Find "a" which is a real number
  • MHB
  • Thread starter anemone
In summary, $a$ is a real number that satisfies the given equation and can be found by following the steps outlined in the conversation.
anemone
MHB
POTW Director
3,883
115
$a$ is a real number that satisfies the equation $a-\sqrt{4-a}\sqrt{5-a}=\sqrt{5-a}\sqrt{6-a}+\sqrt{6-a}\sqrt{4-a}$.
Find $a$.
Mathematics news on Phys.org
Re: Find a
Find $a$.
My solution
Moving everything to one side of the equal sign, the expression can be factored as
$\left(\sqrt{4-a} + \sqrt{5-a}\right)\left(5\sqrt{4-a} - 4\sqrt{5-a} + \sqrt{6-a}\right) = 0.$
Cleary the first term cannot be zero so the second must. Re-arranging such that
$5\sqrt{4-a} + \sqrt{6-a} = 4\sqrt{5-a}$
and squaring both sides and isolating the square root term gives
$10\sqrt{4-a}\sqrt{6-a} = 10a - 26$
and squaring each side again and isolating $a$ give
$a = \dfrac{431}{120} = 3.591\dot{6}$
Re: Find a
Jester said:
My solution
Well done, Jester! My hat is off to you for thinking out such a nice way to factorize the given expression! (Clapping)
Re: Find a
Find $a$.
My solution:
I first let $m=(6-a)+(4-a)=10-2a=2(5-a)$, this gives
$5-a=\dfrac{m}{2}$$4-a=\dfrac{m}{2}-1$$6-a=\dfrac{m}{2}+1$
So the given equation becomes
$5-\dfrac{m}{2}-\sqrt{\dfrac{m}{2}-1}\sqrt{\dfrac{m}{2}}=\sqrt{ \dfrac{m}{2}}\sqrt{\dfrac{m}{2}+1}+\sqrt{\dfrac{m}{2}+1}\sqrt{\dfrac{m}{2}-1}$
$5-\dfrac{m}{2}=\sqrt{ \dfrac{m}{2}}\left(\sqrt{\dfrac{m}{2}+1}+\sqrt{ \dfrac{m}{2}-1} \right)+\sqrt{\dfrac{m}{2}+1}\sqrt{\dfrac{m}{2}-1}$
I then let $\sqrt{\dfrac{m}{2}}=k$ so I get
$5-k^2=k\left(\sqrt{k^2+1}+\sqrt{k^2-1} \right)+\sqrt{(k^2+1)(k^2-1)}$
Expanding and simplifying the equation and solving it for $k^2$ we get
$5-k^2-\sqrt{k^4-1}=k\left(\sqrt{k^2+1}+\sqrt{k^2-1} \right)$
$25-10k^2+k^4+k^4-1-2(5-k^2)\sqrt{k^4-1}=k^2\left(k^2+1+k^2-1+2\sqrt{k^2+1}\sqrt{k^2-1} \right)$
$25-10k^2+k^4+k^4-1-10\sqrt{k^4-1}+2k^2\sqrt{k^4-1}=k^2\left(2k^2+2\sqrt{k^4-1} \right)$
$25-10k^2+2k^4-1-10\sqrt{k^4-1}+2k^2\sqrt{k^4-1}=2k^4+2k^2\sqrt{k^4-1}$
$24-10k^2-10\sqrt{k^4-1}=0$
$k^2=\dfrac{169}{120}$
and therefore $\dfrac{m}{2}=k^2=\dfrac{169}{120}$ hence, $a=\dfrac{10-m}{2}=\dfrac{10-2(\dfrac{169}{120})}{2}=\dfrac{431}{120}$.
To find $a$, we can manipulate the given equation algebraically. First, we can simplify the square roots by multiplying them together, which gives us:
$a - \sqrt{(4-a)(5-a)} = \sqrt{(5-a)(6-a)} + \sqrt{(6-a)(4-a)}$
Next, we can expand the parentheses on both sides of the equation:
$a - \sqrt{20 - 9a + a^2} = \sqrt{30 - 11a + a^2} + \sqrt{24 - 10a + a^2}$
We can then combine like terms and isolate the variable $a$ on one side of the equation:
$a - \sqrt{a^2 + 11a - 20} = \sqrt{a^2 - 11a + 30} + \sqrt{a^2 - 10a + 24}$
$a - \sqrt{(a+16)(a-5)} = \sqrt{(a+6)(a-5)} + \sqrt{(a+6)(a-4)}$
Finally, we can square both sides of the equation to eliminate the square roots:
$(a - \sqrt{(a+16)(a-5)})^2 = (\sqrt{(a+6)(a-5)} + \sqrt{(a+6)(a-4)})^2$
$a^2 - 2a\sqrt{(a+16)(a-5)} + (a+16)(a-5) = (a+6)(a-5) + 2\sqrt{(a+6)(a-5)(a+6)(a-4)} + (a+6)(a-4)$
Simplifying further, we get:
$a^2 + 11a - 80 = 2\sqrt{(a+6)(a-5)(a+6)(a-4)}$
Now, we can square both sides again and rearrange the equation to get a quadratic equation in terms of $a$:
$4(a+6)(a-5)(a+6)(a-4) = (a^2 + 11a - 80)^2$
$4(a^2 + 2a - 30)(a^2 + 2a - 24) = (a^2 + 11a - 80)^2$
$4a^4
FAQ: Find "a" which is a real number
What is a "real number" in mathematics?
A real number is a number that can be expressed as a decimal or fraction, including both rational and irrational numbers. It is a fundamental concept in mathematics and is used to represent quantities on a continuous number line.
How do I find "a" in an equation with real numbers?
To find "a" in an equation, you will need to isolate it on one side of the equation by using algebraic operations such as addition, subtraction, multiplication, and division. Once you have "a" isolated, you can solve for it by following the order of operations.
What are some examples of real numbers?
Examples of real numbers include whole numbers, integers, fractions, decimals, and irrational numbers such as pi or square root of 2. Real numbers can also be positive, negative, or zero.
Can "a" be any real number in an equation?
Yes, "a" can be any real number in an equation. Real numbers are infinite and can take on any value on the number line. However, in some equations, there may be restrictions on the range of possible values for "a".
How do real numbers differ from complex numbers?
Real numbers differ from complex numbers in that they do not have an imaginary component. Complex numbers include both real and imaginary parts and are represented as a + bi, where "a" is the real part and "bi" is the imaginary part.
