain scenarios, but they also have their own limitations and may require more computation time.
