Find accel. of g on Saturns Moon.
  • Thread starter Lance WIlliam
  • Tags
    Moon
In summary, the conversation discusses how to calculate the gravitational acceleration at the surface of Mercury and Saturn's moon Titan. The formula used is F=GMm/r^2 and the necessary information for Mercury is provided. However, for Titan, the radius and mass of Saturn are given instead of the radius of Titan. The conversation then suggests using Google to find the necessary information for Titan and ultimately concludes that the radius of Titan should be used in the formula.
Lance WIlliam
47
]1. Homework Statement [/b]
Calculate the gravitational acceleration at the surface of (a) Mercury and (b) Saturn's moon Titan?
Ive found A by using: F=GMm/r^2
a=Gm/r^2
But how do I find saturns moon titan...All i know is saturn mass which is 5.69e26 and radius6.03e7 of staurn, plus orbit radius 1.43e12
these are not given in the problem I have a chart with the main planets info.
I thought i could just use saturns radius plus orbitsal radius for "r" and use that...but it didnt work.
Thankyou ,
but that does give me the Acceleration of G on the Titan.
example: Earth's its 9.81m/s^2
? m/s^2
What should I use for "r" Do I add saturns radius plus What..? Do I need the distance titan is from saturn?
You use the radius of Titan. I'd ignore Saturn unless you've been specifically told to include it.
ok I did
...G....mass of Titan.../Radius of titan(sq'ed)
a=((6.67259e-11)(1.35e23))/(2.57e3)^2
I get 1.35e6 which is way to big for m/s^2 accel.
You've left the radius in kilometers not meters.
SHouldnt accel. be a number like 3.5ms/^2 not (a number)e6 or 9 ...it should be a lot smaller?
it will be if you use the correct units for the radius.
FAQ: Find accel. of g on Saturns Moon.
What is the acceleration of gravity on Saturn's moon?
The acceleration of gravity on Saturn's moon, Enceladus, is approximately 0.113 meters per second squared.
How is the acceleration of gravity on Saturn's moon different from Earth's?
The acceleration of gravity on Saturn's moon is much lower than Earth's, which is 9.8 meters per second squared. This is due to the smaller size and mass of Enceladus compared to Earth.
How was the acceleration of gravity on Saturn's moon measured?
The acceleration of gravity on Saturn's moon was measured using data from the Cassini spacecraft, which has been orbiting Saturn since 2004. The spacecraft's instruments were able to detect the gravitational pull of Enceladus and calculate its acceleration.
Why is the acceleration of gravity important to know on Saturn's moon?
Knowing the acceleration of gravity on Saturn's moon is important for understanding the moon's surface and its impact on objects and spacecraft landing or orbiting there. It also provides insight into the moon's interior and composition.
Could the acceleration of gravity on Saturn's moon change in the future?
It is possible for the acceleration of gravity on Saturn's moon to change in the future, depending on any changes in the moon's mass or the gravitational pull of Saturn. However, any changes are expected to be minimal over the next few centuries.
