DrummingAtom
- 659
- 2
[tex]\int{f(x)dx}\int{\frac{1}{f(x)}dx} = -1[/tex]
At first glance, I thought ex is a solution. But I'm not convinced yet because I didn't formally go through it. When I did it turns into some nasty integral. Here's a couple things I've tried:
From here I took the derivative of each side and then cleaned it up:
Evaluating the left side integral(if this is allowed) and some algebra,.. gives:
[tex]f(x)\int{\frac{1}{f(x)}dx} + \int{f(x)dx}\frac{1}{f(x)} = 0[/tex]
I then took the derivative of each side again and then some algebra gives:
[tex]\int{f(x)} = -f(x)^2*ln(f(x))[/tex][tex]f(x) = -2f(x)*f ' (x)*ln(f(x)) - f(x)*f ' (x)[/tex]
Cleaning it up and canceling gives finally:
[tex]f '(x) = \frac{1}{-2}*\frac{1}{ln(f(x))-1}[/tex]
Which then I would just need to integrate both sides and there's my final function. That integral is nasty (wolfram gave me some strange function as the solution). Which makes me think that it must be wrong. Here's a second try at the solution.
The hint was: [tex]\int{\frac{1}{f(x)}dx} = -\int{f(x)}^{-2}*f(x)}[/tex] by the chain rule.
If the hint is used then:
After integrating both sides:
[tex]f(x) = \int{f(x)}dx^{-2}*f(x)[/tex]
Then:
[tex] \int{f(x)}^{2} = 1 [/tex]
From here I can square root and give:
[tex] \int{f(x)} = 1 [/tex]
If this is the case I have no clue as to what integrated function gives 1 as the solution.
Any help would be greatly appreciated. Thank you.
