MHB Find al the four-digit numbers ABCD
  • Thread starter Thread starter anemone
    Numbers
The discussion focuses on finding four-digit numbers ABCD that, when multiplied by 4, yield the reverse of the number, DCBA. The analysis reveals that A must be 2, leading to D being 8. Further deductions show that B can only be 1, with C determined to be 7. The only solution identified is the number 2178, which satisfies the condition of the problem. The thread concludes with an affirmation of the solution's correctness.
anemone
MHB
POTW Director
Find all the four-digit numbers $ABCD$ which when multiplied by $4$ give a product equal to the number with the digits reversed, $DCBA$. (The digits do not need to be different.)
Mathematics news on Phys.org
A has to be < 3 because 3* 4 = 12 so RHS is a 5 digit number
A cannot be 1 as from RHS A has to be even.
So A has to be 2.
now $B$ can be an odd digit $B \lt 5$ because $4*25 = 100$ that is 5 digit
So $AB = 21 / 23$
if $AB = 23$ $DC \ge 92$ so $D = 9$ which is not possible as $4*8$ is $2$ ending but $4*9$ is not.
$AB = 21$
So $D = 8$
so the number = $4*(2108+10C) = 8032+100C$
or $8432+40C = 8012+ 100C$
or $60C = 420$
so $C =7$
so number = $2178*4 = 8712$ or $ABCD=2178$
Well done Kali! And thanks for participating!
Hello, anemone!
Find all the four-digit numbers ABCD which, when multiplied by 4,
We have: \;\;\begin{array}{cccc}_1&amp;_2&amp;_3&amp;_4 \\<br /> A&amp;B&amp;C&amp;D \\<br /> \times &amp;&amp;&amp; 4 \\<br /> \hline D&amp;C&amp;B&amp;A<br /> \end{array}
In column-1: \;4\!\cdot\!A\text{ (plus &#039;carry&#039;)} \,=\, D
. . Hence, A = 1\text{ or }2.
In column-4: \;4\!\cdot\!D\text{ ends in }A, an even digit.
. . Hence, A =2.
And it follow that D = 8.
We have: \;\;\begin{array}{cccc}_1&amp;_2&amp;_3&amp;_4 \\<br /> 2&amp;B&amp;C&amp;8 \\<br /> \times &amp;&amp;&amp; 4 \\<br /> \hline 8&amp;C&amp;B&amp;2<br /> \end{array}
There is no 'carry' from column-2.
. Hence, B =0\text{ or }1.
In column-3, 4\!\cdot\!C + 3\text{ ends in }B,\text{ an odd digit.}
. Hence, B = 1\text{ and }C =7.
Therefore:\;\begin{array}{cccc}<br /> 2&amp;1&amp;7&amp;8 \\<br /> \times &amp;&amp;&amp; 4 \\<br /> \hline 8&amp;7&amp;1&amp;2<br /> \end{array}
soroban said:
Hello, anemone!
. . Hence, A =2.
Good job, soroban! (Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
