Find acceleration of a box given the forces on it....
In summary: Maybe the angle should be 21° below the horizontal?In summary, a 895 N crate is being pushed across a level floor by a force of 397 N at an angle of 21◦ above the horizontal. The coefficient of kinetic friction between the crate and the floor is 0.24. Using the sum of forces equation, we can derive an equation for the acceleration of the crate in terms of the weight, applied force, angle, and coefficient of friction. However, the applied force angle in the diagram does not match the one described in the problem, suggesting a possible error.
vvvivvvian
A(n) 895 N crate is being pushed across a level floor by a force of 397 N at an angle of 21◦ above the horizontal. The coefficient of kinetic friction between the crate and the floor is 0.24. The acceleration of gravity is 9.81 m/s.
What is the acceleration of the box? Answer in units of m/s/s
to find mass, Fg = mg
895 = m9.8
m = 91.3265I've tried
ΣFy = FN - mg - FAsinθ
ΣFy = FN - mg - FAsinθ = ma
ΣFy = FN - mg - FAsinθ = 0
FN = mg + 397sin21
FN = 895 + 142.272
FN = 1037.27
∑Fx = FAcosθ - Ff
∑Fx = 397cos21 - (0.24)(1037.27)
397cos21 - (0.24)(1037.27) = ma
397cos21 - (0.24)(1037.27) = (91.3265)a
= 1.33 m/s/s but this is not correct
can anyone tell me where i went wrong/what is the correct way? thanks
Note: ##\sum\vec F = m\vec a = (mg)\vec a/g \implies \vec a/g = \frac{1}{mg}\sum\vec F## ... ie. the net force divided by the weight is the acceleration in gees.
ie. your answer would have been a = 0.14g. Then, no need to do that 1st division risking a possible rounding error.
I bring this up because your reasoning seems fine - so the error will be in arithmetic or rounding off or something like that... or a mistake in the problem itself.
So redo from the start...
Info:
W=895N, F=397N, ##\theta##=21deg, ##\mu##=0.24
... the task is to derive an equation for the acceleration in terms of just these 4 things.
Off free body diagram ##\sum\vec F = m\vec a## :
(1) ##F\cos\theta - \mu N = ma = (W/g)a## since ##W=mg##
(2) ##N-W-F\sin\theta = 0##
(N=normal force)
Do all the algebra first - when you have derived the final equatio, then you can put the numerical values in.
The problem describes the applied force as having an angle of 21° above the horizontal, but the diagram seems to show it as directed below the horizontal. Could it be that the diagram is not right?
Likes Simon Bridge
Related to Find acceleration of a box given the forces on it....
1. How do you find the acceleration of a box given the forces on it?
To find the acceleration of a box, you need to use Newton's Second Law of Motion, which states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This can be represented by the formula a = F/m, where a is the acceleration, F is the net force, and m is the mass of the box.
2. What is the difference between net force and individual forces?
Net force refers to the total force acting on an object, taking into account all the individual forces acting on it. Individual forces are the separate forces acting on an object, such as gravity, friction, and applied forces. To calculate the net force, you need to sum up all the individual forces acting on the box.
3. How does the direction of forces affect the acceleration of the box?
The direction of forces does affect the acceleration of the box. If all the forces acting on the box are in the same direction, the acceleration will be in that direction as well. However, if the forces are acting in opposite directions, the net force will be smaller, resulting in a smaller acceleration. If the forces are perpendicular to each other, the net force will be zero, and the box will not accelerate.
4. Can the mass of the box affect its acceleration?
Yes, the mass of the box can affect its acceleration. According to Newton's Second Law of Motion, the acceleration is inversely proportional to the mass. This means that the larger the mass of the box, the smaller the acceleration will be for the same net force. In other words, a heavier box will be harder to accelerate compared to a lighter box.
5. Are there any other factors that can affect the acceleration of the box?
Apart from the net force and mass, other factors that can affect the acceleration of the box include air resistance, friction, and the surface on which the box is moving. These external factors can either increase or decrease the acceleration of the box, depending on the situation. For example, air resistance can slow down the acceleration of a falling box, while friction can decrease the acceleration of a box sliding on a rough surface.
